August 16, 201411 yr I'm looking at getting a 108 lb Hay Budden for my first anvil. The guy is asking 300 for it. There are no significant chips out of the side, and no cracks or undo wear that I can see. Is that a reasonable price for the size?
August 16, 201411 yr Great anvil, H-B's. One thing you can do...check the rebound with a steel ball bearing if you can, or, gentle drop with a ball pein hammer, handle pinched between thumb and finger (latter with the owner's permission, of course). $3 per pound might be considered a bit high by some, but if it's in mint condition may be worth it. A 108 would be okay for lighter work, but not real heavy forging. I paid $2.25/lb. for a 170# H-B in very good condition.
August 16, 201411 yr Pictures of the anvil in question would help. Also where you are located and what type of things you plan on making on the anvil. If you are in New England or Ohio or other "anvil rich" areas, you may be able to find others for less. If you are in an area where anvils are scarce, jump all over it, but again, pictures would help.
August 16, 201411 yr Author I'm in Dayton Ohio. I've heard Ohio is anvil rich, but I can't seem to find them, or if I do they want ridiculous prices. I wouldn't be doing heavy forging, ultimately I would like to do knife making, or maybe a few swords.
August 16, 201411 yr Well for what you described as what you want to do, I would think 108 LBS would be a good size unless you plan on doing pattern welded billets someday where you may want some more beef under the hammer. Search this site for TPAAT and use it. Check craigslist as often as possible (the good anvils for good price tend to disappear within hours and sometimes minutes of being posted for sale). Without pictures I couldn't give a yes/no answer as to what I would do, but as to the brand, Hay-Budden is an excellent brand and is my 2nd favorite anvil I have worked on next to my Columbian. All things aside and assuming the condition is as good as you say, $3 a pound is pretty standard around my area with the occasional $2 or less a pound. Many folks will also mention to you that for blade smithing, a perfectly suitable anvil is a heavy hunk of steel. Search for scrapyard anvils or read through the blade smithing section and I'm sure you will find examples. Edit: Pics posted while I was typing. It looks pretty good to me. That paint is ugly IMO though and can serve to hide defects sometimes. Might help in getting the price down a little bit.
August 16, 201411 yr Greetings Mike, Judging by the paint the anvil was used for a lawn ornament ... I looks to me like the face has some deep pits from sitting out.. Look careful that could be a problem. Good luck Forge on and make beautiful things Jim
August 16, 201411 yr You have a bit over a month before the largest annual blacksmiths conference in the world is held just up the road from you; buy your anvil there! Shoot we had a local fellow from NM buy 30 anvils the first Quad-State he went to...and a trailer to get them home. Did you ask at SOFA meetings?
August 16, 201411 yr That size anvil is very popular, since it is light enough to move yet stout enough for some reasonably sized work. Hay-Budden is a great brand, also my second fave, after Fisher, but a HB is my main forging anvil. The face is not as mint as you think, the edges have some big chips, yet they are well within the realm of being ground off and rounded over to prevent further chipping. It doesn't seem to have much if any sway, an indication of overall condition. I'd say considering it's small size and better than fair condition, it is a decent price, but as Thomas points out, you should likely wait until the anvil supermarket opens next month.
August 17, 201411 yr Author I have never attended a SOFA meeting. Where / when is this blacksmiths conference? I would gladly hold off on my purchase until then if I can possibly get a better deal.
August 17, 201411 yr Mike, take a look here. http://sofablacksmiths.org/quadstate/quadstate2014.html Brian Pierson
October 1, 201411 yr Author I ended up not getting it (didn't even bother with the drive to look at it). Waited till quadstate and went there looking. Ended picking up a 154lb Hay Budden (much closer to the size I really wanted to have).
October 1, 201411 yr Great! I picked up a 5" postvise for US$35, robustus not gracile, sure drooled over the 700# Fisher and even more over Patricks 1050# double horn. Hope you enjoyed Quad-State!
