Smokeman
Everything posted by Smokeman
  1. Thanks for posting. I have to make a lilly pad and a frog for a sculpture I am working on. Thanks for posting the how to step by step.
  2. Hi folks, been working on a Koi Fish sculpture for a lady that has a patio next to a Koi fish pond. When all said and done, It will have plate steel for the base. Two large seaweeds and a Lilly pad. The fish will be welded to the metal plant stalks as if it is swimming through them. I probably hand forge a frog to put on the lilly pad.
  3. Hi folks, after years of using a propane forge, I decided to fire up my coal forge. Boy, I should have done this years ago. It is amazing at the heat you can get in a very short time compared to propane. In the pic I was tying my first axe head using coal. I learned my first lesson, if it is left in there too long, it will burn up. With propane, I could watch the color I was getting. Anyway, I found that it heats my shop better than propane..Using a hair dryer for air until I get an old hand crank. Having a great time with coal !
  4. Nice job Waid, if you marry her, you just created a family heirloom that will pass from one hand to another for many years.
  5. My second attempt at a Rams head. The first one I did I snapped the horn off.
  6. Thanks Glenn, I will open it up. Probably help more ash to fall too. Should I put clay in the drum or should I be ok ?
  7. After failing at several attempts to forge weld with a liquid fueled forge, I built this coal /charcoal cracker with some stuff I had laying around the shop. I think it will serve me well.
  8. Made this two panel gate for a customer last month and installed it on his deck stair entrance. My first time using powder coat. Worked out well.
  9. Just foolin around today and made this Snake Knocker. I Still have some finish work to do on it. Take Care, Smokeman
  10. Hey I like that, " A Belt Feed Varmint Buster". I do have a question though, I would like to tackle a .50 BMG. Do you do your own barrels ? Also , what are you getting for a barrel. Thanks Again, nice work on your production line you have there.
  11. Not sure if I am a trained gunsmith, but I do like to throw a rifle together from time to time. Here is a pic of my Mauser that I did. 6.5 x 55 Sweed barrel. Working on two others, Mauser 308 and a total build Chicopee falling block. PS: Nice work on your rifles there.
  12. Smokeman posted a gallery image in Member Galleries
  13. Here it is folks, The finished bird feeder. With the cone on the top. Thanks for your help in making the cone.
  14. Very valuable formula at that my friend. Thanks Again
  15. Nice Job. Cool Setup.
  16. Hey Guys, I made a pattern out of poster board from the formulas that you shared and helped explain. Sorry it took so long for me to figure it out. It Worked out perfect. I will post the bird feeder on this thread when I finish it up and have it powder coated. Thanks Again ! Just shows, never too old to learn how to do something new.
  17. Thanks guys, I think I have it now.
  18. Thanks guys, yes, the post got deleted somehow during the down time. I am not sure how to do the steps after I divided the hemisphere into equal parts. As far as the cone size, 19" diameter on the bottom. Point at the top. The distance from top to bottom, 12". It should be easy, I know you have it there,but I just dont see it yet. Thanks for your help.
  19. Thanks for the information guys. I will try both and see how I make out. Thanks Again !
  20. I need to make a sheet metal cone to put on top of a large bird feeder. I do not know how to make the cone. The cone is 19" round at the bottom and the top is to a point. The height of the cone is 12" top to bottom. Thanks for any help.
  21. Been a while since I have been here. I hope everyone is doing fine. Here is my Shop Forge that I have been working on. I did manage to fire it last week. Works well. Need some fine tuning though. My pesticide blower did ok for a test drive until I find a nice one. Happy New Year Folks.
  22. Thanks for the incentive curly. I think I will take the weekend and do the same.
  23. Thanks for your input guys. I'll try a few of the methods that you posted and see what works out the best. Thanks Again !
