Everything posted by GobblerForge
what is it??
They are also used on grader blades called scarifiers. The tips are carbide and can not be forged. If they are brazed on then they will come off when you heat them in the forge. I tried. The steel is some pretty good steel. I don't know what. Gobbler
Fireplace Cranes
I've used the vertical hole method with two variations. One uses a hole drilled in the hearth and a hole drilled deep into the lentil, as recommended earlier. The other used a hole drilled into a plate. The plate was then pinned to the hearth with rivets for pins. Gravity does the rest. The one problem I have with anchors that put internal pressure on the hole sides is they can and have broken masonry. Stone compresses great but fails with tension. Gobbler
Double Duty blanket pin
Make the broach out of file steel and then harden in bacon grease. No tempering required. I've made lots of them this way and not a one has broken. Perhaps the side worn toward the body could be the strike surface and not mar the show side. Gobbler
Humidity and forge welding
I have noted over the years that forging on rainy days, when the humidity is in the 90's, that I have more difficulty getting the fire as hot. I attribute this to there being more water in the fire, thus cooling. On dry days it's a little easier to forge and work the fire. On a related note, my shoulders hurt more when I work on a rainy days as well. Gobbler
Colors of temperatures
Will this work? Gobbler
Old way of cutting railroad rail
Localised heat and bent by hand I would think. Gobbler
I have a box of those cartridges in my collection. I would like to see the tool that does this job. Sounds frightening. I've only seen drawings of it.. Gobbler
Old Machinery
Just a thought, but I would consider finding out what some of these old tractor parts are worth to the tractor collecting community. You may find that selling the parts to a collector or dealer may make more money and will buy more stock than the tractor produces. Gobbler
can you convert a log spliter?
When the gallery gets running again, look in Gobblerforge gallery. I used hydraulic parts to build my tire hammer. Gobbler
Deer Skin Apron
I made my apron 18 years ago out of a deer hide. No problems yet. Gobbler
Shop signs
My hooks actually swivel. The lady that took the photos positioned them to her liking for the pic. Gobbler
Shop signs
I tend to hang my horse shoes at an angle so a little luck spills into the shop. Here's my signs. The wood sign is portable to hang at demos. Gobbler
show me your anvil!
- Make a hot cut hardy
On the topic of hardening and tempering, I would say yes to both. The time that the hot steal is in contact with the hardy isn't enough to take out the hardness. There is a lot of mass there. Gobbler- Railroad track anvil?
As Ironstein said, wrapping a chain around the waist of the anvil a time or two will absorb vibrations. Don't over tighten the chain. It works better if lose. In the pic you can see I use the lower chain to hold the anvil to the stump and the upper chain to quiet the anvil. When people ask why, I tell them it's just a mean anvil and I have to hold it back. Gobbler- Hay-Budden List
150lbs. With stump, chain and tools, right about 200. Gobbler- Hay-Budden List
#200984 dated to 1913 per AIA. Gobbler- setting railings in granite steps
What is the issue with pouring lead? Gobbler- my Hay- Budden?
WD40 won't hurt anything. Any oil is good. Some are just better. Gobbler- Hay-budden anvil
You are correct. I meant forged steel, not cast steel. I don't know what I was thinking there.- Hay-budden anvil
On this particular anvil I suspect you will find the weld line about mid-waist. It should be all cast steel the entire top half of the anvil. HB started doing this in about fall 1908. They were experimenting with different methods at that point in time so I would expect to find different examples. Gobbler- Those who demo
Condratulations, Grampaw. That is as cool as it gets. Gobbler- my Hay- Budden?
If we can get the serial number, it can be dated. If it is a HB and has the center weld line, then it is most likely 1909 or after. Gobbler- my Hay- Budden?
He didn't say edge. He said the whole bottom was wore flat. By what? Wouldn't it have to be on something moving for a long time to wear flat? I just don't get it. I've seen hundreds of anvils, same as a lot of folks here, but never saw one where the bottom was worn. Only the top. Gobbler- Those who demo
I guess, your welcome. I just finished two back to back three day demos. One at Atwood Lake Fall Festival and Algonquin Mill Fall Festival. I love showing and teaching. That's why many of us do what we do. Making a little cash never hurts to inspire more work but the demo is the real reason. Ohio's fall colors don't hurt either. Gobbler - Make a hot cut hardy
