274 -
Everything posted by angiolino
I recommend small mobile crane on wheels for workshop
angiolino replied to angiolino's topic in Member Projects
thank you for your right suggestions, in my part this type of crane for workshop mechanic to extract engines from vehicles, they are commonly called: "goat or hydraulic capretta", do not ask why, but in Italian some cranes are called goats or bigo or crane in boating, thanks again for the right suggestions -
thank you for your valuable suggestions -
hello, for my small craft shop, I wanted to build a small crane on wheels, similar to those used by mechanics to extract the engines from vehicles, modest range say two tons, those with the arm, which are raised hydraulically with the piston, manual of course some economic and safe idea?
help construction digging homemade bar
angiolino replied to angiolino's topic in Blacksmithing, General Discussion
Me gustaría usar el sistema de fijación con pernos porque, en el lugar donde debo colocar la barrera, hay un terreno en un sitio remoto y estrecho sin electricidad, no tengo un generador de corriente eléctrica, utilizando el sistema de carpintería de metal y las mordazas atornilladas. Podría transportar los diversos elementos de ensamblaje con mi carro viejo, de lo contrario tendría que alquilar una camioneta con costos de transporte adicionales, la barra para la excavación que aún no me he dado cuenta, ya que en mi área hay un lugar perdido y no hay muchos recursos, alguna idea? gracias por las sugerencias correctas I would like to use the bolting system because, in the place where I have to place the barrier, there is a terrain in a remote and narrow place without electricity, I do not have an electric current generator, using the metal joinery system and the jaws screwed. I could transport the various elements of assembly with my old car, otherwise I would have to rent a truck with additional transportation costs, the bar for the excavation that I have not yet realized, since in my area there is a lost place and not There are many resources, any ideas? thanks for the correct suggestions https://www.cantierepro.com/ponteggio-tubi-e-giunti-tubi-innocenti.html https://simplifiedsafety.co.uk/guardrails https://www.totalsitesupplies.co.nz/product/buy/shisham-burke-bar/ -
thanks for the right suggestions, I should create a hinged hinge and a right jumper, a friend of mine suggested me to use metal pipes for metallic carpentry like those used to make temporary scaffolding on construction sites that you think? thanks again for the right suggestions http://www.layher.it/cataloghi/Catalogo-accessori_tablet.pdf -
thanks for the suggestions, unfortunately I have no current in the agricultural land, I should buy steel bars, the iron shop owns a small truck, therefore with a small economic contribution of transport, I would deliver the material to the house where I have my small workshop in my garage, I have the welding machine the drill and other equipment, I would build the frame of the modular gate to bring the bars into the ground and compose it using bolts bars and plates and fixing brackets, the ground is in an isolated place or so I should bring everything you need and the equipment from home, I own an old utilitarian transport, otherwise I should hire a pickup truck, I should find a cheap and effective solution, thanks anyway for the right suggestions, thanks -
four meters wide, a suitable access to make a truck access a farm machine, easy to carry out and transport, robust and light, the land is out of reach in the countryside in the suburbs, some carriers use it as illegal dump to discharge construction waste and cumbersome, that's why I'm working and engineering to fence the perimeter of this land and to block access to the access path, thanks again for the valuable suggestions -
thanks for the right suggestions and photos you have been very useful http://extension.uga.edu/publications/detail.html?number=C774&title=Fences%20for%20the%20Farm thank you again, excuse me if I insist, I should also make a gate or barrier to open the entrance road, you could suggest me how to make a gate mountable without using welding, I have no electricity in the countryside, I would like to make a gate or a barrier at home in my garage and take it into the ground in pieces with an old utilitarian car. and mount it with brackets bolts some suggestions thanks again best wishes for the current holidays https://contentgrid.homedepot-static.com/hdus/en_US/DTCCOMNEW/fetch/DIY_Projects_and_Ideas/Building_Materials/Guides/simple-steps-to-assemble-and-hang-a-chain-link-gate-HT-PG-BM-hero.jpg https://www.instructables.com/id/How-to-Hang-a-Farm-GateFence/ https://www.farmweld.com.au/heritage-style-country-gates/ -
thanks for the valuable suggestions, some photos if they are not too pretentious and boring thanks -
