August 11, 201015 yr Hi, all. Just had to have the rotors replaced on my front brakes. I asked them to save the old ones for me and now have a pair. Anything useful to do with them? What are they made of? They are from a Prius. Thanks! Eric
August 11, 201015 yr Eric, They're most likely made of cast iron. Being that they are from Prius they're probably not big enough for fire pots. But you can use them to make stock stands to hold long material being forged,or heated in a forge. Larry
August 11, 201015 yr How many lug bolt holes are in the rotor? It can be used as a lay-out tool. Insert the lug bolts and it can be used as a bender. There is always the use as feet for stock stands etc. You may want to nest a couple together to make up the weight needed for some projects. There are all manner of uses and possibilities. (grin)
August 13, 201015 yr Author How many lug bolt holes are in the rotor? It can be used as a lay-out tool. Insert the lug bolts and it can be used as a bender. There is always the use as feet for stock stands etc. You may want to nest a couple together to make up the weight needed for some projects. There are all manner of uses and possibilities. (grin) Glenn, 5 lugs holes, also each has 2 smaller holes about 1/4" diameter. The hub/axle hole is about 2 1/4" diameter.
August 13, 201015 yr three of them laied out in triangle and welded together make a very stable base for a stand
August 13, 201015 yr Author three of them laied out in triangle and welded together make a very stable base for a stand Rats! Only had the front brakes done! :P
August 13, 201015 yr I used to use them individually as bases for my small to medium sized sculptures. I don't think they are cast iron but some kind of forged steel. <_<
August 14, 201015 yr I used to use them individually as bases for my small to medium sized sculptures. I don't think they are cast iron but some kind of forged steel. Don't know about prius but the 6 my better half picked at the scrap yard are all cast iron. Tried one as a base for a dishing stand(bottom of a OX tank) popped right off. Now designated yard art bases. Ken.
August 14, 201015 yr Yep, cast iron to take the heat and resist warping. Bolt together for projects. Are they vented, or solid rotors?
August 14, 201015 yr Author Yep, cast iron to take the heat and resist warping. Bolt together for projects. Are they vented, or solid rotors? I'm guessing venting (not experienced with this stuff) - They have square cross-sectioned channels running from the edges in toward the center. Not sure how far they go in. Would that be vented? If nothing else it increases the surface area to help radiate the heat.
August 14, 201015 yr Yeap that's a "vented rotor" the square channels reduce the weight, radiate heat and move air like a fan. "unsprung weight" or weight below the springs is detimental to the ride quality of a car. Of corse lighter cars get beter milage and have lower material costs. As to material, some are cast steal, some cast iron and others forged. Depends on what the engineers thought sous get the job done for the least weight and cost.. Sorry, the exmechanic is coming out.
August 14, 201015 yr Which vehicles used cast steel, or forged rotors? Every one that I have ever seen has been cast iron. I deal mostly with American makes,older classic cars, and trucks.
August 14, 201015 yr I've Ben out of the industry for 15 years.most of the asian non vented rotors I delt with as well as some utopian models such as BMW and volkswagon use cast steal. Some oventhe high end stuffmuse aluminum break hats with steal disks.
