Mark Wargo New2bs
294 -
Everything posted by Mark Wargo New2bs
Well, the weather wouldn't cooperate for making charcoal today. As the wind died down late, I decided to try using corn for a fuel. Worked like a charm and allowed me to forge my first "S" hook. I know I didn't clean up the hammer marks too well, but I was having a hard time seeing since it had gotten dark. Otherwise, please let me know what ya think. Mark
Charcoal vs. corn
Mark Wargo New2bs replied to junker's topic in Solid Fuels: Coal, Coke, Charcoal, Wood, etc
Tried forging with corn tonight for the first time. I used approximately 12 pounds of corn in an hour and a half. So buying bagged deer corn at retail which is $6 for 50 lbs, I used about about $1 of fuel per hour. This was in my brake drum forge powered by a $5 oscilating fan from Wal-mart. It quite rapidly heated the stock I was working with. I was not as efficient with the fuel as I could have been. I've only forged with charcoal, so managing the fire took some learning. As noted, the underside of the fire will burn up leaving a "cavern". That takes a bit of getting used to. Mark -
A few weeks ago I stopped by a railroad and talked to a workman about legally aquiring a piece of rail. He told me that a fellow took a piece last year and was prosecuted and warned me not to pick any up. He did give me a number I could call to inquire. Mark
I came across this picture of a Champion Blower mostly disassembled. From reading I have noted several folks wondered what they looked like on the inside. I hope this helps those who are interested. Mark
Update: After some elbow grease I can make out "Made in Sweden" stamped just above and to the right of the weight. There is some type logo above and to the left of the numbers, but I think it is going to be too badly damaged to make out completely. I will continue to sand on it until I get it relatively clean. The anvil has been welded onto it's stand, so looking at the bottom is out I'm afraid. Mark
Hopefully I've figured out how to attach photos...Here is the forge setup, work table with vice, and my two anvils. I'm told the table is the piston from a steam locomotive. It weighs about 640 lbs. My forge and tools are modest, but I've cobbled them together since I started in October of this year. Mark
Make a hot cut hardy
Mark Wargo New2bs replied to ofafeather's topic in Hot Cuts, Anvil devils, metal cutting on the anvil.
Thanks Nakedanvil. I guess in my mind I thought it might try to squeeze down into the hardy rather than upset if that whole end remained hot. -
This is a very informative thread. Nakedanvil, in order to upset the middle of the hardy hot cut after tapering the end, did you heat the center, cool the tapered end then use a sledge on it while in the hardy hole? Mark -
Definitely start with stock that is long enough to make both halves of the tongs and work one end at a time. I bought 4 feet of 1/4 inch by 1 inch stock and cut it in half, that way I could work both havles at the same time to keep them similar while having plenty of cool handle to hold on to. In my brake drum forge, I have no problem heating just the end that needs to be worked. I haven't cut out slots on the side of my forge, so to heat the center I have to pile the charcoal in there. Check every flea market and antique shop you come across and ask people at work. (Carry pictures of what you are looking for, because we are two generations removed from people who actually did this stuff and most folks look at you funny when you say your are looking for blacksmith tongs). Also, everyone at work who "goes yard saling" has permission to purchase tongs sight unseen for around $10 and I will buy them no questions asked. For me, a distant relative found one set in his barn and donated them. I bought 1 set of bolt head tongs that were hanging on a fence for $2. I bought one set of tongs for $12.50. I'm making my first set now. Trying to use channel locks and vice grips got frustrating really quickly for me. Good luck with your own tong search! Mark
Converted Ball Peen
Mark Wargo New2bs replied to S.Willis's topic in Axes, Hatchets, Hawks, Choppers, etc
That is absolutely fantastic! -
Small Ball Peen Hawk
Mark Wargo New2bs replied to aablades's topic in Axes, Hatchets, Hawks, Choppers, etc
Neat! Nice use of the old hammer. -
ball pein hawk
Mark Wargo New2bs replied to weldervaughn's topic in Axes, Hatchets, Hawks, Choppers, etc
Very Nice! -
charcoal
Mark Wargo New2bs replied to Bigcity's topic in Solid Fuels: Coal, Coke, Charcoal, Wood, etc
I use charcoal (natural hardwood, not briquettes) in my brake drum forge. I get the air from a $5 oscilating fan from Wal-mart and that gets it plenty hot. You will go through quite a volume of charcoal relative to coal. -
Thanks much. That was very educational! Mark
Thank you guys for sharing your time and knowledge with me this weekend at the craft fair in Jackson. I really appreciate getting to pick your brains regarding hammers. Thanks also for talking with me about the forge welded cable knives and heat treating. Mark
Cross Pein Vs. Straight Pein?
