angiolino
Everything posted by angiolino
  1. hello I would like to realize a metal anvil to beat us over the iron recovered material would have picked up ideas, ll'incudine made tracks seems a slight bit to beat us over with 12 libre poker, what would you suggest? I should also realize the pedestal to support it as it should have and how high taking into account that are one meter high and eighty centimeters, if you had pictures would be great thanks
  2. the canopy is already done I have to build the rack, I bought the tahi H 100 mm for the brackets, columns can I make beams H 160 mm 2 meters high, the base of the lighthouse with adequate beams, without drilling the floor and walled with concrete, the base I can hope that a meter has not been reversed, should be enough thanks for your cooperation
  3. hello I should make a roll cantilever rack made at home for my small laboratory course safely shop to stock the bars of pipes and metal profiles to be placed in my back yard, to realize a warehouse store in order, pottete help me as I conceive and realize, looks useful advice and tips with
  4. thanks for your advice, which could have brought this device? The hoist arm should not be more cantilever type falcon with pulleys? what do you say?
  5. you could help me build a handcrafted log skidder to pull logs graces that I recommended to use materials
  6. hello, I would build an iron staircase to a loft raggiongere, height 2 metr, size scale length scale of 230 cm width 50 cm, 22 cm steps away, how should I do to get a perfect artifact? I use the material?
  7. I would like some advice I should carry an iron mezzanine: height from the ground 2.10 meters ttravi length 2.50 meters, 1.20 meters x x ddistanza beams beams to install, as recommended proceeding to me, that use the material thanks to those who want to help me look suggestions and testimonies
  8. hello I have a big stove Methane gas burner, as you advise me to turn it into a forge to heat and make plastic the metal for forging? thanks to those who will want to provide tips and photos hello to the next
  9. how to build a kusarigama ninja, which measures has, use material that someone has competed in the construction?
  10. spreader beam" and a "lifting beam were is the different?
  11. hello guys, I have to move the machine tool, I was suggested to build a spreader beams with steel beams to balance the load during lifting and translation, can you help me load it is 3 tons the length of the spreader beamc 8 feet could you help me out how to conceive and build it through to the next https://encrypted-tbn3.gstatic.com/images?q=tbn:ANd9GcRu1J8ProIXX3GT9JG7ujWQZzJxOzHhHfz9HlvrnB0vjepmLdVw http://g01.s.alicdn.com/kf/HTB1yiqtKpXXXXaLXVXXq6xXFXXXe/Adjustable-Lifting-Beam.jpg_220x220.jpg
  12. thanks guys lighthouse treasure your valuable advice, I have to rest on the frame of the ground campaign as lifting device usero peranco Manual chain http://www.optimalhandling.com/ShowImage.axd?id=1116&W=207&H=208 http://www.sdms.co.uk/images/sized/images/products/SE218-EOD-Tripod_261_400_s_100_imagesproductssdmswatermarkurl.png_100_100_60_c_c.jpg
  13. i have to build a tripod hoist crane height under hook 12 feet reach 2 tons as realizable, can you help me? thank http://www.arrow-cranehoist.com/tripod.htm http://www.cisco-eagle.com/catalog/c-5329-tripod-cranes.aspx
  14. thanks for useful suggestions
  15. i build a metal arm gin pole to be installed at the rear of an agriculturar machine for uses as a crane what material do you suggest to use that tecnique h 12 feet p 2 ton
  16. hello I should carry a rake or a tool to smooth and clean the sand of the beaches from waste and stones debris carried by storm surges would advice thanks
  17. Ciao, io Così se METTERE La Discussione Nel forum giusto, tuttavia Expore la Domanda: Dovrei Costruire Una drawbarr rigida per il traino di camion o coacher in Fallimento, Come una grande Dimensione dovrebbe attacched Rudden avanti e indietro dei Veicoli Che Si Può aiutare me noiSei le Dimensioni del materiale: 2,50 metri Peso / 3 della metropolitana per TIRARE 12 tonnellata tanks
  18. Sorry guys but I do not speak English and I have difficulties to insert pictures and drawings I would need tips and sorry if I postat 2 messages sequentially aspect grazi tips for your patience and your precious time is a patio sun to achieve iron frame transparent cover polycarbonate 16 mm
  19. hello I have to build an outdoor canopy type patio that serves as protection for the front door and canopy for the car measures sono.lunghezza L = 15 feet, width = 10 feet, height = 11.5 feet in iron, from a i want to side with iron plates bolted to the wall on the other side i want to support the joists to a girder resting on two iron pillars type portal that advice you can give me what material to use that section with aspect information and suggestions hello
  20. hello we have to realize for a house in the countryside a shed or pergola or patio to be fixed to the wall and then place an iron portal measurements are 20 feet long high 11 ffet larga13 feet iron one hand resting and hooked to the wall of the house from 'backed up to a portal formed by two pillars iron uprights and a beam iron might help size the various parts and materials required have a drill welding and grinding machine thanks
  21. thanks for your helpuful suggestion I will make certainly treasure
  22. hello I do not know if you can help we would like to make a manual winch or a capstan winch to haul and tow boats and small boats maximum length of 20 feet wood could you help me to design it and make it look simple materials with tips
  23. thanks for the valuable advice I will treasure it, doubt it was just the choice of material for the steely blade to prevent denting and wear thanks again
