Should I buy this?
I have the chance to pick this peter wriggt 100lb anvil for 200 dollars the only think is the edges are pretty round and one side is banged up a little is it still a good buy and could I make my money back if I ever want to resell it?
I would drop $200.00 on that in a heartbeat! Drop a one inch ball bearing on the top and check for rebound but it looks to be in great shape.
Yes, you will get your $ back any day of the wek
Grab it before someone else does, then go home and admire it and congratulate yourself on a fine acquisition.
Hopefully your out buying that anvil and not reading these posts!
If you don't like the rounded side step around it and use the other side! Good looking anvil give it a work out!
It appears to be in good usable condition. You do not want sharp edges, as they can create cold shuts in the workpiece.
As to price. You won't lose any value considering the average today is around $3 a pound here in the US.  It is more than I pay, and less than others are paying, you're right in the middle. It is a well known maker, with a good reputation. As long as the top plate checks out , IE; not delaminating, not softened from a fire, etc..it will serve you well.
