August 29, 20232 yr Author Rivet nuts come in mild steel, stainless steel, and aluminum. Aluminum nuts deform far more easily than stainless or mild steel, using hand tools; once the flange nut is added to the gas tube assembly, they will be quite adequate for this purpose.
September 1, 20232 yr Author 6mm x 4mm (millimeter) brass tubing can be used as gas tubes for 3D printer nozzles, used as gas orifices on small burners. You must use an M6x1 tap, to create internal thread for a 3D printer nozzle, about ¼” deep in the gas tube. When tube exteriors are threaded with an M6x1 die, you must stop the external thread short of the tube area with the internal thread. M6x1 external thread, is used to create a gas tube that can be moved back and forth within an M6x1 rivet nut; the nut should be riveted (best choice described further on), silver brazed, silver soldered (workable alternatives) to a fender washer (or sheet metal mounting plate); this allows the gas orifice, which must be screwed into the forward end of the gas tube, to be positioned at the optimal distance from the mixing tube entrance, which is attached to the burner’s funnel. This is the economical choice of exterior thread, but the mounting plate must then be screwed onto the burner funnel’s flange plate (especially practical with sausage stuffing tubes), so that the gas orifice can be cleaned when needed, after installation. Tap the internal thread first, and Screw in a 3D printer nozzle, to check that it is axially aligned. These nozzles are quite short, and unlike soft copper MIG contact tips, they cannot be bent into alignment. If the nozzle is not axially true, cut off this short section of tube, and thread for a nozzle all over again. You will only be losing about 5/16” of tube with every failed attempt. It is pointless to go through all the work to center and align the gas tube, otherwise. Cut the tube off at the desired length for a gas tube suitable for the chosen gas orifice, up to a two-inch length for a ½” burner size, and smaller for smaller burners with their smaller gas orifices. If the gas tube is too short, it will weaken performance, but overlong does not affect performance. Threading the tube’s exterior with an M6x1 die allows you to attach an M6x1 rivet nut to the burner’s mounting plate, in place of a standard hex nut, and by using the same size tap and die, you can buy an inexpensive set. The rivet nuts are 3/4” long, with an exterior lip on one end; their threads end 5/16” short of the end of the nut with an external lip; this makes it nearly impossible to accidentally braze filler alloy onto its internal thread, if you choice to silver braze or silver solder the rivet nut onto it. The rivet nut’s full length can be used to help ensure proper axial alignment of the gas pipe and orifice, once a flange nut is threaded onto the gas tube. Rivet nuts are also easily press fit into 1/4” aluminum plate, which can be used to make large mounting plates. Use your digital calibers to ascertain the exact outside diameter of the rivet nut, before ordering a drill bit. It is important to avoid drilling an oversized hole. Taps used for creating internal threads in gas tubes are seldom used in tubes with the perfect internal diameter for them, and so those diameters might need to be increased with a drill bit, for the tap to start threading properly. M6x1 metric taps used to thread the end of gas tubes, to accept 3D printer nozzles, may need to enter a tube end that has been enlarged with a 5mm or a number #9 (0. 1968”) drill bit. The correct hole size is desirable even with a taper tap, and necessary with the plug tap that you may end up with, unless you search carefully for taper taps. You will only be tapping threads a little over 1/4” deep, to employ 3D a printer nozzle as a gas orifice. Use an M6x1 tap to create thread for use with the gas tube in a 1/4” thick aluminum mounting plate; or silver braze an M6x rivet nut onto a stainless steel mounting plate, rather than a standard hex nut. Rivnuts are 3/4” long, with an exterior lip on one end; their thread ends 5/16” short of this end of the nut, making it nearly impossible to accidentally braze filler alloy onto its internal thread. The rivet nut’s full length can be used to ensure proper axial alignment of the gas orifice, once a flange nut is screwed onto the gas tube; by tightening it up against the other face of the rivet nut. Note: You will use two different kinds of nuts. The flange nut has a hex head that can be gripped with a small crescent wrench. Hold the tube in vice grip pliers or in a press vice, while you start running a die down its length. The rivet nut has no head, but can be gripped in pliers; these tools allow you to trap these two nuts together on the exterior thread you are creating, once you have threaded a sufficient length of the tube, so that you can trap them together, and use the wrench to help finish threading the tube’s exterior, if you lack a press vice, or vice grip pliers. The gas tube’s exterior and interior threads only leave minimal wall thickness to work with. So, you should mount the tube in a drill vice, and do any drill and tap work on a drill press, if you can. It is not easy to drill or tap the inner