Chris Covington Posted May 20, 2013 Share Posted May 20, 2013 Just finished this candle holder that Lyle Wynn was so gracious to show me how to make. Seems to be a hit on my facebook page so looks like Im going to be making quite a few more! Quote Link to comment Share on other sites More sharing options...
Grant Posted May 20, 2013 Share Posted May 20, 2013 good morning all trauma -The candle holder is very elegant. It seem to be about 2 and ½ wine bottles high; where was is designed to sit? -grant Quote Link to comment Share on other sites More sharing options...
Chris Covington Posted May 20, 2013 Author Share Posted May 20, 2013 right now its sitting on a curio cabinent in our living room. I have had people say they want them to sit on their deck and other people want 3 with them each being a different size. Im going to try and make the next couple smaller Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 20, 2013 Share Posted May 20, 2013 Pretty slick, aught to be a salable item for sure. My only question is how stable is the bottle? It looks like it might swing like a bell and maybe break against the twisted stem say by being bumped or by a gust of wind. I think I have the inkling of a simple fix for swinging if it's a factor at all. All in all, I really like it, lots of possibilities. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Chris Covington Posted May 20, 2013 Author Share Posted May 20, 2013 it is stable. The only way the bottle moves is if you bump it Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 20, 2013 Share Posted May 20, 2013 Cool, looks like I need to pick up a bottle of wine. :D Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
yesteryearforge Posted May 20, 2013 Share Posted May 20, 2013 Thats a good idea but I wouldnt expect anything less from lyle and it looks like you did a good job with it Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted May 20, 2013 Share Posted May 20, 2013 Greetings Truma, Thank you for posting your neet candle holder.. Consider it put in my memory bank of things I want to make... Best overall design I have seen in a long time.. Forge on Jim Quote Link to comment Share on other sites More sharing options...
Marksnagel Posted May 21, 2013 Share Posted May 21, 2013 Thanks for posting the pic of the really cool candle holder. I think that there are several of us here that will attempt to duplicate yours. Just so happens that I have several bottles and a glass cutter laying around. Did you use a glass cutter or did you score it all the way around with a small file? This is surely on the to do list. Again, thank you. Mark <>< Quote Link to comment Share on other sites More sharing options...
Mudman Posted May 21, 2013 Share Posted May 21, 2013 That is VERY cool! Quote Link to comment Share on other sites More sharing options...
Chris Covington Posted May 21, 2013 Author Share Posted May 21, 2013 I scored the bottle with a scorer from home depot. Then on the advice of David Gaddis I heated some water in a kettle and alternated hot water and cold tap water over the scored line until the bottom just fell off. This method worked beautifully and only took about 3 rounds of hot then cold. Quote Link to comment Share on other sites More sharing options...
David Gaddis Posted May 21, 2013 Share Posted May 21, 2013 You are up on the internet waaayyy too late. Get to bed so you can cut on those eyeball while rested! And you project loos good as Lyle's. So now I guess we need to visit the patent office to see who owns what? Nooo Nevermind! Carry on Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 21, 2013 Share Posted May 21, 2013 I scored the bottle with a scorer from home depot. Then on the advice of David Gaddis I heated some water in a kettle and alternated hot water and cold tap water over the scored line until the bottom just fell off. This method worked beautifully and only took about 3 rounds of hot then cold. I hadn't heard of that technique. We used to wrap a single line of string around a bottle, put a little lighter fluid on it and light it. It'd break clean in a very short time, sometimes seconds, never more than maybe 30-40 seconds. An old friend used to let the string burn a bit, then cut it off and blow on the line. We would've gotten straighter breaks if we'd scored the bottles first but we didn't. We were making beer and wine glasses or would that be flutes? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Ironman50 Posted June 11, 2013 Share Posted June 11, 2013 That's classy and elegant looking candle holder. Great design especially the stand and the twist, very ornate. Well done! Quote Link to comment Share on other sites More sharing options...
Prokopto Posted September 19, 2013 Share Posted September 19, 2013 way cool! Quote Link to comment Share on other sites More sharing options...
2Tim215 Posted September 21, 2013 Share Posted September 21, 2013 Love it! Hope you don't mind if I give it a try. How do you cut the bottle? Quote Link to comment Share on other sites More sharing options...
JimsShip Posted September 23, 2013 Share Posted September 23, 2013 I bought a bottle cutting kit to make a similar candle holder I saw on here once, and most are made to cut the tops off bottles for glasses and not the bottoms, but with a little practice, it does work. (You can find the kits on amazon) You really need an even score all the way around for the hot/cold water tick to work. (and when it does it's awesome, but when it doesn't there's great sadness!) someone here posted they used a red hot heated ring to heat the bottle, and then dump it in the quench tub to pop the bottom off, but this method has never worked for me. Quote Link to comment Share on other sites More sharing options...
