A few spare nuts.....
THAT is just plane NUT'S !!!!!!!!!!!!!! LOL :o
thanks for the look
makes you wonder how many nuts it took & how long
I'd be willing to wager that there's over a million nuts in that piece.  I can't imagine how much work went in to all that spot welding, and then having to shape it all correctly to get the musculature just right.
Definitely more than a week's work, even if you add in a few hours of overtime!
I'd take you up on that wager.  A million 1/2" nuts would roughly weigh 35000 pounds.  Even if that thing was solid steel rather than hollow form if would weigh less than that.
If I were to make that I'd tack the nuts together as a flat sheet then form the "sheet" of metal as needed.  Weaving the edges of the sheets together so they looked good would be the trick.
All I can say is WAY Cool piece. There are just TOO MANY straight lines for me to get started on and stay off moderated status. A lot of work for sure.
That is an amazing sculpture. Not sure I'd like it in the loungeroom but you have to admire the tenacity of the sculptor.
So how was it done? If it was spot welded, he's a very neat welder! Maybe it's a fibreglass figure with the nuts attached? It would be interesting to know.
Finally found a credit on the site.  Turns out that Hulk was made by these guys -->  http://www.oldsteelart.com
Judging by their site, they're no strangers to doing incredible things with bits of metal!
