Hi All,
I am working on making a large vise for smithing. I got a bug to make my own screw and nut by semi-traditional means, hence this involves winding a 1.5" diameter rod with 3/16 keystock, paired up so as it is wound, the threads for the nut are created too. I am doing this with my smithing mentor and we are learning as we go. I welded a guide to the rod to help get the pitch correct and tacked the ends of the two 3/16 keystock pieces so they would rest against the guide. Wrapping was done with two people working in tandem with an oxypropane torch and a hammer with the form rod held upright in a vise. It was tricky getting the helices separated and off the rod..it required some hammering in a swage block to slightly expand the coils so they would "slip" off the rod, as well as some precision prying with a screwdriver. Still much more to do.
In the photos I show the fully wound coils on the form rod. The nasty looking bump on the right side is a splice that I mig welded in so as additional 3 foot pair of keystock rods could be added to the coil to reach a full 9" wrapped length. The splice was a piece of heavy gauge sheet steel intended to bolster the butt-welded keystock during the wrapping process. The other photo shows the two coils separated from the guide rod. One coil will be cut in half and forge brazed into a pipe for the nut, the other half will be spliced onto the longer coil and this will be brazed on to a support rod for the screw.
The vise leg and moving arm are made of 4" steel channel and the jaws started from 2 x 2 x 8" mild steel that I machined on a mill. I have welded up the jaws into the channel and learned I am a better grinder than welder. I hope to change that someday :) I will send up more pictures after this weekend. I am enjoying the journey. The vise is less important..as has been pointed out.. I could have bought a decent used post vise already :))
Nicole