threads free hand; and they are too short, to work despite cross threading at their entrance. Bevel one end of the gas tube, before running your M6x1 die down its other end. Some sellers list actual inside and outside diameters of their tubing; most do not. If your tube ends up with too thin a wall to support both internal and external thread, you can stop the exterior thread short of one tube end, and tap the internal threads in that area. However, you will then have to be able to remove the mounting plate, in order to clean the gas orifice, so the plate must be screwed in place on the funnel’s flange. Note: You will use two different kinds of nut with the gas pipe assembly. The flange nut has a hex head that can be gripped with a small wrench. Vice grip pliers can hold the tube, while you start running a die down its length (if you do not have a press vice). The rivet nut has no hex head, but can be gripped by those pliers. The gas tube’s exterior and interior threads only leave a minimal amount of wall thickness to work on this tube. So, you should mount it in a drill vice, and do the drill and tap work on a drill press. It is not easy to drill and tap the inner threads free hand. Bevel one end of the gas tube, before running your die down its exterior. Some sellers list actual inside and outside diameters of their tubing; others do not. 6x4mm tube will not support both internal and external thread M6x1 thread, in the same area; you must stop the exterior thread short of the tube’s forward end with its internal threads. You will then have to be able to remove the mounting plate, in order to clean the gas orifice, so the plate must be screwed in place on the funnel’s flange. If you use a silver braze alloy with as high a melting range as you can find, along with black flux that is rated for stainless-steel, this will provide a high temperature bond that requires less care to be kept in place, while brazing a hose barb on its end, with easy flow silver brazing wire and a lower temperature rated flux. Water-soaked rags, or blocking putty (ex. Wetrag) around the part, but kept away from the second area being joined, is another way to help protect existing silver brazed joints. Anti-flux can be placed around a joined area that is too close to the new joint for blocking putty to be used effectively; by resisting fluid flow out of the area of an existing join, it will help you to protect it, while brazing the second join, if you waste no time. Alternatively, a ¼-32 die will create fine enough external thread to be run over the area of M6x1 internal thread, leaving just enough wall thickness, if you screw the 3D printer nozzle in place gently; this allows the gas assembly to be screwed on and off through the rear face of the burner’s mounting plate, so that the gas assembly’s mounting plate can be silver brazed, silver soldered, or glued in place. However, you cannot find Rivnuts (threaded insert nuts) in this fine thread, so you will need to drill and thread a matching ¼-32 hole in ¼ aluminum plate, and add a ¼-32 rear facing nut to the gas tube, to secure it in place on your mounting plate, or change the internal thread in an 8-32 rivet nut accept the larger ¼-32 thread; this involves drilling the smaller 8-32 with a 5.5 millimeter drill bit, and then chasing the larger diameter thread through the remaining thread; this is only feasible because they both have the same number of thread per inch and are near the same size. This work can be done far more easily on aluminum rivet nuts then on steel or stainless steel nuts. It is necessary to tap the internal thread, before the external thread, because the external thread may leave the wall too thin to successfully tap an internal thread, afterwards. If the 3D printer nozzle, is not axially aligned, cut off this short section of tube, and thread for a nozzle all over again. When the gas assembly is finished, only screw the 3D nozzle up to snug; do not over tighten it, or you may rupture the thin wall between inner and outer threads. Unscrew the nozzle before threading the exterior of the tube, and remount it afterwards. You will need to sand the outer diameter of the 3D nozzle a few thousandths of an inch smaller, so that it will slide inside the internal thread on the mounting plate. The tube’s far end can be screwed into a threaded hose barb, after using thread locker to provide a gas tight seal, or it can be silver brazed or silver soldered to seal the threaded joint. You will use an aluminum 8-32 rivet nut, attached to the mounting plate, with this external gas tube thread. You will not find a hex bolt in this size, so use a socket head cap screw that has at least 1-1/2” of thread on it (some bolts are not threaded all the way to the head). Run a hex nut up the bolt, and trap it in place as hard as you can. Then, run a second nut all the way to the first nut, and lock them in position together, to become part of your rivet setting tool. Be sure to set the rivet nut on the mounting plate before you drill and tap it to change its 8-32 thread into ¼-32 thread. What if you cannot get the two nuts aligned together, to use a wrench on? Take the second nut off, and sand one face down, until you can move it into alignment.
