stan Posted September 22, 2015 Share Posted September 22, 2015 The extent of my knife making is limited to a couple of simple bench coil spring ones, lately I have made a couple of fire pokers with about 4inches bent over welded (electric arc) and re forged to form the handle.So here is a coil spring knife made similar,steel was preheated before welding.knife is not that great but I was interested to see if the thing would crack or fail during the process of forging, welding ,heat treatment so far all good..I do plan to put it to use in the back yard. Quote Link to comment Share on other sites More sharing options...
neg Posted September 22, 2015 Share Posted September 22, 2015 Looks nice! You gunna put a proper handle on it or leave it as is? Quote Link to comment Share on other sites More sharing options...
stan Posted September 22, 2015 Author Share Posted September 22, 2015 The extent of my knife making is limited to a couple of simple bench coil spring ones, lately I have made a couple of fire pokers with about 4inches bent over welded and re forged to form the handle.So here is a coil spring knife made similar,steel was preheated before welding.knife is not that great but I was interested to see if the thing would crack or fail during the process of forging welding ,heat treatment so far all good..I do plan to put it to use in the back yard. Thanks neg , have to think more about a handle. Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted September 22, 2015 Share Posted September 22, 2015 Thanks neg , have to think more about a handle.Good Morning,Thinking about a handle is quite simple. One half is on one side, the other half is on the other side. Couple of locating pins, a few drops of epoxy, a little pinch, a little patience. Presto, a lump. Now make the lump nice!!Just a thought,Neil Quote Link to comment Share on other sites More sharing options...
stan Posted September 22, 2015 Author Share Posted September 22, 2015 Hi Neil the original idea was by folding a section of the coil spring over and weld and forging it would become the handle but as it turned out it dose not quite have enough mass to make a good handle so I will add a lump to it. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 22, 2015 Share Posted September 22, 2015 Tang looks way heavy, adding a handle will make it even more so. I'd grind it down and then handle it! Quote Link to comment Share on other sites More sharing options...
stan Posted September 22, 2015 Author Share Posted September 22, 2015 Yes your right Thomas that sounds like the way to go,I realize now that if I want to make the knife in one piece with a metal handle I need more stock that end or if I want to add a handle the original stock size would probably been ok.This one seems to be in between. But I don`t think it was a complete waste of time because its shown me that I can weld up spring steel and re forge it, I was half expecting it to crack or delaminate. Quote Link to comment Share on other sites More sharing options...
bikecopXXX Posted September 28, 2015 Share Posted September 28, 2015 That looks good to me. different enough to be interesting. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted September 28, 2015 Share Posted September 28, 2015 Might be a camidate for a rapped (dodged a fun spelling oops) handle. Most ar disatisfiingly thin. Quote Link to comment Share on other sites More sharing options...
stan Posted September 28, 2015 Author Share Posted September 28, 2015 Thanks bikecop,a rapped handle a good idea Charles Quote Link to comment Share on other sites More sharing options...
LibrariaNPC Posted September 29, 2015 Share Posted September 29, 2015 Honestly, I'm gawking at how you have that handle set up and curious how you put the guard in like that. Mentally I'm trying to figure out how you did it without cutting into it, and while I have a few theories, I can't say I have it figured out.Personally, I like the metal handle, but that's mostly because I don't have the setup for good handles. If you plan on using this in the yard, though, I'd use a wrap, and go with colors that will jump out at you. Quote Link to comment Share on other sites More sharing options...
stan Posted September 29, 2015 Author Share Posted September 29, 2015 Hi libraria and thanks, as I said before I am no knife maker and the method would probably be considered un conventional at best I started using the method for a few fire pokers and like you like the idea of a metal handle.Once the section (3to 4 inches is folded over and welded its heat to bright yellow and re forged.The guard can be shaped before or after.If you can get 5/8 spring steel it would be better with a larger handleCheers Stan Quote Link to comment Share on other sites More sharing options...
ausfire Posted September 29, 2015 Share Posted September 29, 2015 Hey Stan,Can't really comment on your knife as I'm no knife maker, but it certainly looks fine to me. Interesting how you welded and reforged it.I'll have to try something like that one day - I've got coil springs of all sizes and no idea what to do with them. Quote Link to comment Share on other sites More sharing options...
LibrariaNPC Posted September 29, 2015 Share Posted September 29, 2015 I would not have expected a weld like that by looking at your image. Interesting approach! Thanks for the elaboration on that! Quote Link to comment Share on other sites More sharing options...
stan Posted September 29, 2015 Author Share Posted September 29, 2015 (edited) Hi Ausfire the process of folding over or adding pieces then re forging works well for me because I have not mastered forge welding.you should try the process with mild steel for your camp oven lifters after re forging if your lucky you can`t see the weld marks. .So far I have not had any problems with welding and re forging spring steel,I allow the this to heat up to a dull red before welding clean the slag a good wire brush and back in the forge Edited September 29, 2015 by stan Quote Link to comment Share on other sites More sharing options...
stan Posted September 29, 2015 Author Share Posted September 29, 2015 Here is the second try of a knife made out of coil spring in one piece with a metal hand Although its probably more a dagger. I should have taken more photos, but there is one directly after welding . The brass inlay was to cover a stuff up in that slight hollows were leaf after re forging. Quote Link to comment Share on other sites More sharing options...
ausfire Posted September 30, 2015 Share Posted September 30, 2015 Hi Ausfire the process of folding over or adding pieces then re forging works well for me because I have not mastered forge welding.you should try the process with mild steel for your camp oven lifters after re forging if your lucky you can`t see the weld marks. .So far I have not had any problems with welding and re forging spring steel,I allow the this to heat up to a dull red before welding clean the slag a good wire brush and back in the forge Stan, I have used the fold and weld technique a couple of times to make snakes with a python-like head. It's really hard to upset 5/8 steel to get enough mass for the head, so fold/weld reforge works pretty well. I welded it cold though. Might be easier at red heat. Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
stan Posted October 1, 2015 Author Share Posted October 1, 2015 Had some of this refrigeration capillary tube laying around so use for a copper wrap. Quote Link to comment Share on other sites More sharing options...
ausfire Posted October 1, 2015 Share Posted October 1, 2015 Good use for fridge tube. Cool handle ay? Quote Link to comment Share on other sites More sharing options...
stan Posted October 1, 2015 Author Share Posted October 1, 2015 Good use for fridge tube. Cool handle ay?Thanks Ausfire the capillary tube is good because the wall thickness is quite large for its diameter so can be bent tight without creasing, makes a comfortable handle. Got enough knives now don`t really have the right grinding/polishing setup looking forward new project but finding the right one not easy. Quote Link to comment Share on other sites More sharing options...
ausfire Posted October 2, 2015 Share Posted October 2, 2015 Your new Ryobi might help with that, Stan. Quote Link to comment Share on other sites More sharing options...
