Everything posted by angiolino
yatagan/Kukri knife
thanks for the right suggestions, unfortunately I live in the suburbs, you understand that I can't emit combustion fumes, my neighbors, too close to each other, would complain or worse, they would report me to the authorities in charge. , first I went to my uncle who had a mechanical workshop, around me parts of the blacksmiths no longer use the classic coal forge even with gas, now they buy the iron bars and the elements already forged and stamped by the factory, segmantano the they assemble and weld, from blacksmiths they have evolved into welders, they don't even have a blowtorch flame, I have to find an ingenious DIY solution that is home-made and safe and cheap to manage. thanks anyway for the right suggestions. I have to investigate heat treatments, temper annealing, nitriding cementation. Thanks again
yatagan/Kukri knife
thanks for the valuable advice. I have a modest equipment, like steel I use the elliptical sheets of old truck springs, I don't have a forge I have to find a way to make up for it with foirtuna equipment thanks again sorry for the trouble, thank you ..
yatagan/Kukri knife
I did not use the ax with the iron pipe as time passes, I use the one with the yellow handle and the machete to clean the garden of shrubs from bushes that form spontaneously. I had to interrupt the construction of blades. before I went to my uncle who had a machine shop with machine tools and equipment, since he died and the workshop is closed I built a small workshop in my house, but I don't have the comforts of a mechanical workshop. I have a banquet and some tools, so the results are modest. I can't shoot the blades on the anvil. I just cut out the shapes of the blades on sheet metal cuttings and then sharpen and polish them. therefore the result is modest. thanks for the right suggestions
yatagan/Kukri knife
disappointed, right? I'm a real landslide an amateur I have a lot to learn, do I hope to become a master knife maker knife sharpener? in a few centuries maybe and after so much elbow grease fatigue and sweat ... let me know where I'm wrong, thanks, I'm a real recruit, no doubt about it?
yatagan/Kukri knife
I tried to make a machete with a crossbow sheet truck it is very rudimentary and rustic I use it to clean up the soil from the bushy bushes shrubs. I can't make the ergonomic handle ... thanks anyway
yatagan/Kukri knife
hello I would like to try my hand at building a knife. I thought of a kukri I think originally from Nepal or a Yatagan, of Russian origin I think, you would kindly have pictures or drawings, what material do you advise me to use, have some friend friends built these specimens? I just a few rudimentary machetes. if I can I would like to make a big bowie knife later, which they tell me is an indestructible knife. thanks
advice help build in-store mezzanine in inexpensive metal
the whole place is 3.70 meters, calculates that I am 180 cm tall therefore, the walls are weak, I would like to find simple robust and cheap materials, maybe scaffolding pipes, what do you say how would you do spending a little money, but realizing a robust structure ? thanks for your opinion http://minamishika.com/tubi-innocenti-bricoman.html
hello I should make an internal mezzanine in my shop, I have two parallel brick walls I would like to place on it the beams on which to apply the platform. wall dimensions: a wall is 2.20 meters long, 1.95 meters high and 30 centimeters wall thickness the second wall is 1.85 meters high and 18 centimeters thick, the distance between the walls or width is 2.50 meters, as I realize that I use material, that load and capacity I could load on it thanks ...
welding cart homemade
thanks for your advice I found 80 cm x 40 cm boards you think it is enough L-shaped iron from 30 mm height 90 cm from the ground 3 shelves. Required Materials 1/8" standard steel angle iron (sizes chosen to accommodate 4-foot lengths angle iron is available in): Four 1/8" x 1" x 1" - 18" in length mitered at 45 degrees Four 1/8" x 1" x 1" - 30" in length mitered at 45 degrees Four 1/8" x 1-1/4" x 1-1/4" - 36" in length (legs) Two 1/8" thick mild steel plates measuring 17-1/2" x 29-1/2" Four casters with threaded shafts and matching nuts Four coupler nuts used to fasten threaded rod together Four lock washers to fit caster shafts One steel tubing 3" in length, 1-1/4" inside diameter Materials List 1-1/4″ x 1-1/4″ x 1/8″ x 10′ angle iron (3) 32″ x 20″ x 1/8″ sheet metal (2) 1-1/2″ x 1/8″ x 4″ round tube (1) 4″ x 130-lb.-rated caster with brake (4) 7/16″ non-zinc or galvanized nuts, fit to casters (4)
welding cart hello, I should make a small table with ruoote to put on a synergic welder the measures are 170x 320x 400 mm the weight six kg should be at least 80/90 centimeters high from the ground with all the wheels, I would like to create a welder trolley on which to make even shelves like shelves to keep the welding machine, the mask the cables the electrode packs and all the necessary equipment, some economic and aesthetically pleasing ideas to lose little time and little money thanks Commercial link removed.
