Everything posted by angiolino
Help build a metal warrior statue with scrap metals recycled from the junkyard.
I have to find an anatomy book maybe I do it in material like characters of pirates of the Caribbean, but I have to study it and do it in proportions otherwise it does not come a statue but a pile of debris, it must have elegance, harmony and convey a message it must have the appearance of a warrior also stylized otherwise it becomes a wreck am I wrong? '
I would like to make a warrior with a shield that protects the body in such a way that I save a lot of work and details I have to go to scrap yards but first I have to draw a sketch with four measures otherwise I risk using and recycling useless and unsuitable material thanks.
thanks for the precious suggestions, of course I do not have the presumption of making the armor of a medieval crusader warrior but a stylized material structure that gives the impression of a cross between a warrior and a robot, perhaps with car shock absorbers, gears connecting rods or similar or similar scraps, I think it is necessary to start from a drawing a sketch with measurements, maybe if you would be so kind as to attach the links of the most appropriate discussions, thanks again for your collaboration sorry for the trouble greetings. https://www.vol.at/imposante-skulpturen-aus-schrott/3243386http://lauringartner.weebly.com/uploads/1/0/8/8/10881719/6164209_orig.jpg?1354737135
Help build a metal warrior statue with scrap metals recycled from the junkyard.: hi excuse me if I disturb I would like to create a warrior at natural height by recycling metal pieces from workshop scraps or metal objects recovered from scrap shops or body builders some simple and cheap idea thanks greetings excuse me for the bizarre and bizarre question greetings warrior metal art sculpture https://www.mari9art.com/samurai-2nd-metal-sculpture
advice table desk desk workstation office advice design.
thank you for your kind availability and your valuable advice, I have space problems so I have to work out, sorry if I'm not an active user, but you understand well where I come from are delicate moments, thanks again greetings to all.
hi sorry if I disturb, in my shelter laboratory I have my workbench welding station, I would like to create a study office corner, a corner where to put a sturdy table a desk to have fun reading the newspaper, consulting books designing sketching, supporting the computer, or a workstation versatile multi-purpose to my personal needs. therefore I thought of creating a personalized desk table, the measures would be: 70 cm wide, 80 cm high h, 120 cm long, you will tell me buy it, I would like to create a banquet, light versatile robust useful for any eventuality, perhaps to disassemble delicate objects, what can you suggest to me, I state that an emporium was selling 80 € therefore between material and time I should save, perhaps by recycling objects or other materials. what do you think, thanks greetings.
yatagan knife-construction advice original drawings dimensions.
thanks i try, thanks for your precious time.
sorry if I disturb, by chance you would have a drawing with the measurements, I would like to make the shape with a cardboard paste it on the foil and trace it and remove the excessive metal, the handle maybe I do it in wood sorry if I disturbed you but on the net if not it is prudent an infinite number of news comes out, maybe I should use a Russian site rumemo of Cossacks or gypsies thanks again and sorry if I disturbed you greetings angelino greetings to all. thanks for your precious time. https://en.wikipedia.org/wiki/Kukri
if it were possible I would need some information, I would like to build a Russian or Romanian knife"yatagan knife" I think it is a Russian hunting knife for bears or maybe it was used by Romanian or Eastern European gypsies I don't know where it came from, but I didn't find the size or the design of the original blade, the drawings on the net look like Filipino bayonets or kucri , let me know thanks I would like to try my hand as a cutler, what material should I use, suspensions crossbow do you think is suitable, and the handle and the grip. thank you. in a photo he says that it is an Ottoman saber, it is not clear.
homemade diy garden cart
Volumen Mulde: 225 l Max. Zuladung: 500 kg Max. Zuladung beim Kippen: 250 kg Reifengröße: 16" x 4.00 - 8 Höhe mit Griff: 1040 mm Länge: 1.410 mm Breite: 810 mm Höhe: 740 mm Nettogewicht: 31,17 kg Bruttogewicht: 35,65 kg the problem is not the frame of the cart, I msa the wheels, the axles and the supports to fix it to the structure, I would not want to go to a turner's workshop to have them made too expensive I know, I would like to make them with objects that I can adapt and find around, buy the shopping cart is very expensive for me, thanks for the right suggestions.
