angiolino
Everything posted by angiolino
  1. a post pounder o post driver homemade?a plantpale tool for homemade fences and palisades? some ideas already made to take a cue thanks
  2. I thank you for your testimony, some photos courtesy to get inspiration and inspiration? thank you feel for the heat treatment as I rule? not knowing the characteristics empirically, I have to use a piece of steel for recovery. Thanks again
  3. thanks for the valuable suggestion, I have to recover the right piece of steel to build it (I had recommended steel rod for reinforced concrete armor), if you had other photos or drawings for inspiration, I invite you to attach them to the discussion thanks again greetings to all friends of the forum I take this opportunity to offer you best wishes for happy holidays
  4. cosa pensate di questo?digging ripper rake
  5. hello I should make with a recovery materials a steel digging bar to use as a spud bar, crow bar, to make holes in the ground and plant poles, what do you recommend, some friend user has built one if you like and what material he used , would you have photos to use to get inspiration thanks to which optimal dimensions?
  6. thanks for the right suggestions and valuable advice, know some other friend user had photos drawings or other valuable tips to be submitted to invite him to join the discussion thanks
  7. hello, a friend of mine owns a small excavator model komatsu pc 75, should use it to clean up and clean up a long-abandoned agricultural farm, should weed out ailanthus type shrubs, weed weeds, bramble bushes, should free the soil from stones roots stones, for this motif asked me if I could make a rake by hand to make it easier to clean, the standard bucket is not suitable for this purpose, a rake about 1 meter thick 15 mm thick, teeth about 40 cm long, to be hooked to the strssa bucket of the excavator, some constructive suggestion for the bucket rake to slaughter and tear the soil ask about 1000 € uro, we want to spend less thanks to those who want to collaborate in our project.
  8. thanks for the precious suggestions, we will surely use the ancient and effective method of the grandfather with manual tools and lots of effort, as regards the use of the excavator or other machinery we will evaluate the risks and the operating expenses thanks to the valuable suggestions or advice, if other friends users have ideas or similar experiences, I invite them to participate and write to the discussion thanks again
  9. thanks for the valuable advice. I did not understand what I should not buy?
  10. I was advised to rent a wheelbarrow like the photo and a small excavator, I would not know how to use them in those conditions, the old men of the village have advised me to do as the grandfather shovel and pickaxe manually, and so much effort, ancient and tested method , if you had to hire an excavator in your opinion as more suitable as weight size and power? could I, with a little patience, learn to maneuver it or would it be too presumptuous for my abilities? they advised me downstream and up the slope to plant upright posts and crosspieces to create portals on which to hook ropes and pulleys, what do you think of a rudimentary cableway/derrick?
  11. thank you for your precious suggestion unfortunately I can not use excavator, in that slope it would be dangerous too, maybe we will make a temporary structure like scaffolding for the appropriateness of the materials and we will manually realize the works that we can in economy
  12. + http://www.regione.piemonte.it/ambiente/tutela_amb/dwd/tecniche_sistemazione.pdf http://hot-184591.blogspot.com/2012/05/macchine-da-cantiere-nellantichita.html http://didattica.uniroma2.it/assets/uploads/corsi/144406/001_dispensa_impaginata.pdf https://makezine.com/projects/make-34/heron-of-alexandria-and-the-gin-pole/ gin pole hoist? work would be a job in economics to be done voluntarily as a hobby in the spare time they advised me to buy a small excavator, which will climb the slope and build the access path, will help my friends in a voluntary way, if you know another system maybe like those used by the Egyptians to erect the monumental pyramids or other works, I invite you to propose alternative and economic solutions, originally it was made by a team of skilled forestry workers with manual tools with many hours of work
  13. I should transport tools and materials to restore the site (environmental maintenance), which as you understood was hit by a violent fire, which destroyed the plants that supported the ground to prevent landslides and landslides, an acquaintance advised me to use type tracked vehicles excavator, dump truck or crawler loader, I could install a cableway and pulley, we will have to install support iron trellis, what do you think? thanks for the attention and the right suggestions thank you http://baitoncello.blogspot.com/2012/12/progetto-teleferica.html
  14. enclose a few of illustration picture photo
  15. 5 metre, it's exact altitude , transport, to lift piece of wood ,stick,
  16. For a land in the countryside with terracing we will have to build a device for transport and lift type cableway. A friend of mine suggested to me like a monorails or a shingle lift or a ladder hoist type like those for construction sites as it is very short the path to be done from the cart about 8 meters. The weight to translate I think 500 kg. What can you suggest. Thanks to those who want to help me providing valuable suggestions, rail hoist frame in steel beam Rails are two 2x4s fixed together to form a L shape.
