3,622 -
Everything posted by TWISTEDWILLOW
Floor options for shed wooden floor
TWISTEDWILLOW replied to MarriedWithAnvils's topic in Building, Designing a Shop
I agree with everyone that else that the wood floor is safe to use but on the other hand If you are worried about having a thief motivated enough to steal a anvil and stand that weighs 500 pounds personally I don’t think your shed doors would stop them if they want it that bad. Frosty brings up an excellent point of exposure working inside with a propane forge and Thomas brings up a good point on needing something stable under your anvil stand. If your really worried about theft then my suggestion is Build the lean to off the side and pour a concrete slab and anchor your stand to the slab or maybe wrap a chain around the anvil and anchor the chain to the slab. it seems to me that would be a cheap, safe and effective solution to your problem. You can get reclaimed lumber for next to nothing if not free if you look around and if you make friends with a concrete truck driver in your area I’ll bet they will swing by and pour project leftovers for you (trust me I’ve tried and it works) and sheet metal like the lumber can usually be had cheap or free from projects or tear downs. You could double the size of your work area for next to nothing and be safe from fumes, theft, have your anvil on a stable surface and not worry about catching the floor on fire. -
what about getting a welders blanket at harbor freight and nailing it down like carpet and set up your anvil and forge on it? For that matter you could put it on the walls around you hot work area. -
Howdy from the Great State of Texas!
TWISTEDWILLOW replied to Wyatt Flora's topic in Introduce Yourself
Howdy from Oklahoma -
Could you use the inside of the the shed for power tools and machines you have and use it for finishing work and then build a lean to off the side of the building to set up your forge and do all your hot work under the lean to? -
I’ve got a vise vice and I’ve dragged home quite a few but I’ve never come across anything like that one it’s pretty cool, curious how wide are the jaws? Sorry I’m like frosty I can’t help with info either on the vise or cart but they are both really sweet finds.
Doing more research in my area I found where a cable suspension bridge used to pass over the baron fork creek almost a century ago. No real way to tell if this vise was used for that project but that’s the only cable bridge I can find that was around around here. We have some 100 year old bridges still standing an in use but they aren’t cable.
TWISTEDWILLOW replied to jlpservicesinc's topic in Building, Designing a Shop
Glad to hear you got your problem figured out and was able to bring it back online -
Mouse Hole Forge Anvil ID
TWISTEDWILLOW replied to Shane V's topic in Anvils, Swage Blocks, and Mandrels
That’s a nice find Shane -
What I found interesting is that his company was involved In everything from several famous bridges to military equipment to Lindbergh’s plane!
Lol that’s a good idea frosty, Thomas don’t worry I keep up to date on my tetanus shots because every were I go I’m digging through junk piles, billy and pnut it’s not that I actually buy pbr on the regular it was just the cheapest beer I could find that day lol.
It’s a really neat project and I hope you find your wiring issues without to much trouble or frozen fingers, I can’t wait to see your machine up and running again! You already got wheels turning in my mind about making something like that for my shop. -
Show me your anvil stands
TWISTEDWILLOW replied to pkrankow's topic in Stands for Anvils, Swage Blocks, etc
That looks really nice! -
I’m not an electrician or a hvac guy but Im wondering What if you returned the wiring back to its original set up when it was working and see if it does work agin then put your kill switch on the supply line? Also does it have any thermistors, thermocouples or fuses that might have blown like on a dryer? I know a dryer motor will still spin but if one of those things blows then the dryer won’t heat. If it does have one of those you could test them with your multimeter set on ohms and rule them out as a problem. Sorry I’m not much help. -
That’s a pretty cool heater, now I want one! -
Here’s another one of my junkyard finds, i guesstimate it to be 175 to 200 pounds but my wife has banned me from using her bathroom scale to weigh dirty rusty junk I drag home so I’ll have to get a weight later for it. The searching I’ve done so far has led me to it being a wire rope eye splicing vise. The company that made it turned out to have a pretty interesting history but I was unable to find any info on when it was made. It has three jaws and two move at the same time. I haven’t found a use for this thing yet but it was weird and I didn’t already have one so of course I needed it.
Andrew, If you can’t mount it permanently maybe you could find a piece of plate and mount it to that to help keep it from spreading out like Jennifer suggested. You could drill and tap the holes and put the bolts in from the top so it will set flush. you could still have it mobile that way and maybe take some of the stress off. I think everyone here is just worried about the cast iron failing and dropping and anvil on your foot. -
My vote is also cast iron I’ve got an old cream separator out in my junk pile with a stand similar to that one and i believe mine is cast iron. Neat old stand I just haven’t figured out what to use mine for yet. -
My Silver drill press.
TWISTEDWILLOW replied to Jim Foster's topic in Drills, Post drills, Mag drills, etc
that’s a nice silver! I’ve found two just like yours but they were both missing parts or had broken parts and neither looks as nice as yours. I’ve still got one rigged up in the shop that I use but it’s not near as complete as that one. -
If you get it I’d be really interested to hear if it is a green river foot vise. I’ve been hunting for one for several years now but when I find them they are either to far away for me to get them or they are higher than I I wanna pay. So I just keep hunting I figure one day one will turn up we’re I least expect it. Did you get the swage block that’s setting buy the fire pot? Also that cone looks really sweet how tall is it and what’s the top and bottom diameters? Sorry for all the questions I get excited when I see a pile of old rusty tools.
I zoomed in and got a screen shot of it. It really looks like the top end of a foot vise but I could be wrong. Thank you for the info on the shops out west of me I’ve got some kin out their that may know something I’ll sniff around and see if anyone has ever heard of what happened that stuff at tinker. Are those post drills champions?
And here I thought I was dragging home lots of rusty gold. Looks like you hit the mother load in one trip. I’ve filled up my truck a time or two but I never found that much stuff in one place at one time or if I did I couldn’t swing it money wise. I seen lots of goodies when I zoomed in the pictures but one thing caught my eye in your fist picture left side middle is that a green river foot vise that I spy or are my eyes deceiving me?
Wow that’s a cool story and it kinda makes me wonder every time I here about something like that, how many old warehouses, closed down hardware stores, barns and surplus sites still have vintage tools and machines new In the box that have been forgotten and looked over for decades. This is why I like exploring and following stories and leads sometimes it’s nothing but waste of time and gas and sometimes there’s a goldmine of forgotten history setting in the back of a dusty old building. Here’s some pictures of a couple of things I dragged out of that salvage yard before it closed.
Thank you Steve, i thought it was cool that it still had the matching base with it when I found it because most of these grinders I’ve seen don’t have a base with them. Thomas those are really cool I saw one built like your larger one in a local salvage yard, they had it in the shop hooked up to a 5hp electric motor and they had changed it over to run on modern vbelts. It’s nice to see yours both still have the original flat belt pulleys. The salvage yard went out of business and I was late to the auction so I wasn’t able to save a lot of the old tools and machines that were there. They had been open since the early 1940s and I loved going there because you could find almost anything.
