My First Spoon
JJordan
So this is my first spoon. All advice on form and function is welcome. I am looking for some feedback also on what to tell someone if they wish to use it as it was intended to . Basically how would a someone care for it in their home. how to prevent rust and the sort. if it was a show piece then I would recommend the usually like bees wax etc... But for a spoon what would you do? I know there are food grade oils for cutting boards and counter tops, would these work on bare steel? any Feedback would be good. thanks in advance.
Would like t thank crossed heart forge for the idea I tried t make it my own.
post-22671-0-87333800-1352085000_thumb.j
post-22671-0-79654300-1352085004_thumb.j
post-22671-0-09839000-1352085008_thumb.j
post-22671-0-37192000-1352085012_thumb.j
post-22671-0-79741200-1352085015_thumb.j
Ayup, nice piece of spoonishness. Season like cast iron, or apply paraffin wax or spray Olive oil Pam hot. The down side to using Pam is olive oil takes a little time to cure so it may be tacky for a while. Done at the right heat and it cures fairly quickly but it IS a spray so it'll get around. Maybe just olive oil on a paper towel is a better choice.
I like to cure toasting forks by toasting something tasty like bacon. Mmmmmmm, bacon.
JJ, just use it in the kitchen. If it's something that only gets brought out once in a while then rub a bit of cooking oil over it and give it a wash in hot soapy water before use. If it get's regular use, don't bother as cooking oils and natural fats in the food you stir/serve will preserve the metal. I have a spoon I made from coil spring that hangs from a ladder in our kitchen and hardly ever gets used anymore. It doesn't rust and we live in the semi-tropics
  • 4 months later...
  • 2 weeks later...
