273 -
Everything posted by angiolino
build a salmon ladder at home in iron tips
angiolino replied to angiolino's topic in Welding/Fab General Discussion
thank you for the valuable advice and clarifications, I evaluated everything and will try to take the right solution, my friend told me that he wanted to find an old scaffolding type scaffolding on which to build the power rack structure and fix the salmon ladder on it and others tools, like the pulley and also use it as a support for the barbell to lift weights on bench thanks, even if you had other ideas to draw inspiration from, I invite you to write thanks again htt -
on the net I have seen some examples seemed scaffolding for construction site, of those homemade were almost all in wood, obviously it is not a structure for public gym but for an acquaintance of mine who has the hobby to train at home, I do not find the right design with the right reference measurements, if I make the hooks too far apart, I risk that when I hook the bar in the trimming phase, it does not grip and therefore you fall ruinously, I would like to know the right distance between the hook and the hook and the right distance between the hooks right proportions, we would like to do it in metal maybe tubular what do you think?I saw one that was attached to a structure called a power rack CYCLONE 100 -
hello a friend of mine would like me to build him a gym apparatus a salmon ladder, it is a metal structure on which a bar is hooked and a climb is made, repeatedly hooking the bar to the special support hooks, it would be used for training traction someone could suggest me how to build it and what material to use on the net there are photos without reference measures thanks
honestly I only reclaimed the area where the fence was set up, I cut the bushes and weed the weeds, I made a couple of holes for the foundation plinths, but the ground is hard and stony, I have a lot of difficulty, if any user friend if you have any additional suggestions or suggestions, I invite you to participate, I have to hire a pickup truck to buy the material I need thanks
even 100 km per hour, it is at the limit with the railroad, the railroad company does not take care of the maintenance of the area next to the tracks, bushes grow bushes reeds, the wind carries waste, wild animals and snakes nest. I would like to realize with metal tubes the frame on which to screw the corrugated sheets I plant fifty centimeters in the ground what do you recommend? http://www.cemensolai.com/cordoli2012/recinzioni-prodotti-266.html http://dogler78.org/let/ http://ixiqi.co/image
metal fence tips should I build a metal fence like a construction site with corrugated sheets, I should make the poles and crossbars to screw them in, which material should I use? eleven meters long, 2 meters high, which materials I use which sections and how far away I put them, how deep I place the poles? the poles in t-section or in tubular hollow? thank you
it is a dwelling, you understand that it must have a minimum of aesthetic sense, otherwise my neighbors could report me to the local authorities for building abuse and break down the structure denounce me and make me a salty fine, however if some friend had photos or drawings with measures I invite him to write, thanks again for the valuable suggestions, thanks anywayhttps://5.imimg.com/data5/JR/MG/MY-6126577/car-parking-canopy-500x500.jpg https://www.picclickimg.com/d/l400/pict/123095153187_/Freestanding-carport-garden-canopy-hot-tub-cover.jpg https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQPh4TLlehPE0fSE7uqDJvKmUziilycTLC_R9LUfPhHKVM9CbI3Pw
thank you for the valuable suggestions, an engineer friend of mine suggested me to use for the frame structure instead of the profiled H-beam metal tubes at least 100 mm in section, he believes very tenacious and light what you think? today the sirocco wind from the African desert is blowing at more than 100 / km / h has broken some torn up trees billboards damaged roofs, I have to evaluate the structure of the supporting frame and the anchoring base, I think we need large concrete plinths, what do you think you? thanks anyway for some valuable advice, I will certainly treasure it, thanks https://www.oppo.it/tabelle/profilati_hea.htm https://www.oppo.it/tabelle/a_elenco_tabelle.html https://www.oppo.it/tabelle/profilati_ipe.htm https://www.oppo.it/tabelle/profilati_inp.htm https://www.oppo.it/tabelle/profilati-tubi-quadri.htm https://www.oppo.it/tabelle/profilati_upn.htm https://www.oppo.it/tabelle/profilati-tubi-rettang.htm https://www.oppo.it/tabelle/carico_flessione_ipe.htm http://www.cabiddu.it/tecnica/ProdottiSiderurgici.pdf
hello I should build a protective shelter to protect two cars in a courtyard, and measures are maximum wall height courtyard H 2.5 meters, width depth 5.50, length 9 meters, how do I proceed that material, how would you do it? the structure of the frame we would like to realize it in iron, which materials do I use for cross beams archerecci beams? thanks to those who want to help me in this project
Russian and Oriental knives tips
angiolino replied to angiolino's topic in Knife making Class General Class Discussion
thanks for the right suggestions, there is a photo album inside the forum where you can take pictures, pictures, drawings, measures to use as reference shapes, thanks again -
thanks for the right suggestion, if I can and do not disturb and I am not boring, you would have some reference photos, thanks for what material and heat treatment I should adopt, thank you for your cooperation, sorry if I'm petulant, thanks it would look like a bayonet or a small saber, an oriental scimitar, right, am I wrong? -
sorry if I disturbed you, thanks
would my nephew want to build a gym bench, a power rack and all the equipment needed to set up a gym at home to make some ideas? thanks for collaboration
I should make an ax acceptation of those with large half-moon blade, I can not find reference pictures or drawings with measurements, it would be like a big cleaver or a big wide-banded monkey. thanks anyway for the right suggestions, what material and thickness do you recommend to use? in truth it is the first that I am about to realize, therefore every suggestion advice or other is welcome thanks again
I recommend small mobile crane on wheels for workshop
angiolino replied to angiolino's topic in Member Projects
Thank you for your precious intervention and the right advice, I treasure your words thanks again Blackhawk -
thank you for the right suggestions if any friend user had photo drawings or other suggestions or useful tips, I invite you to speak and write thanks greetings to all of you, thanks for the active collaboration
hello, I would like to make a small table with wheels to use to transport where I need a small portable 60cm long, 25 cm high 40 cm weight 7 kg weight 180 amps, some ideas, I've seen some for plasma cutting, some ideas , some photos, some design with measures thanks http://pdf.directindustry.it/pdf/cemont/catalogo-generale-2017/181804-727825.html https://weldingsuperstore.co.uk/brand-cemont.html
thank you for your right suggestions, in my part this type of crane for workshop mechanic to extract engines from vehicles, they are commonly called: "goat or hydraulic capretta", do not ask why, but in Italian some cranes are called goats or bigo or crane in boating, thanks again for the right suggestions
