Everything posted by angiolino
advice building potato digger tool
[Commercial link removed] I should first remove the stones and the roots and dig up everything, otherwise with this tool if I leverage and buried there is a big stone risk of breaking the tool, wasting time and effort and giving me the hernia due to fatigue, I should proportion it to my weight and to my body, at the height and age, 180 centimeters by ninety kilograms, anyway thanks for the advice, as I progress with the reclamation, I understand I hope the right strategy to be adopted thanks.
it is not flat it is in the hills in ancient times it was a terraced terraced vineyard, my uncle had it filled with waste earth to make a square and build a shed, then nothing has been done for decades it has been uncultivated, now passing time I'm cleaning it with farmer's hand tools, but it's a hard job, a sprout of ailanthus has turned the ground into a small jungle, first I cut the plants now I'm undermining the roots with a pickaxe and an iron pipe that I use as a lever if I do not transfer everything will turn into a wild jungle and you will not be able to enter even with excavators and mechanical shovels. sweating blood elbow grease fatigue and a bad back that I don't tell you, in the evening I am physically destroyed but gym. https://www.metric-conversions.org/it/area/acri-a-metri-quadrati.htm 2000mq = 2187.2yd
I have plant residues, the resulting material, I don't know if it is adequate and suitable for the purpose, what tool I should make, you would have some images with photos, not a machine but a tool that I can simply make at home with a few recycled tools and objects. thank you.
the land has been abandoned for some time about 1000 square meters, I am cleaning it up and tilling it little by little with a hoe and pickaxe a hard job, it would take a mechanical shovel, but unfortunately I am short of cash at the moment, I have to create a small vegetable garden for the home economics, with the little that I can scrape together, bad times in my part, between crisis and virus, let's hope it ends well.
hello, I should make a simple potato digger tool, as I conceive and make it to be efficient, robust and effective, what material I use, what size, I think it is a big pitchfork or a big rake. let me know, thanks.
help construction design realization gin pole
help construction design realization gin pole: hello we will have to build a gin pole hoist to be installed as a foruna crane on the flatbed of a truck, to transform it when needed into a makeshift crane to be used on the farm, some ideas some constructive suggestions, we will have to make the support supports to hinge the arms to the platform and the tie rods to support the same to the body any ideas? http://img.iweku.com/upload/f/c0/fc021be8352c50cc07021d6ed452bac8_thumb.jpg http://img.iweku.com/upload/e/a9/ea988e6cb1cb3fefbf966a359b64593a_thumb.jpghttp://img.iweku.com/upload/3/5c/35c28a4fa27f80c20a1906c35312ccaa_thumb.jpg Autocarro Medio Fiat 80 CARATTERISTICHE E PRESTAZIONI PRINCIPALI Cilindrata: 5499cm3 N. cilindri: 6 Potenza: kW:117,8; CV: 160 a 3200 giri/min Coppia: Nm: 392; kgm: 40 a 2000 giri/min N. Marce: 5 Riduttore: si Trazione: integrale Velocità max: 93 km/h Carburante : gasolio Autonomia: 500 km Capacità serbatoio: 145 litri Dimensioni: Lunghezza: 6413mm Larghezza: 2295 mm Altezza: 3085mm Peso: 5930 kg Portata: 4000 kg Peso rimorchiabile: 6400 kg N. batterie: 2 Tensione: 24 V N. posti: cabina: 2; cassone: 18 Dimensione cassone: Lunghezza: 4255mm Larghezza: 2200mm Altezza: 500mm
help tip construction boom pole for crawler loader
it does not have to lift tons when you need 300 500 kg maximum at low heights the convenience of a small lifting crane a small courtesy forklift. not big and heavy weight lifting. http://gardentractortalk.com/forums/topic/58611-front-end-loader-jib-boom/ https://www.qualityweldingservice.com/qm22/index.php/extenda-boom.html https://www.qualityweldingservice.com/qm22/pub/media/catalog/product/cache/c9e0b0ef589f3508e5ba515cde53c5ff/b/o/boom-extenda-20ft-horiz-reach_1.jpg https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQWNzqWSlNNLoE2OkzfqIzgNCpJC4nVGhrMJw&usqp=CAU
hello, sorry if I disturb, I should make a boom pole for a small tracked power shovel it is a fiat allis fl 5 weighing 8 tons, 90 horsepower engine 3.97 meters height of the bucket discharge pin bucket capacity 1 cubic meter, keep in mind that a meter of gravel weighs about 1.5, 1, 8 tons as weight. how should I conceive it, what material I use, how to attach it to the bucket, how much can protrude from the bucket to prevent the machine from overturning, for the stability of the center of gravity of the mechanical shovel, how to reinforce the bucket the fiat fl5 is the same in size, weight and power as the caterpillar 931. thanks sorry if I disturb you. the boom will serve when it is necessary to load and lift loads as needed.