September 1, 20232 yr Author Two out of the three orders of flange nuts and rivet nuts purchased online, which were suppose to be 8-32 thread, turned out to be M6x1 thread instead. So, if my directions seam all wrong to you, use digital calipers to insure that the screw or nut that you are working with is actually the size that some drop-shipper claims it to be.
September 3, 20232 yr Author Materials needed to make your aluminum rivet setting tool: (A) A carbon steel socket head bolt of the same thread size as the rivet nut, and at least long enough to accommodate every part, and still engage all the threads on the rivet nut. The reason to use a carbon steel socket head bolt, even if it is called a cap screw, is that it will be stronger than even a stainless steel screw; extra strength is desirable when using a small diameter bolt as part of a forming tool. (B) Two flat washers to sit next to the head of the bolt, and provide bearing surfaces. Some people even grease these washers. (C) A flange nut, drilled out to freely slide over the bolt thread; it is there to provide a bearing surface between the rivet nut and the bolt head, with its locking surface on the side facing the rivet head (you do not want the rivet nut to turn in the hole, while being reshaped). (D) A wrench for the flange nut, and a wrench for the bolt head.
September 3, 20232 yr Author You are far better off to employ aluminum rivet nuts with a homemade rivet nut setting tool, because these small rivet nuts require equally small bolts in your tool. Even though the smaller rivet nuts are easier to compress, the disadvantage grows as the bolt size shrinks. The smaller the bolt the more likely it is to break off while being used in a hand tool. So, malleable aluminum rivet nuts are the obvious choice in these small rivet nuts. The same factors are present in commercial rivet nut setting tools, and show up in broken parts with cheap tools. Why does this happen with cheap tools? Because properly tempering bolts calls for good quality control, and that is what is most often missing in cheap tools.
September 6, 20232 yr Author For larger rivet nuts (8mm or 5/16” and up) you should choose steel, because, in the large sizes many people complain of stripping their weak aluminum threads, while the larger mandrels on the commercial tools (and larger bolts on homebuilt tools) are not inclined to break.
September 6, 20232 yr Author Mounting plates So, why start with sheet metal, or a fender washer to make a mounting plate? Why not braze together separate parts instead? When you begin with a flat surface; all you need to do, is avoid bending it, to assure that the gas assembly mounted to it will remain perpendicular to the air opening, and therefore axially true to the cone shaped air entrance. Fender washers come in various thicknesses, over which you have little control; because they all have 2-1/2” or smaller diameters, that is okay. But the larger mounting plates that you make from sheet metal need a minimum thickness, to ensure that they stay flat while being constructed, and then mounted. 0.079” thickness in stainless-steel plate is strong enough to stay flat when being silver brazed to a funnel, but not so thick that it is difficult to drill the center hole; then cut and grind three air openings. How thick aluminum plate should be is more dependent on what alloy is used, rather than funnel diameter. Choose 1/8” thick 6061 (AKA T651) aluminum plate; it is the most rigid available, but is no more work to drill, thread, or cut, than soft aluminum alloys.
September 7, 20232 yr Author Note: Small metric (ex. M2) cap screws and matching nuts are the inexpensive and simple way to screw mounting plates to funnel flanges; they allow you to drill matching holes through both parts, and screw them together, while avoiding the use of tiny taps (which are inclined to break off in the hole). You can find them in kits for under ten dollars online.
