kovacija(blacksmith)
Everything posted by kovacija(blacksmith)
  1. in my place too I can recharge the propane tank on my island but I still can
  2. How did you make that finish? glowing dark color? some liquid or ?
  3. great work guys!!!:cool: Is the heat spread all around or yust around the burner''?
  4. OK today the burner (blower) will be finished! i somehow hooked up the el. motor to the blower (blower is a washdryer part)
  5. I have removed the round stabilizer with forging off and now searching for the el motor to run it now it has a straight axle with no add ons!
  6. hahahah:cool: running away from the chasing dog with 300lb anvil don
  7. in my town there are no garage sales ! :(if a folk sels his house (and my dad do the electricity for new owner) I usualy get lot of hard iron rods...etc and sometimes hammers... but if I don
  8. 1000 Anvils?????? (take a cargo boat and steel all of them...)
  9. I see it would be a nice forge in it...
  10. I found some sort of a blower (in the bush) but I think it will be dificult to make something of it...what about a hair dryer? it has a stand for rotor but the ball bearnig is broken so it jams sometimes i tried to hook it up with a old blender motor (bad connection ) it product a very strong blow (need bigger engine) how am I going to hook it up with an axle ????-of el.motor any suggestions? should I remove the existing axle of "blower"
  11. yes just like i ment... I am not happy too! I will try to make a blower of some sort for the burner... I think it would work...:rolleyes:
  12. Great work! did you make a little hole for nail to hold the handle without loosing the spear? in my country all gaff is made like this it is much safer...
  13. I found a gas burner so I am wondering if is possible to install it into the forge? see pictures above...
  14. Thanks for the explanation... but I can
  15. that is genius! it is what I was looking for-I can connect my wacume cleaner to the water pipe! only i still cannot understand the gas inyection? throug the elbow pipe... What about forged ends of water pipes is it very important how wide are they open?
  16. maybe this is OK - I have all the material- pipes:cool: see in the first post on top of the page-picture
  17. Ok for the burner this summer my paycheck went to oxy-fuel(propane) equipment (aprox. 1000$) but i still haven
  18. I see I had stupid wories about my forge... Now I know why I become a member of this web page-because people like you! thanks for everything! still I have problem with burner My dad has a lot air conditioning equipment ( cooper pipes etc...) and i must figure out how to make a perfect burner... until then salute to all of YOU!:cool:
  19. Thanks for your interest and explaning some things... I know that skoda was produced in čehoslovačka(cehoslovakia) now two countries and the ww2-hitler interest for that country was expecialy for the Iron and Steel in that time they were leading industry for steel.
  20. I think some wool ressistant to fire... if not I have been tested a roof cover wool and it gives a (some ) results 40% not burning teksture and 30 cm diameter is that enough? (for my forge) I have a lot bricks-from el.heaters actualy ressistant bricks for the iterior of forge;)
  21. hello I have a little problem my charchoal forge is too slow and non economic for me so I am going to make a GAS forge so the problem is in my tube for it... my tank (water heater) is made of steel thick 3mm or i think 0,1 inch his diameter is 30cm so the question is: is all that strong enough to hold the tempreture (I already seen all blueprints on this site,...)