Pallet Pry Bar/ crowbar homemade
thanks again for your kindness and availability, you are priceless, especially in this period of crisis and covid, useful advice and very precious suggestions in my opinion thank you.
thank you again for the valuable advice, very useful and invaluable for amateurs in disarray like me, unfortunately I am still a rookie to train, I envy you and admire you veterans at the same time, thanks again, sorry if I disturbed you thanks again.
BUSTER PALLET Buster BREAKER1 Breaker Pallet?? thank you for everything, I will search my warehouse to find suitable materials, thank you and sorry again
hello, a carpenter friend of mine would like me to build him a tool to disassemble the wooden pallets and recycle the planks, how should I conceive it, on the net I saw some user friends who made like a metal fork a big iron fork to unpin the planks , how to make it functional. thanks I wait for advice
Swiss Bar/Multi-Grip Bar diy?
sorry guys, i would like to make a babell swiss bar multi grip. could you help me, what material do I use, how do I fix the various pieces to compose the frame, do I make an assembly jig with reference points? thanks. I only have the welder and a small angle grinder as a tool at my disposal. thanks
kettlebell homemade with recycled material tips
thanks for the right advice
thanks for your brilliant and ingenious suggestion, I hadn't thought about it.
if I make it out of concrete, in reality I don't even know how to use it for training but I'm bored to death on the net I saw 15 kg but the right weight I think is better 8 kg barbell dumbell I think they are more suitable for home training, I hope the confinement and coercion will soon end, otherwise I will need a new shed to store all these junk that I would like to make. https://ru.wikipedia.org/wiki/Гиревой_спорт
how to make a kettlebell at home with recycled material and a few tools. guys excuse me if I disturb, I am closed at home because of the covid, as time passes I would like to build a kettlebell, the pastime does not consist in using it by training, but in building it some suggestions thanks sorry for the inconvenience.
I recommend making "dumbbell / barbell barbell bench homemade
my pastime during the constraint and segregation is not training but building tools with recycled material, we hope the quarantine ends soon.
thanks it's not bad the coronavirus is slowing us down we advance at a snail's pace. desperate times call for desperate measures. need sharpen ingenuity, big fine brain shoe, I would like to use old gears engine flywheels and as barbell bars metal pipes or steel saali recovered in workshops and scrap shops, thanks anyway. I'm preparing for the new quarantine. our politicians in order not to alarm us say things with the drop counter. Thanks again http://www.storytrender.com/23695/gym-built-old-car-parts-hailed-worlds-hardcore-workout-arena/ https://www.thesun.co.uk/news/4038179/gym-built-from-trees-tyres-used-car-parts-russia-forest/ makeshift gym from car parts https://www.telegraph.co.uk/cars/news/inspirational-russian-fitness-fans-build-makeshift-gym-car-parts/russian-gym-made-car-parts-scrap7/
thank you for your suggestion
I recommend making "dumbbell / barbell barbell bench homemade: hello if it were possible I would like to make gym weights by recycling objects, spending little money, some creative ideas beyond sand, stones and containers of water or concrete? thanks waiting for suggestions.
construction advice, home-made gym bench
in confidence as a boy I built one with scrap iron and a board, I weighed about 70 kg but I managed to lift about 90 kg, well once under stress I lost control and was about to decapitate myself. with an enormous effort, I leaned the barbell sideways and slipped from underneath, don't mess with these gym tools, rightly some friends suggested combining the bench with a power rack which would be a sort of protective cage a support for the barbells and the weights, I have to think about it. thank you Materials Needed 1. Wood – we are going to be using eight 4×4 in pieces, eight feet each: a. Four for the uprights b. Four for the cross pieces 2. 1 lb of 2 in. Star Bit Wood Screws and 1/2 lb of 3 in same screw type 3. 14 – 1/2x2x2 3/4 90 Degree Steel Ties (the strongest ones you can get) 4. 8 – 3×5 strong Flat Steel Ties For each safety bar you will need:: A 60 Inch (3/4 in) Pipe A 4 Inch (3/4 in) Pipe A 90 Degree Elbows (optional) One Cap (optional) For each racking pin you will need: A Chair Flange A 1 1/2 Inch Pipe A Pipe Connector A 4 1/2 Inch Pipe One Cap
only for horizontal bench training
gym weights barbells dumbbells, the person who will use it is 180 cm tall weighs 90 kg I think he will have to lift 40 kg of barbell. a simple structure to make but sturdy, thanks i think iron frame wooden floor. I think it is the best solution, which can support a maximum load and a capacity of 200kg. thank you. what better structure conformation, with 4 upright feet type chair or type H upside down? what material do you suggest box-shaped metal pipes or L or T type profiles? what section to support the load, crossbars of reinforcements diagonal braces? thank you sorry if I'm petulant.
hello, if it were possible, I would need some advice some suggestions to make a gym bench, it should be light robust aesthetically pleasing to handle compact not bulky to store in a corner when not needed. measures: 12 inches wide 30 cm long: 48 inches - 120cm high from the ground: 17 inches - 43 centimeters what material do i use? how do i make it? thank you
