Contest - Design an anvil stand
from the "Blacksmith's Cook Book" page 8. This is a great little book to add to your want list if you don't have it. ;)
1329.attach
  • 1 month later...
  • Replies 61
  • Views 18.5k
Okay, it's January 2, 2007......how do we submit/publish, etc our entries for comparison or consideration or just general viewing by the collective audience?
Use the "contact" from the opening page of the IForgeIron site to request specifics as to size and format, or send the information to me by email.
Hey Frog
Just wondering If you tried the anvil stand? Does it have a good rebound?
I use the fork lift tine anvil stand all the time. The anvil has the same rebound as before, it's just moveable now that it is on wheels. The whole rig weighs more than 500 lbs.
  • 1 month later...
Just so it doesn't get lost in the shuffle, was a decision ever reached?? :rolleyes:
The entries below are workable but appear to be unlike those in the next post.
Burying a stump (or log) has been used for years as mention in the posts.
Burying a Rail Road track rather than using it in a horizontal position is much more effective as all the mass is directly under the impact point of the hammer. A second piece of horizontal section nearby would be nice when a larger face was needed.
Buckets as stilts are interesting, but I can see a problem with uneven ground, tools junk etc on the floor, and falling off the buckets.
A good idea, but there may be some problems here with the bolts becoming loose and wallowing out the holes, making the adjustment difficult over time.
The sand in a barrel is a traditional method, easy to assemble, mobile and works well.
This is a very workable design. Easy to adjust and portable. Most likely this will be duplicated, or modified, and used in many ways.
Thibeau was thinking outside the box (referring to the box that is used to contain an anvil - and pun intended) with his design. It is adjustable, mobile within the shop, and breaks with the traditional thinking of what an anvil stand looks like. His use of unusual materials is refreshing.
The time for the contest has expired, I will declare these two designs the winners with the nod going to Thibeau for originality. The Thibeau design will be presented as a blueprint so you can look over the details of the design.
One type or size anvil stand will not fit everyone. This is a good subject for discussion. I would like to see it continue with additional postings, ideas, and designs.
And to the winner of any future contests, we have this beautiful work of art as an award to strive for, courtesy of the Institute for Advanced Rube Goldberg Studies at the Dancing Frog Forge....:D
1895.attach
1896.attach
1897.attach
1898.attach
  • 9 months later...
This is to late for the contest but I thought I'd share anyway.:)
This spring I will need several anvils/stands for the local 4H members to learn and practice on. The age and hieght of the members vary alot. In planning the needed stands I started out looking through I forge Iron and the books I have on the shelf at home. I also thought of the stand I used at John C. Campbell. What I ended up with was a cross between Mark Aspery's stand in his book "The Skills of a Blacksmith Volume 1" and the John C. Campbell stands.
The legs and table are 2"x2" heavywall pipe cut at 20 degree angles with 4"x4"x1/4" pads. The sides are 2"x2"x1/8" angle iron 6" long.
The adjustment is done with 6 boards 3 - 1 1/2" thick 1 - 3/4" thick and 2 - 1/2" thick.
With the anvil sitting on the bare table the floor to anvil face height is 26" even. with all the boards sitting in the frame the floor to anvil face height is 32". My two shop anvils are both at 29 1/2" so I thought this was a good spread.
The chain around the anvil waist is welded and so are the two chain drops. There is a hook on one side for the one chain to hook into and a bolt/hook on the other side to hook the chain and tighten the anvil down to the stand.
The hammer/hardy racks are made from 3/8" square.
As always the design was based around what I had in the resource pile.
I made a couple of drive hooks just to try it out and it seems to be very stable.
If you would like a BP I have 2 more to make and will work one up while I make them.
John
4676.attach
4677.attach
4678.attach
4679.attach
4680.attach
4681.attach
4682.attach
4683.attach
  • 2 weeks later...
I just found this site and I've been resurecting my shop the last couple of months.While cleaning up I realized I needed to be able to move my anvil easily because the space is multi purpose.So her is what I came up with.
I made a little pocket for a crow bar to fit in, to lift the stand and insert the wheels, roll around the shop and lift to remove the wheels.
It's not finished yet, still need to anchor it to stand and make hardie, tong and hammer holders.
5034.attach
5035.attach
5036.attach
5037.attach
  • 2 weeks later...
Thanks A-Man
  • 4 months later...
Hey mark,
i`am thinking about using your design on your satnd for a #250 anvil i got (possibly a jet ) and wanna make a stand for it that I can move around but was wondering with a 250# anvil on it how would i take the wheels off? (it be moved around in my shop , going use it when I have a striker) I really like the design Thanks,Chris
Hi Chris
The crow bar will lift the stand with the 236# anvil thats on it with not much effort. I just lift till the wheels clear the concrete and slide them out, then slowly let it down, then move to opposite side and repeat. I had the chain and hoist on it in the pics for safety as that was the first time I lifted with the crow bar.
Hope this answers your ? I'll take some pics of the pocket for crow bar or any part you would like a better look at.
Mark
Thanks Mark! I sorta wondered about that ! I`am good on pictures , I `ll keep uns informed once I start the stand
I took some more pics (i love pictures) here's one , more in the gallery.
Looking forward to seeing your build and flattered that you're using my idea although i'm sure someone did it before me.
I use a similar method to move my power hammer (heaven forbid) Pics show during construction. It looks like the wheel is bolted on but its just a pin in a holes that are drilled in the rear corners of the base plate. I have a "dolly" that levers the front on the angle plate shown in the pic with the anvil and mast mounted. The dolly pivots so I can steer the machine while moving. Wheels are solid cut from 2.5" round stock. Sorry, I don't have a pic of the dolly
6794.attach
6795.attach
Edited by Dodge
Nice set-up Dodge, is your dolly simmilar to a johnson bar?
Mark,
I'm not familiar with that term but picture a pry bar with wheels. Thats sort of what my dolly is. It has a locater pin that matches the hole in the front angle plate and pivots on that pin. I will try to get a picture to post here soon ;)
Scott
I'm sure you've seen or used one of these probably by another name, sounds like yours has a pin instead of a flat blade.
Yes. Mine is very similar to that except the for mentioned pin. On the picture, it would be on or in place of the flat plate :)
