Soldering copper attractively?
Hey Folks,
I'm just wondering whether there are solders out there that are copper colored. If I want to solder together a few ornamental copper pieces, is there any way do do it such that the solder doesn't stick out like a big silver thumb, or is that the way of things?
thanks in advance,
Archi
I used fauscopper (sp) from welding supply
it takes a patena just like copper
comes in flat sticks
need oxy torch to melt
Look at stained glass suppliers they sell a solder for doing the copper foil work rather than the lead cames.
Phos-copper/copper-phos = phosphorous copper solder is used for refrigeration lines, and has a copper color which would work good for your application.
Thomas, My wife has a stained glass studio and teaches classes. The solder used on both copper foil and lead came
is 60/40. The copper foil joints are silver colored or patineaed black.
Ken.
You can use copper patina on tin/lead solder.
Like this. http://www.amazon.com/Super-Brite-Copper-Patina-Solder/dp/B000N64PDE
I've used it on stained glass work. It leaves a thin copper plating on the solder.
  • 2 weeks later...
I have seen this on stained glass work that my mother-in-law did and the results were impressive.