September 7, 20232 yr Author Drill an oversize hole through both parts (use 1/8” M35 high speed steel drill bits for M2 size screws).
September 7, 20232 yr Ah GEE Mike breaking taps is the BEST way to learn how to use them. Do it on practice pieces before tapping something that counts. Frosty's secret tip is, "Don't get in a hurry, take a turn on the tap but as soon as you stop, revers direction to break the cuttings loose before taking the cut farther. Use light oil to clear and carry the chips out, it's not really a lubricant. Frosty The Lucky.
September 7, 20232 yr I purchased a product called Tap Magic many years ago. It worked so well that I eventually bought a gallon. I use it for drilling and tapping. Still, the second you feel resistance, reverse, then forward. Peck all the way through. I have gone against the wisdom of Frosty’s last post and broken taps. It has been a long time since I have broken a tap because I never try to get just a little more when the tap starts to bind. When the part matters, a piece of broken tap stuck in there is always an adventure. Also, drill the correct size hole for the tap. Depending on how much thread engagement you need, you can get away with a little too big but a little too small is no good.
September 7, 20232 yr The local WalMart carries Tap Magic, I'll have to pick up some and give it a try. Dad used water soluble oil mixed a little thick for drilling and tapping in his day. Frosty The Lucky.
September 7, 20232 yr I figured it was just a clever marketing name, but I was truly surprised at the difference Tap Magic made when cutting threads or drilling in certain materials.
September 7, 20232 yr Author Good input guys. I can now refined my descriptions on threading, with better language Boeing had some green slimy stuff that worked wonders for tapping, but I could never find out what it was.
September 7, 20232 yr Tap Magic has been my go to for tapping and drilling for seems like forever, never found better. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus
September 8, 20232 yr Author IMQUALI Rivet Nut Tool, 17" Rivet Nut Tool Set with 13 Metric & SAE Mandrels M4 M5 M6 M8 M10 M12, 8-32, 10-24, 1/4-20 * 2, 5/16-18, 3/8-16, 1/2-13, 130pcs Nuts, Durable Blow Molded Case, IMQ-900 ($46 through Amazon.com). This tool had pretty good reviews, so I thought that their mandrels must be hardened. Since I prefer to use stainless steel rivet nuts for all my small burners (to create show-pieces), it looked like a worthwhile tool. Alas the 5/16-18 rivets that came with the tool didn't want to screw down all the way onto the mandrel. So, I sent away for a die from one ad, and a tap from another. The tap came today, and sure enough the rivet nut's threads needed chasing. However, it still didn't screw all the way onto the mandrel, so I must wait for the die to arrive, to see if the problem can be cleared up. Even if that works, it means that all thirteen mandrels will probably require their own tap and die. At an average price of $14 a pair, that would come to an extra $182 to get a $46 tool fully functional!!! Still another reason to build your own tool. Fortunately, I am only care about three rivet nut sizes; even this will nearly double the tool's price
September 9, 20232 yr Author Even tools that were once known for their quality are changing management these days, and one of the first casualties is quality control.
September 9, 20232 yr Exactly, gold standard brands are just flecks of mica since being taken over by bean counters and foreign acquisition. Dad's WWII era Sear's right angle disk grinder predates Craftsman and will still rip your arms off if you're not careful and my 70s, Craftsman hand tools are the best in my tool box. I'd call the new versions crap but at least you can fertilize a garden with crap. Frosty The Lucky.
September 9, 20232 yr Author Well, quality tools are way to likely to grow legs on job sites these days. When I left the failing shipyards and started working on the docks, I gave away nearly all my American manufactured tools to buddies who didn't, and replaced them with Harbor Freight specials. Why? the only thing worse than poor tools, are suddenly missing tools in the middle of your shift! It wasn't easy working with "the forty thieves" for fifteen years, but it beat returning to Boing Boing Aircraft Co.