  17. hinge? pintle? pivot? trust bearing ? I can not find the right pieces for the rotating turntable boom turntable support, I do not find the right bearing for the bolt pin, I believe I have to build modified piece on the lathe, do you have any suggestions? I thought it was enough to cut the drill bit and screw it, instead I have to build a hinge on the lathe, advice? thank you https://www.canadiancustomelectrical.com/shop/product/jib-crane-hinge-kit-426?category=57 https://www.materialflow.com/p/Wall-Mounted-Jib-Cranes http://www.westernsafety.com/products/spancocranes/spancocranepg6.html http://www.proservcrane.com/Products/AbellHoweJib https://www.pinterest.co.uk/pin/396035360957271480/ http://racingcars.co/wall-mounted-jib-crane/wall-mounted-jib-crane-stunning-types-accent-sales-and-service-co-home-design-ideas-29/
  18. you say that I can build the boom without bearing thrust pads how? actually the bolts and the tie rods I found them I have difficulty in finding the bearings to make the boom swivel you have alternative solutions, if you would give me the courtesy to send me photos, as a boom beam I chose a ipe of 120, as a hea pillar of 100 high 4 matri I hope they are sufficient for a range of 500 kg, if it were a useful capacity higher sincerely bought a crane approved to be safe, anyway thank you again excuse me for the trouble I gave you the next http://www.oppo.it/tabelle/profilati_ipe.htm http://www.oppo.it/tabelle/profilati_hea.htm http://www.oppo.it/calcoli/travi/trave_acd.php pivot shaft swing boom hoist http://www.fsindustries.com/more_info/mast_type_jib_cranes/1_2_ton_capacity.shtml
  19. I thank you for your intervention, I have to be honest, I was going to buy the iron to make the structure, then I stopped I had a conscience of conscience, if you give the zipper I'm afraid you hurt some one if not you I ask too much could you make me the photo of the support of the pin where the column crosses the pillar thanks, I was taking a 100 mm beam for the column and a Ipe 120 mm long 3.70 meters for the crossbar the hoist and the cart I have them already taken, I have to establish the bolts for the pins / creme 26 mm thick) and the tie rods to hook the upright column to the pillar (crd 20 mm in diameter to 60 cm in length) thanks again for your valuable intervention sorry all if I'm getting bored with this discussion thanks to the next I hope soon.
  20. La struttura è stata progettata per resistere a una struttura più robusta e robusta a prova di indebolire la colonna dell'edificio, la gru riposa l'equilibrio alla trave d'acciaio, la trave in acciaio il saffo alla colonna in cemento armato attraverso staffe e grosse barre d'acciaio, devo trovare i vari materiali, sto lavorando grazie The structure was designed to withstand a more robust and robust structure to weaken the column of the building, the crane rests the balance to the steel beam, the steel beam the saffo to the reinforced concrete column through brackets and big steel bars, I have to find the various materials, I'm working thanks Swing arm hoist boom
  21. http://www.practicalmachinist.com/vb/general/picking-up-heavy-things-machine-tools-when-your-old-324187/index2.html thanks for the right advice, my problem is not the welding but the rotating support of the hinge, if I do not realize it robust, when I load the crane gives and I beheaded the head, if you could give me pictures drawings measures would you do me big favor, even of the diagonal tie sorry if I disturb you and take advantage of your patience, but the security above all, the scope is modest, but the arm weighs 40 kg, the cart and the hoist 20, kg plus the weight to be lifted, if the zipper yields and falls from 3 meters high we hurt ourselves thanks again sorry if I bothered you again thanks again
  22. http://www.ets-spa.com/it/ thank you guys for your valuable intervention, if possible I would like to have photos and drawings your Jib crane, for the pins I thought big bolts, but I also have to realize the supports and thrust ball bearings, I have to see if there are bushings in bronze "bronzine", a guy engineer tells me that a beam ipe 120 mm Ah H can support peak load maximum profit of% == 5 Kg 5 quinals, enough for me, the supporting column I want to do in steel leaning and anchored au a big concrete pillar of the building, my engineer friend suggested me to use a H-shaped steel beam with a 100 mm wide section HE as a vertical column, as a diagonal rod to empirically suggest to weld a 50x 100 mm plate thick what you think is safe is feasible. the structure is cantilevered like a shelf, I would not want to give up the hinges and beheaded, when I use the crane and I have a load hanging anyway thanks again, if you had other suggestions I invite you asottoporli to my attention thanks again greetings thank you guys for your valuable intervention, if possible I would like to have photos and drawings your Jib crane, for the pins I thought big bolts, but I also have to realize the supports and thrust ball bearings, I have to see if there are bushings in bronze "bronzine", a guy engineer tells me that a beam ipe 120 mm Ah H can support peak load maximum profit of% == 5 Kg 5 quinals, enough for me, the supporting column I want to do in steel leaning and anchored au a big concrete pillar of the building, my engineer friend suggested me to use a H-shaped steel beam with a 100 mm wide section HE as a vertical column, as a diagonal rod to empirically suggest to weld a 50x 100 mm plate thick what you think is safe is feasible. the structure is cantilevered like a shelf, I would not want to give up the hinges and beheaded, when I use the crane and I have a load hanging anyway thanks again, if you had other suggestions I invite you asottoporli to my attention thanks again greetings
  23. Thank you for your intervention and your opinion, if I can afford to ask, how would you have done it? thanks again for your constructive criticism and your considerations
  24. What do you think of this perch made by the blacksmith?
  25. a friend user has created this jib crane that I found on the web made everything in steel beams
