monty Posted July 27, 2011 Share Posted July 27, 2011 i wasnt sure if this was the right place for this, but i recently bought "copper earthing rod" only to find out it is only copper plated steel,5/8", is there anything i cand do with this? thanks monty Quote Link to comment Share on other sites More sharing options...
edge9001 Posted July 28, 2011 Share Posted July 28, 2011 drive it into the ground and hook the ground connection of your house or shop to it Quote Link to comment Share on other sites More sharing options...
bigfootnampa Posted July 28, 2011 Share Posted July 28, 2011 I've been told that the softer copper will move so much easier than the steel that they are likely to separate while being forged... I've not tried it personally. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted July 28, 2011 Share Posted July 28, 2011 that is normal and standard for grounding rods. Quote Link to comment Share on other sites More sharing options...
jeremy k Posted July 28, 2011 Share Posted July 28, 2011 What was your purpous for the initial purchase? The steel or copper? Quote Link to comment Share on other sites More sharing options...
pkrankow Posted July 28, 2011 Share Posted July 28, 2011 Those make good stakes as is for garden stuff. Socket the decoration and put it on top. Phil Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 28, 2011 Share Posted July 28, 2011 1: can you return it for $$ or credit? 2: If not can you work it into projects as a piece that doesn't get forged? Quote Link to comment Share on other sites More sharing options...
Bentiron1946 Posted July 28, 2011 Share Posted July 28, 2011 Been there and tried to forge one very early on and decided to forget it. They are good for one thing and that is as intended, a ground rod. <_< Quote Link to comment Share on other sites More sharing options...
monty Posted July 29, 2011 Author Share Posted July 29, 2011 i got it for the copper thanks for input i think i will follow your advise phil and ThomasPowers, thanks Quote Link to comment Share on other sites More sharing options...
pkrankow Posted July 29, 2011 Share Posted July 29, 2011 I got fooled cleaning out my aunt's garage once. I thought I had 500# of copper ground cable in the truck, and went to recycle, as the garage was falling down. Well, it was copper plated steel, 500# of it. I didn't believe the guy till he stuck a magnet to it and handed me a file! That was disappointing, I only got paid the recycling to tear the garage down (and had to return my parent's truck with a full tank too) After hauling 4 trips of steel, I PULLED the garage down with a chain in one go. I think I cleared $200 or so. Phil Quote Link to comment Share on other sites More sharing options...