September 10, 20232 yr Author For most of my life, homemade tools only made sense if something was needed that wasn't offered in the marketplace. American tools that were being invented in the forties, were so durable in fifties. Japanese tool designs improved far faster than quality declined through the sixities and seventies. Later, Chinese tools were so cheap that their flaws could be overlooked for quite a few years. I remember looking through a book on blacksmithing, from an author who built all of his own tools, and laid out how to duplicate them in detail. It was obvious that I could repurpose cheap imports for a fraction of the time and expense, since a worked steel already. But everything changes over time. Today, if you can't buy a quality tool, you are far better off to build your own from scratch, just like in the forties. Everything comes back around again on the merry-go-round of history.
September 10, 20232 yr Author Materials needed to make your rivet nut setting tool (revised): (A) A grade 12.9 steel socket head cap screw of the same thread size as the rivet nut, and at least long enough to accommodate every part, and still engage all the threads on the rivet nut. The reason to use a hardened steel cap screw, is that it is much stronger than even a stainless steel cap screw; extra strength is desirable when using small diameter thread as part of a setting tool. (B) A minimum of two brass flat washers, to sit next to the head of the bolt (and provide bearing surfaces). Some people even grease these washers. More washers will simply provide more slip. (C) Two flange nuts; one is screwed up tight against the bolt head; and a second flange nut drilled out to freely slide over the bolt’s thread (it is there to provide a bearing surface between the rivet nut and the bolt head, with its locking surface on the side facing the rivet head (you do not want the rivet nut to turn in the hole, while being partially crushed into shape). (D) A wrench for each of the two the flange nuts. Drill a hole in the mounting plate that is as close to the rivet nut’s outside diameter as feasible. A friction fit would be ideal. The more gap there is between the rivet nut and the hole the harder your job of riveting becomes. The less gap there is between the rivet nut’s body and the hole it gets pushed into the sooner it starts becoming trapped in place, and no longer able to turn under your tool. Screw the first flange nut tightly against the bolt head. Slide two or more flat washers onto the bolt, beside the first flange nut. Slide the drilled out flange nut onto the bolt, with its locking side facing the rivet nut. Screw this assembly unto the rivet nut, just finger tight. Push the rivet nut into the hole in the mounting plate. Put a wrench on each of the flange nuts. Tighten the nut next to the bolt head until the rivet nut is securely fastened onto the mounting plate, using the wrench on the drilled-out flange nut to keep it from turning. You can find several videos of this process on the Net, with minor variations in nut and flat washer choices. You are far better off to employ aluminum rivet nuts with a homemade rivet nut setting tool, because small rivets require equally small bolts. Even though small rivet nuts are easier to compress into shape, the problem grows as the bolt diameter shrinks. The smaller the bolt the more likely it is to break off while being stressed, by use as part of a hand tool. So, malleable aluminum is the obvious choice for small rivet nuts. The same factors are present in commercial rivet nut setting tools, and show up as broken mandrels. Why does this happen? Because properly tempering mandrels calls for good quality control, and that is usually absent with cheap tools. For larger rivet nuts (8mm or 5/16” and up) you should choose steel rivet nuts, because, in the larger sizes, many people complain of stripping the weak aluminum threads, while the larger mandrels on the commercial tools (and larger bolts on home-built tools) are less inclined to break. Note: Grade 12.9 bolts are easier to find than imported rivet nut tools with properly hardened mandrels; they are a lot cheaper too. Flange nuts: You will use two flange nuts as part of your homemade rivet tool. You will also use a flange nut to tighten the gas tube into axially true position on the gas assembly’s mounting plate. Alternatively, two flange nuts can be used to secure the gas tube on a mounting plate without use of a rivet nut, if need be. One flange nut is silver brazed, or silver soldered to the forward-facing side of the mounting plate. The second nut is used, snugged up against the plate, to tightly trap the gas tube in an axially true position.
September 11, 20232 yr Author IMQUALI Rivet Nut Tool update Well it turns out that the only thing wrong with this tool was its new owner. I had the wrong mandrel in the tool. With the correct mandrel it worked just fine.
