john_zxz Posted June 22, 2013 Share Posted June 22, 2013 Hi, yesterday I began to forge a new pair of tongs. I started with 3/8" x 1" mils steel and I fullered it with my flypress. When I was drawing the handle, I noticed there was a lot of cracks on it. I never forged it colder than orange color, it was always yellow and I stopped when orange. One rein was correct but the other was definitely ruined by these cracks. What happened? My dies for the flypress is 2 pieces of 3/4 round that act as a fuller so there is no cold shuts... The first pic is the 2 reins when I stopped working on them because of the cracks. The second is the one that is fine and the others ares the cracks in detail of the other tong. What can cause that? I'm pretty sure it is not the flypress because it is not powerfull enough to squeeze the metal in one heat, it took several. Is it the repetive heats? I must tell that I'm using hard anthracite (clean one) as a fuel. I wonder if it can transfer carbon to the steel due to repetitive heats and then becoming brittle? I noticed that when I put a little piece in the fire several times, it tends to develop cracks too, that's why I'm asking for the fuel... And it never happened with coke or coal. For now I will have to forge weld a piece for the reins because the cracks are too deep it will shatter when put into stress I guess... Quote Link to comment Share on other sites More sharing options...
bigfootnampa Posted June 22, 2013 Share Posted June 22, 2013 Your metal was overheated and started to burn. You could forge weld a new rein... but it would be easier to start over IMO. Quote Link to comment Share on other sites More sharing options...
Bob S Posted June 22, 2013 Share Posted June 22, 2013 looks burnt to me too. will be unpossible to weld. start over. Quote Link to comment Share on other sites More sharing options...
john_zxz Posted June 22, 2013 Author Share Posted June 22, 2013 Well if it started to burn I didn't notice, it was yellow at its brightess.... but I recently changed my bulb light for a brighter one so maybe the color appears different in my shop now... Thanks Quote Link to comment Share on other sites More sharing options...
macbruce Posted June 22, 2013 Share Posted June 22, 2013 Mild steel is no longer mild imo, they add too much scrap to the mix so it's kinda like burning medium carbon steel at the very least, which ain't cool. Quote Link to comment Share on other sites More sharing options...
john_zxz Posted June 22, 2013 Author Share Posted June 22, 2013 Yes Macbruce, I learned that last week :wacko: when I quenched a 1/8 thick plate in water and then bend it cold to a 90 degrees angle... It snapped at 20 degrees and the center looked like carbon steel... By chance I didn't receive the piece on my face. Quote Link to comment Share on other sites More sharing options...
SoCal Dave Posted June 22, 2013 Share Posted June 22, 2013 There is something to be said about the light in your shop. The old blacksmith's have minimal light which may give a truer color for the naked eye. I have learned to turn out the lights in my shop, during the day, and close the doors, if I need to be sensitive to the color changes in the metal I'm working. I really noticed this when working with bronze. I know there are lots of different types of light bulbs made today and they will change how you see colors. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 24, 2013 Share Posted June 24, 2013 Look into "hot short" as opposed to "cold short" You keep saying it only got to yellow but what if that steel can only take orange? Quote Link to comment Share on other sites More sharing options...
teenylittlemetalguy Posted June 24, 2013 Share Posted June 24, 2013 There is something to be said about the light in your shop. The old blacksmith's have minimal light which may give a truer color for the naked eye. I have learned to turn out the lights in my shop, during the day, and close the doors, if I need to be sensitive to the color changes in the metal I'm working. I really noticed this when working with bronze. I know there are lots of different types of light bulbs made today and they will change how you see colors. Lamps ( light bulbs) are rated with a CRI color rendering index, this higher the number the better the color rendition. Also they carry a kelvin temp for the color of light output. The higher that is the closer to true sunlight. So a fluorescent lamp in a house might be 3500 K and 70 CRI. In my shop I prefer 4100k and 80+ CRI. But I still like it dim so I can see the color of the light from the metal. Quote Link to comment Share on other sites More sharing options...
Dan C Posted June 24, 2013 Share Posted June 24, 2013 What about grinding down to good metal before deciding to start over? I forged a gardening tool this weekend and burned it slightly. Cooled it, then ground it down to what looks like good steel, normalized and then finished the cultivator. As I'm uncertain about it's integrity though I'm keeping this one for myself vs. selling it. Quote Link to comment Share on other sites More sharing options...
john_zxz Posted June 24, 2013 Author Share Posted June 24, 2013 The steel is 44W (A36 for US I think?). Is there any issue with working it at yellow color? This is the only mild steel they sell at my local supplier and I'm a total newbie with the differences in mild steels. It think it may be because of my new light bulb (fluo compact) I must have misread the color of the steel. If I grind it to remove enough of the cracks it will be too thin, so I'll cut the bad part and weld a new rein (the jaw is still in good state) Quote Link to comment Share on other sites More sharing options...
joshua.M Posted July 2, 2013 Share Posted July 2, 2013 I live in Ontario, we use the same grading system as the US, never heard of 44W Josh Quote Link to comment Share on other sites More sharing options...
son_of_bluegrass Posted July 2, 2013 Share Posted July 2, 2013 If you're using something like A36, it could be anything and not necessarily mild steel. A36 is a structural grade which means it need to meet certain criteria for strength not for composition so it may have alloying elements that make it air hardening or hot short or just completely unsuitable for forging. And that may just be a 6 inch section in 5 foot worth of bar or it may be most of a bar. Since there is a lot of recycle in structural grades they become a crap shoot, sometimes you get a lovely to forge piece, sometimes you get a section that falls apart no matter what you do. ron Quote Link to comment Share on other sites More sharing options...
john_zxz Posted July 5, 2013 Author Share Posted July 5, 2013 If you're using something like A36, it could be anything and not necessarily mild steel. A36 is a structural grade which means it need to meet certain criteria for strength not for composition so it may have alloying elements that make it air hardening or hot short or just completely unsuitable for forging. And that may just be a 6 inch section in 5 foot worth of bar or it may be most of a bar. Since there is a lot of recycle in structural grades they become a crap shoot, sometimes you get a lovely to forge piece, sometimes you get a section that falls apart no matter what you do. ron Thanks for the explanation on A36, I didn't know that this steel can be different in composition from batch to another batch. Quote Link to comment Share on other sites More sharing options...
Francis Trez Cole Posted July 8, 2013 Share Posted July 8, 2013 take a look at how deep your fire, with your metal in the orange or yellow range. Your working area of forge Coal is like a ball the bottom of the ball will oxidize the metal the top will pick up the junk where your coal is converting to coke. I have seen this happened in rivet forges where the fire pot is not deep and the depth can be fixed with a few bricks to make the mound of coal deeper and bigger. Quote Link to comment Share on other sites More sharing options...