a post pounder o post driver homemade?a plantpale tool for homemade fences and palisades? some ideas already made to take a cue thanks -
I thank you for your testimony, some photos courtesy to get inspiration and inspiration? thank you feel for the heat treatment as I rule? not knowing the characteristics empirically, I have to use a piece of steel for recovery. Thanks again -
thanks for the valuable suggestion, I have to recover the right piece of steel to build it (I had recommended steel rod for reinforced concrete armor), if you had other photos or drawings for inspiration, I invite you to attach them to the discussion thanks again greetings to all friends of the forum I take this opportunity to offer you best wishes for happy holidays -
help design construction rake ripper for excavator
angiolino replied to angiolino's topic in Problem Solving
angiolino posted a topic in Blacksmithing, General Discussion
hello I should make with a recovery materials a steel digging bar to use as a spud bar, crow bar, to make holes in the ground and plant poles, what do you recommend, some friend user has built one if you like and what material he used , would you have photos to use to get inspiration thanks to which optimal dimensions? -
thanks for the right suggestions and valuable advice, know some other friend user had photos drawings or other valuable tips to be submitted to invite him to join the discussion thanks -
hello, a friend of mine owns a small excavator model komatsu pc 75, should use it to clean up and clean up a long-abandoned agricultural farm, should weed out ailanthus type shrubs, weed weeds, bramble bushes, should free the soil from stones roots stones, for this motif asked me if I could make a rake by hand to make it easier to clean, the standard bucket is not suitable for this purpose, a rake about 1 meter thick 15 mm thick, teeth about 40 cm long, to be hooked to the strssa bucket of the excavator, some constructive suggestion for the bucket rake to slaughter and tear the soil ask about 1000 € uro, we want to spend less thanks to those who want to collaborate in our project.
thanks for the precious suggestions, we will surely use the ancient and effective method of the grandfather with manual tools and lots of effort, as regards the use of the excavator or other machinery we will evaluate the risks and the operating expenses thanks to the valuable suggestions or advice, if other friends users have ideas or similar experiences, I invite them to participate and write to the discussion thanks again
I was advised to rent a wheelbarrow like the photo and a small excavator, I would not know how to use them in those conditions, the old men of the village have advised me to do as the grandfather shovel and pickaxe manually, and so much effort, ancient and tested method , if you had to hire an excavator in your opinion as more suitable as weight size and power? could I, with a little patience, learn to maneuver it or would it be too presumptuous for my abilities? they advised me downstream and up the slope to plant upright posts and crosspieces to create portals on which to hook ropes and pulleys, what do you think of a rudimentary cableway/derrick?
thank you for your precious suggestion unfortunately I can not use excavator, in that slope it would be dangerous too, maybe we will make a temporary structure like scaffolding for the appropriateness of the materials and we will manually realize the works that we can in economy
+ http://www.regione.piemonte.it/ambiente/tutela_amb/dwd/tecniche_sistemazione.pdf http://hot-184591.blogspot.com/2012/05/macchine-da-cantiere-nellantichita.html http://didattica.uniroma2.it/assets/uploads/corsi/144406/001_dispensa_impaginata.pdf https://makezine.com/projects/make-34/heron-of-alexandria-and-the-gin-pole/ gin pole hoist? work would be a job in economics to be done voluntarily as a hobby in the spare time they advised me to buy a small excavator, which will climb the slope and build the access path, will help my friends in a voluntary way, if you know another system maybe like those used by the Egyptians to erect the monumental pyramids or other works, I invite you to propose alternative and economic solutions, originally it was made by a team of skilled forestry workers with manual tools with many hours of work
I should transport tools and materials to restore the site (environmental maintenance), which as you understood was hit by a violent fire, which destroyed the plants that supported the ground to prevent landslides and landslides, an acquaintance advised me to use type tracked vehicles excavator, dump truck or crawler loader, I could install a cableway and pulley, we will have to install support iron trellis, what do you think? thanks for the attention and the right suggestions thank you http://baitoncello.blogspot.com/2012/12/progetto-teleferica.html
5 metre, it's exact altitude , transport, to lift piece of wood ,stick,
