ciladog Posted February 15, 2012 Posted February 15, 2012 I made a video of how I make a ram's head for a poker. Enjoy. Quote
bigfootnampa Posted February 15, 2012 Posted February 15, 2012 One thing I noticed was that your coal was dry... if you wet it you'll find that you have a better fire and get more work out of your coal. The dusty fines will coke into nice chunks instead of sifting through your clinker breaker. Quote
Marksnagel Posted February 15, 2012 Posted February 15, 2012 Thanks so much for the tutorial video. It answers a lot of questions. Mark <>< Quote
Private Entrance Posted February 15, 2012 Posted February 15, 2012 Almost makes it look simple. Thanks for the video! Quote
doc Posted February 15, 2012 Posted February 15, 2012 Great tutorial !! I like how you show making the inertia bend. Quote
ciladog Posted February 16, 2012 Author Posted February 16, 2012 Thanks to all. Great tutorial !! I like how you show making the inertia bend. It seems counterintuitive but it is the best way to make that bend, at least for me it is. Quote
beth Posted February 18, 2012 Posted February 18, 2012 thanks ciladog great tutorial - i love to watch videos, so much easier to learn from. i made one of these years ago, and never have since - but i should - and oddly with all my stressing about forge welding, that first one was absolutley beautiful.... i love you way of doing that bend - i could use that alot, am always finding myself with difficult access when bending things, i will undoubtedly use your technique - cheers :)! Quote
Cross Pein Posted February 18, 2012 Posted February 18, 2012 Thanks Ciladog Great head, learned a lot. Quote
34557564 Posted February 18, 2012 Posted February 18, 2012 Great tutorial, I have got to try that one day. That's 1/2" square, right? Quote
Jeff Seelye Posted February 19, 2012 Posted February 19, 2012 Great job on the poker! Also a great video, Ciladog, you are multi talented! Quote
ciladog Posted February 19, 2012 Author Posted February 19, 2012 Thank you all for the kind words. I have made these ram's heads out of stock as small as 1/4" round and as large as 1 1/4 square. In the attached images the small head was made from 1/4 round (that is a 5/16 nut holding it up) and large head was made from 1 inch square. The one in the video was made from 1/2 inch square. Quote
seldom (dick renker) Posted February 19, 2012 Posted February 19, 2012 Nice work. I am very envious. Quote
windancer Posted February 20, 2012 Posted February 20, 2012 Thank you for taking the time to make and edit this tutorial and sharing your hard-earned experience. I book marked it! Dave Quote
metalmangeler Posted February 20, 2012 Posted February 20, 2012 Ciladog thank you for your post I tried to post some pictures of more power hammer options to speed up the process, my last attemp failed so I won't bother with so much written info on this one. Hopefully the pictues if they work will be self explanitory. I use 2 hammers which helps to get more done in each heat. Wild sheep have short upright faces. I use a wedge to taper the horns as the first step. then a double swedge to start divideing the horns the example is poorly done. I bend my face without cutting or welding and try to keep the face short. and narrow nose Then I use a face swedge, this needs to be made for each size stock that will be used, it is just a well made face driven into a hot block. I texture my horns with a set chisle only I swing it as this speeds up the process, it is not as exact as what you are doing though In addition to the scrolling tongs I use some tongs that reach across the curl of the horn to help close straight sections. I do this out of the gas forge rather than with a torch. Quote
Backwoods Blacksmith Posted February 21, 2012 Posted February 21, 2012 Very nicly done. thank you so much. Quote
Ferrous Beuler Posted February 21, 2012 Posted February 21, 2012 Very nice work ciladog! Your smithing is well rendered but you also deserve kudos for such a good job using a video camera in the shop, your video efforts turned out a high quality result. Very well done. Great job editing too, BTW. Quote
ciladog Posted February 21, 2012 Author Posted February 21, 2012 Metallmangeler, Thanks for posting the way you do it. I will give some of your methods on the power hammer a try. It's always good to learn new ways to get it done. Quote
ciladog Posted February 21, 2012 Author Posted February 21, 2012 Very nice work ciladog! Your smithing is well rendered but you also deserve kudos for such a good job using a video camera in the shop, your video efforts turned out a high quality result. Very well done. Great job editing too, BTW. Ferrous, thank you for the compliment. Quote
Randy Posted February 21, 2012 Posted February 21, 2012 Nice job! Amazing what can be done with a ram's head. I've done a lot with twisted horns. One twisted one way the other the opposite. You were talking about ones in 1/4" stock, check these out. They were done by Deloy Larson of Utah. He passed away this past November, but look what he was capable of! Yea, the one is on the end of a welding rod, without breaking off the flux! Amazing! Quote
beth Posted February 21, 2012 Posted February 21, 2012 wow thats incredible!! respect to you Deloy wherever you now may be, beautiful :) Quote
ciladog Posted February 21, 2012 Author Posted February 21, 2012 Those small heads are indeed incredible. I will have to try that on a welding rod but first I have to get 20X lense for my magnifier. Quote
ciladog Posted February 23, 2012 Author Posted February 23, 2012 Well Randy, I went into the forge this morning and gave it a try. I have a new respect for Mr. Larson. This is not an easy thing to do mainly because the forging is so small that the heat dissipates in an instant. I'm happy with the way it turned out for a first try at it. The flux did break off as the process went on. But all in all, I think it is an OK attempt. I made a video of the attempt, enjoy. Quote
