Indian Fly Presses
I have them in my fabrication workshop since father's time. and they are pretty good for my fabrication work that is straightening, bending, sheet metal fabrication works, etc. I have seen many of them around me. if you would like i can send photos of my press
Aditya B changed their profile photo
Convert small fly press to motorized or foot operation?
well as far as my experience and knowledge goes these are not the type of presses which goes mechanized by power. between you have shot for applying working principle of forging screw presses but i dont think that will go work on such small level effectively. still the flywheel which you are using is creating the inertia for your working i will definitely never suggest someone to do this, 1. too much hectic 2. you will need geared motor (costly stuff and finding one in junk yard is next to impossible) 3. you will need custom built bevel gear (another costly stuff) 4. there are maybe chances of loosing power rating so all and all i would never try to modify instead try another hydraulic press hope this will help you
Blademithing series on History channel
perfectly said as far as my opinion concerned a bend and broken both are failure and as this week was concerned Illya was a certain winner for shield making. I watched his videos over man at arms as compared to them his knife came out under expected.
- Homemade Air Blower WIP
Touchmark/Makers Mark stamps?
Yes H13 is quite good
so far so busy these days but i managed to have some progress i managed to put fabricate housing with a elbo as i do have a bottom blast except elbo all other parts are coming from my scrap there is a flow control which is just been in design and i have used it first time will provide more detail about it when it will work but for info when you move this hex head this will change amount of air out And for all the balancing Fans Yess!! my fan is already is pretty much balanced and didnt gave any kind of balancing problem in my test run!! And thus it is proved that you can make your own fan in welding workshop
1. these welds what you saw here are just tac weld i am going to full weld those from both sides 2. as far is welding on speed rotation considered i have seen many of my welded job turning on high speed and taking deep cuts and welds always worked fine 3. when the backing comes in play the back or housing which you are viewing right now is going to weld on one metal structure which will going to hold motor and housing both 4. i am still searching for appropriate squirrel cage/ fan blade in market but i am not getting one. i havent thought about handcrank i need to reduce human efforts but i am going to put valve or damper in between blower and forge to control the flow
After blowing up 2 chinese air blowers on first runs I have decided to make my own air blower (hoping good use of my old 0.5hp motor ) Specification Power - 0.5 hp / 1440rpm Dia of Housing - 10 inch Dia of fan - 8 inch Width of fan - 25 mm Out Vent Dia - 1 inch Right now Mounting Shaft is gone to friends shop for internal key way hope it will do my work will keep all informed when it will perform
- Mechanical Crest