DIY forge building board
I should add the bellows, thanks for everything, if maybe you would do me the favor of attaching some image you would do me a great favor, thanks again, sorry if I disturbed you thanks
sorry could you be clearer, maybe with picture or drawing what should I do to make it usable? sorry if I have an insight, a picture is worth + 100 words thanks for your availability. maybe link me to a picture or similar discussion, thanks again, I'm sorry if I'm boring and repetitive
I made this brazier, what do you think about how I could refine it and perfect it to make it functional for the purpose?
hello I would like to build a homemade forge with recycled materials, I recycled the container of an old electric water heater, how do you advise me to make it? better to gas or to firewood type brazier. do I have both a gas torch to weld the tarry sheath and a large gas stove? do you need refractory bricks as you advise me to proceed? thanks
build a salmon ladder at home in iron tips
thank you sorry if I take advantage of your patience and your precious time thank you again, I'm too fussy and boring forgive me. The supporting structure is made of square iron boxes 40x40x3mm would it be enough to hold the load?
how would you do it? could you kindly attach some drawings with measurements,? thanks. hold bar bells? what would you say to me with a photo I don't go to gyms thanks
thank you for the valuable advice and clarifications, I evaluated everything and will try to take the right solution, my friend told me that he wanted to find an old scaffolding type scaffolding on which to build the power rack structure and fix the salmon ladder on it and others tools, like the pulley and also use it as a support for the barbell to lift weights on bench thanks, even if you had other ideas to draw inspiration from, I invite you to write thanks again htt
on the net I have seen some examples seemed scaffolding for construction site, of those homemade were almost all in wood, obviously it is not a structure for public gym but for an acquaintance of mine who has the hobby to train at home, I do not find the right design with the right reference measurements, if I make the hooks too far apart, I risk that when I hook the bar in the trimming phase, it does not grip and therefore you fall ruinously, I would like to know the right distance between the hook and the hook and the right distance between the hooks right proportions, we would like to do it in metal maybe tubular what do you think?I saw one that was attached to a structure called a power rack CYCLONE 100
hello a friend of mine would like me to build him a gym apparatus a salmon ladder, it is a metal structure on which a bar is hooked and a climb is made, repeatedly hooking the bar to the special support hooks, it would be used for training traction someone could suggest me how to build it and what material to use on the net there are photos without reference measures thanks
metal fence tips
metal fence tips
metal fence tips
honestly I only reclaimed the area where the fence was set up, I cut the bushes and weed the weeds, I made a couple of holes for the foundation plinths, but the ground is hard and stony, I have a lot of difficulty, if any user friend if you have any additional suggestions or suggestions, I invite you to participate, I have to hire a pickup truck to buy the material I need thanks
metal fence tips
even 100 km per hour, it is at the limit with the railroad, the railroad company does not take care of the maintenance of the area next to the tracks, bushes grow bushes reeds, the wind carries waste, wild animals and snakes nest. I would like to realize with metal tubes the frame on which to screw the corrugated sheets I plant fifty centimeters in the ground what do you recommend? http://www.cemensolai.com/cordoli2012/recinzioni-prodotti-266.html http://dogler78.org/let/ http://ixiqi.co/image
metal fence tips
metal fence tips should I build a metal fence like a construction site with corrugated sheets, I should make the poles and crossbars to screw them in, which material should I use? eleven meters long, 2 meters high, which materials I use which sections and how far away I put them, how deep I place the poles? the poles in t-section or in tubular hollow? thank you
canopy roof for metal car parking do it yourself constructive advice
it is a dwelling, you understand that it must have a minimum of aesthetic sense, otherwise my neighbors could report me to the local authorities for building abuse and break down the structure denounce me and make me a salty fine, however if some friend had photos or drawings with measures I invite him to write, thanks again for the valuable suggestions, thanks anywayhttps://5.imimg.com/data5/JR/MG/MY-6126577/car-parking-canopy-500x500.jpg https://www.picclickimg.com/d/l400/pict/123095153187_/Freestanding-carport-garden-canopy-hot-tub-cover.jpg https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQPh4TLlehPE0fSE7uqDJvKmUziilycTLC_R9LUfPhHKVM9CbI3Pw