hi I need some advice, I would like to build a cart for the garden, you will tell me use the wheelbarrow, but the cart has 4 wheels that unload the weight on the ground while the wheelbarrow 1, I would need to understand what material to use which wheels and how to make it steering, on the net I have seen all kinds of stores sell it very expensive and are not robust. I would need it to transport stones, bricks, wood and other heavy materials that are inconvenient for me to carry with the wheelbarrow. the ground is not compact it has little lift so in my opinion you need the right wheels. how would you do what size to make the frame, how much maximum I can load it clearly should be the replacement of the tracked wheelbarrow but with muscle traction and not a tracked engine. what do you recommend? the ground and sloping moraine with steps and terracing is bumpy in some points it is therefore not very compact, when it rains it blows into a swamp, thanks. Specifiche Colore: Verde Materiale: Acciaio Dimensioni complessive: 86 x 46,5 x 97 cm (L x P x A) Dimensioni del vano del carrello: 86 x 46 x 41 cm (L x P x A) Lunghezza maniglia: 84 cm Diametro della ruota: 25,5 cm Capacità massima di carico: 350 kg Ruote in gomma PU I pannelli laterali possono essere aperti
Point Carry-All Fork Attachment diy
I should use the right materials to make it strong strong but light at the same time, I am afraid that the fixing supports are not adequate enough. Thank you.
Point Carry-All Fork Attachment hello sorry if I disturb, could you kindly suggest me how to build a self-loading rear bucket fork for this old fiat tractor, in my part it is called the pruning fork, as you call it. how do I make it to be light and sturdy?
Rock Rake, do it yourself agricultural pitchfork for stones and potatoes
better round or flat iron? I have a welding machine, I do not regulate myself in giving the right shape to the ladle, the same is used to collect the stones and accumulate them, and at a later time shovel them and maybe load them on a wheelbarrow to transport them elsewhere and set them aside. what would you suggest?
hi, sorry if I disturb surfing the net I found a rake suitable for both digging stones from the ground and potatoes. I think it could come in handy, but the cost would be a bit high. could you kindly suggest me and help me to make a similar one perhaps more effective using maybe pieces of round iron or other materials suitable for the realization of the artifact, the tool looks like a kitchen spaghetti ladle. let me know, thanks. [Commercial link removed] Any gardener who is plagued with stones, large or small, will appreciate this rake. In designing it, we spent a lot of time getting the right tine shape and spacing so that rocks as small as 3/4" diameter could be removed from the soil without taking a lot of dirt as well. In well-tilled soil, it is an easy matter to clear the top 2" or 3" completely of stones. Once you have raked together a pile of stones, you can scoop them up in the basket-shaped head. No more stooping to pick them up or trying to rake them onto a spade. The rock rake picks them up for transfer to a wheelbarrow or bucket, or even for surreptitious dropping over a fence. It can also be used to catapult the stones some distance. The whole tool is light (the head weighs only 3/4 lb) and has hardened steel tines that flex without deforming. 65" overall, with a 6" wide basket. In our tests, we found it to be an outstanding invention, removing all rocks from 3/4" to 4" in diameter, leaving a smooth stone-free soil. Also ideal for harvesting potatoes.
build a sturdy cart by recycling a pallet
thanks for the clarification was what I understood thanks again, it would be the directional handlebar to pull and push the cart, thanks. https://www.askix.com/plataforma-de-madera-ciclo-cam-carretilla-repurposed-bricolaje-movil-plataforma-carro.html
. all clear, right suggestions, do you want to add a rudder? cart type ??? . I remove the lower part which is used to insert the forklift forks, I lower the pallet platform and fix the wheels on it to lower the center of gravity and have greater stability and trim. did I get it right?'