September 12, 20232 yr Author Gas assemblies for MIG contact tips 5/16”x 3/16” brass tube can be internally threaded for MIG contact tips; their 3/16” inside diameter can be threaded for the most common thread found in MIG contact tips (1/4-27). The exterior will accept 5/16-18 dies to create external thread for 5-18 rivet nuts for use on mounting plates). However, 5/16” diameter is also only 0.0025” larger diameter than 8 millimeter, allowing it to be externally threaded to match 8M rivet nuts. This heavy wall tubing can also be used to create gas tubes that are screwed directly into ¼” thick aluminum mounting plates, and then locked in position with a flange nut. If you chose a nylon inserted locknut for this, it will stay in the correct position, without need for brazing, soldering, or gluing it on the gas tube, after the correct distance between the gas orifice and mixing tube opening is found, during tuning. Hose barb sizes for 5/16” tube: Barbed hose coupling sizes match the outer diameter of the narrowest portion of the barb; this leaves no room for threads of those same diameter. Therefore, 5/16” barbed couplings can be threaded to match up with 5/16” tube, only through their thickest sections. 3/8” size barbed couplings can be silver brazed, or silver soldered, but will call for 3/8” fuel hose. If the barb is screwed onto the gas tube, the threaded joint must be sealed with thread locker, to prevent gas leaks. Lamp thread parts: For people who cannot afford “doing things the right way,” or aren’t able to find all the parts and tools, for externally threading 5/16” x 3/16” brass tubing, the gas tube can be chucked into a drill motor, and power sanded to a few thousandths on an inch smaller diameter; then, pushed into lamp thread parts (externally threaded tubing with matching washers and nuts) from your hardware store’s lamp section (usually located in the electronics area). Smaller gas tubea can be trapped in place by silver brazing, soldering, gluing, or even wrapped in electrical tape; it is the lamp thread that must move back and forth for proper tuning, while the trapped gas tube moves with it. Lamp thread tubes have external 1/8-27 IPS thread (AKA IP thread), and internal diameters of 0.285” that will accommodate a 6mm or 1/4” O.D. gas tube with external wrapping of electrical tap, or a 5/16” x 3/16” tube (0.3125” O.D.) after some power sanding while it spins in a 3/8” drill motor. Lamp part nuts are not a good choice for silver brazing, to hold their position on lamp tube. However, one nut can be screwed up against the end of the Lamp rod coupling (or rethreaded 1/8" x 1/8" brass pipe coupling), which the lamp tube is screwed into, and maintain the proper distance between the end of the gas orifice, and the opening of the mixing tube. A second nut can then be tightened hard against it, locking both nuts in position on the lamp tube, allowing you to unscrew the gas tube, to remove and clean the gas orifice, and then return it to the same position, afterward. You do not need to perfectly match up the outside diameter of whatever you use for a gas tube with the inside diameter of the threaded lamp tube. Loose fits are just fine so long as you center the gas tube in place, and prevent movement between the lamp part (threaded tube) and the gas tube. Even electrical tape can be used to provide an interference fit between the gas tube and lamp part. Cut mounting plates with closely matching center holes to the outside diameter of 1/8” brass pipe couplings as mountings for the burner’s gas assemblies. A 1/8" x 1/8" brass pipe coupling has female (internal) 1/8-27 NPS (tapered pipe) thread. A 1/8-27 IPS tap creates parallel thread of the same kind that is used on lamp parts; this tap can be easily run through the tapered threads in a brass couple, to create a practical fitting for use with threaded lamp tubes; to be silver brazed, or silver soldered onto a mounting plate. Lamp rod couplings already have the right thread, so you do not need to purchase a tap; otherwise, they can be installed in the same manner as a pipe coupling, once one end is filed or sanded down to the same diameter as the rest of the tube. Lamp thread couplings can be purchased in inexpensive kits, along with all the flat washers and lamp nuts you will need.
September 13, 20232 yr Author There is little that is more discouraging than searching for the right size fender washer, with close to the right size center hole, to repurpose into a mounting plate for your linear burner's gas tube, and only see photos of 1/8" thick washers, which will take loads of work to cut and grind three air openings into. But, take heart; those photos seldom show the much thinner washer you will actually receive. I almost passed by such an advertisement, before noticing that the written description called for a 0.049" part thickness; that's much easier to deal with. The washers arrived today, and are appropriate for this use.