Mark Wargo New2bs replied to Mark Wargo New2bs's topic in Hand Hammers
Thank you all for your insight. I went looking around this weekend for blacksmithing tools at flea markets and antique shops. By pure luck I happened upon a demonstration by the Mississippi Forge Council. Those folks were very informative and discussed hammers with me and allowed me to get a feel for each of the hammers they had available. A big thanks to those guys for their knowledge and hospitality! Mark -
Starting to Feel Like a Blacksmith
Mark Wargo New2bs replied to billp's topic in Blacksmithing, General Discussion
congrats! I too have started out in similar fashion a couple of months ago. I started with a dug hole and a 1" steel pipe blowing air with a fan. I moved up to a brake drum off of a 4x4 that is now mounted on a portable expanded metal serving cart with black pipe plumbing. I've started my search for blacksmithing classes and I thank you for your testimonial regarding the benefit of such. It's really helped push me in that direction. Good luck on the road of smithing! Mark -
Also, Arftist, my thinking was along your method. It feels more natural for me to hold the material and the hammer at 90 degree angles. That places me closer to the work, and helps me better see what I'm doing. -
Thanks for the perspectives. As a novice, I just wanted to get some ideas about what might work best. I don't want to develop bad habits, or use shortcuts when I need to be learning something valuable. Up to this point I've been using re-handled pawn shop hammers. My wife is ordering me a 3# cast hofi hammer, so I can look forward to using that when it arrives next year. In the mean time, I'll develop the skill I can with the cross pein and improve my muscle development and hammer control. P.S. I drive a Toyota Tacoma and shoot a Tikka T3 .270 Winchester Short Magnum. :D -
Very nice!
I've been using RR Spikes to work on my blade forging. Plenty of internet research and youtube videos has helped. My interest is in forging historically acurate weapons (though not necessarily with historically accurate methods /hug grinder). I've mainly forged bodkin arrow points and RR spike knives to learn the feel of moving metal. So from a complete novice perspective, you can begin learning on blades. I think the major concern many would have would be the exacting standard most people expect from blade work and the frustration that might develop from not getting it right in the early stages. A less than perfect hook will still hold things, a less than perfect knife might not function correctly. I learn best by absorbing a lot of information and forming a cognitive schema, then jumping in to gain practical experience, then returning to the information to adjust my construct based on what I learned hands on.
I have been very fortunate. My great uncle was a rancher and did his own smithing out of necessity. He has since passed and his property was recently sold off. The new owner graciously gave me the only remaining piece: A 600 pound work table made from a complete piston from an old steam locomotive. My uncle had hand drilled and tapped the side to accept a steel vise. Our county judge donated an 1899 Fisher anvil that used to weigh 155 #, but which had the end with the hardy hole knocked off. This week, I was the proud recipeint of what appears to be an all steel anvil of 156 #. I've yet to find any identifying marks. both anvils were used in farm shops, so have some damage from welders and one has some melting near the step (I suppose from a torch). Both are far superior to the 30 # railroad track I was using, as you can imagine.
Very nice. Realy like the way you drew it out.