hi susatemi if I disturb, with these trivial questions, I would like to make a sturdy trolley to move junk accumulated in the courtyard, I thought of using a pallet as a platform and attaching wheels to it. I am afraid that during the translation push phase they could come off, causing the material to ruin on the ground. as you advise me to make it, maybe I make an L-shaped iron frame I fix the wheels below and above it I interlock the pallet type frame. I would not want to spend a lot I would like to use waste material thanks. sorry for the trivial question. Dolly Metálico Para Palets de 1200x800 Color Rojo Con Ruedas con Freno (Cap, Carga 800 kgs) Longitud - 1200 mm Anchura - 800 mm Altura - 305 mm Carga - 800 kg Peso neto - 24 kg Tipo de ruedas - 2 fijos 2 con pivotes giratorios con frenos Diámetro de los ruedas (mm) - 200 Color Rojo. Marca: KONGAMEK
lift and place roof trusses without crane.
- lift and place roof trusses without crane.
but I was a metalworker, I manage to weld, instead of building the trusses in the workshop or construction site and putting them in place on site, I would like to bring the bars on site and segment them and put them in place as I proceed with the work. were you referring to the master plan at the technical office I think?- lift and place roof trusses without crane.
the shed I would like to make it with a pitch as in the side sketch, climb the beams, cut them, weld them and put them in place and move forward, the truck would cost about 800 € uro per day. the reticular structure, if I make a pitch I could make inclined portals and above it fix the beams on which to screw the roof panels, momentarily I would like to make only the roof without lateral infill. ps DennisCA you could be kind enough to attach some photos and explain to me how you did the job, thank you excuse me if I'm picky and boring, thanks again.- lift and place roof trusses without crane.
hello, sorry for the unusual and odd question, I should close a terrace a flat concrete floor, to eliminate water infiltration when it rains, to overcome this inconvenience we had thought of installing a metal roof, or pillars in the H beam and metal trusses. the truss would have a span of 14 meters, the surface to be covered is about 240 square meters, the attic is on the second floor at about 12 meters above the street level. for logistical reasons, we would like to avoid using a truck crane or forklift, I was wondering, is there a self-erecting solution such as stage for concerts or circus structures, with structure pulleys, winches and hoists, a do-it-yourself solution using waste material, such as scaffolding reinforced similar, thanks to those who want to provide more information. thanks for your kind attention.- weed cutter double blade diy homemade
there are no goats, animals and sheep around, unfortunately human goats as neighbors, the motorized brush cutter is a problem, I have to lend it to myself, transport it with my small car, then the cockpit smells of petrol, while a 2p manual tool does it I hide in a hidden corner and use it when needed. .- weed cutter double blade diy homemade
I built it in the afternoon, only it came very heavy, I took a 30x30 x 2 mm box about 38 cm long, I welded teeth made with 8 mm construction iron, 13 cm long 6 pieces, welded about 5 cm l 'one from the other, in the reverse direction I welded the foil of a 4 cm wide gate spring, as a handle I put a rusty iron tube at the head, like a t-shaped razor rake. I broke it works like a hoe but it is very heavy, from the side of the blade I cut from the side of the prongs I pull the mowed grass and I make sheaves. I did something wrong I'm sure. about 3000 square meters let's say 5000 square meters with the neighboring land, it is aesthetically very ugly and heavy, perhaps the scythe would be more suitable.- weed cutter double blade diy homemade
sorry for the inconvenience, I would like to make a similar tool to mow the weeds and bushes in my garden, I do not have a motor brush cutter, every time I have to borrow it. I think this rake-like tool that cuts like a razor and swings like a hoe could be useful to me, do you think it is efficient or would it be better to adopt a classic scythe? thanks, I wait for opinions and suggestions. DIMENSIONS 40″h × 14.13″w × 2.5″d how should i build it what materials i could reuse - lift and place roof trusses without crane.
