heat treat titanium
actually i was planing to make a dive knife.i am going to anodize to change to colors.i have i friend in Cleveland who has a computer control gas kiln to anneal glass. will that work to heat treat it. i knew it would be soft before i bought it. if no one here knows how to heat treat ti that is ok. i could not find much any where.
heat treat titanium
i recently bought a 2 ft by 1/4in by 1 in section of t6-4 grade titanium. i want to make knifes out of it i want to know if it is necessary to heat treat it, if so how do you do it right. i will show you pic of it finished. and i assure you i am not trolling i will even post the link to where i bought it. i did the spark and anodize test it came out positive of ti. http://www.ebay.com/itm/Ti6-4-TITANIUM-FLAT-BAR-STOCK-1-X-250-/130424374788?pt=LH_DefaultDomain_0&hash=item1e5de60604
Is it possible to melt and cast railroad track steel?
it can be done but most likely not by you my anvil is cast iron made in some factory in China. so they are pumped out by the thousands. so yes it can be done but most likely not by you. if i absolutely had to i would legally mix a 3 to 4 ratio thermite and ignite that and have the motlen iron flow into my cast. i would not do this because not only would it be hard to mix all that any thing could go wrong. and the words thermite and oops don't mix.
Simple tips for the shop
i add charcoal powder to the anvil surface. it does not add carbon. but what it does do is it give me a better working time. it prevents heat being transferred from the hot iron to the anvil.
Small hand ax
looks nice
Bent Blade
i would heat it up then sandwich it between 2 wooden blocks in a vice and then tighten. then heat treat it back to normal.
silver cleaner
i found out something you should want to try. i do not know what is happening on a molecular level. what i did was add = parts salt and baking soda into water i dissolved as much as i could. i put in my tarnished pice of silver. nothing happened so i thought to add current to it so i placed in my aluminum wire with out power and in front of my eyes the tarnish went away. if you add current it will work even faster.you can do this with any al even foil. you should try it if you have tarnish silver. just make sure not to touch the al to the silver or it will not work. i hope you enjoy this it is amassing in person. i know this is some sort of electro chemistry but i am not sure on what is happening.
rr spike hawk 3rd try
does any body here know what on like the one in the pic might be worth
Of course you know this means war!
i would make the body out of 1/8 in stainless steal with 2 in angle iron as corners and half way through 1/2 in square tube rib. as for the flag i wold use a rail road spike with the fat end hammered to the same thickness as the spike. you might need more ribs though. for the post i would use 2 in square tubing. i hope this gives you some ideas
Journeyman with no where to go
i live in Cleveland ms 2 and a half hours away from Brandon but unfortunately i have no place for you to stay and very little skill.
i understand your concern.31% is commercial grade hcl $4 a gallon. if i want a weaker solution i will have to dilute it. i still have to work with 31%. so the way i look at it either way i have to work with strong acid. one is faster at etching. either one if i get it on my skin i am getting burned. so it is better to just take proper safety measures, and work with the stronger acid.at least in my opinion.
making a hole for handle
you have to make sure it is perfectly even. a small bit off will rely mess you up. happen to me with my first hawk.
Closest finish to raw polished steel
looks nice good work
- tomohawk Pic 2
- tomohawk Pic 1
