mechanicsage Posted September 25, 2012 Share Posted September 25, 2012 Hey guys, I just bought myself a new anvil for $250, the other day and I'm trying to identify and age the anvil. some pics below. Sorry for the bad lighting, took these pictures at night. thanks guys any help is appreciated. Quote Link to comment Share on other sites More sharing options...
Black Frog Posted September 25, 2012 Share Posted September 25, 2012 Any closeup of the side in the 5th picture? Flats on the base are associated with Peter Wrights.... Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted September 25, 2012 Share Posted September 25, 2012 No numbers, eh? Are those shelf-like steps on the base under horn and heel? Peter Wright did that, but otherwise, your anvil doesn't have a PW appearing base. It might be a Swedish make, as I have seen one Kohlswa with the steps. I'll go out on a limb. I don't think that it is a Hay-Budden because of the way the horn joins the waist. So there! I don't know. Quote Link to comment Share on other sites More sharing options...
mechanicsage Posted September 25, 2012 Author Share Posted September 25, 2012 the steps are under the horn and heel, yeah, I can make out a 305 on the side of the anvil i assume this is the hundred weights measurement, 305 = 341 pounds as i stated above. p.s i used an industrial scale to measure the weight of the anvil before hand. Quote Link to comment Share on other sites More sharing options...
MOblacksmith0530 Posted September 26, 2012 Share Posted September 26, 2012 That is a horribly ugly anvil and you shouldn't have it in your shop ship it to me and I will hide it for you..... Seriously though I don't know what it is but it resembles english pattern anvils and I know that is no help. Quote Link to comment Share on other sites More sharing options...
mechanicsage Posted September 26, 2012 Author Share Posted September 26, 2012 I got the grinder and polishing piece out this morning and gave the whole anvil a good polishing up, especially the side where the 3 0 5 were punched in and have uncovered some markings however I cant make any sense of them, :( thanks guys for your responses :) Quote Link to comment Share on other sites More sharing options...
Farmall Posted September 26, 2012 Share Posted September 26, 2012 It does look like a PW and I believe I can make out most of the words "Solid Wrought" in a circle around where the "O" is stamped Quote Link to comment Share on other sites More sharing options...
Frozenforge Posted September 26, 2012 Share Posted September 26, 2012 You can kinda make out where it says PATENT then below that ENGLAND and the SOLID WROUGHT in a circle around the center number. That would, according to AIA, place it being made after 1910. 341lb for $250 bucks! Nice. Quote Link to comment Share on other sites More sharing options...
mechanicsage Posted September 26, 2012 Author Share Posted September 26, 2012 What does that mean its made of ? Steel face iron body just iron or just steel Quote Link to comment Share on other sites More sharing options...
macbruce Posted September 26, 2012 Share Posted September 26, 2012 Yeah, PW....I can make out ATE (pATEnt)a few inches above the 305..... Quote Link to comment Share on other sites More sharing options...
Fatfudd Posted September 26, 2012 Share Posted September 26, 2012 It would be a wrought iron body with a steel face plate, They are good anvils and yours looks to be very nice. Quote Link to comment Share on other sites More sharing options...
Jeff Lodge Posted September 26, 2012 Share Posted September 26, 2012 You can see where it says Solid Wrought around the middle number. Like Macbruce says it's a Peter Wright. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 27, 2012 Share Posted September 27, 2012 You can tell from that chipped edge that it has a steel plate---and how thick it still is. Quote Link to comment Share on other sites More sharing options...
Loneforge Posted September 27, 2012 Share Posted September 27, 2012 Our PW has the same circular Solid Wrought stamping as this. And the same numbering pattern for the weight. I think it's a PW too! Quote Link to comment Share on other sites More sharing options...
