Everything posted by bnewberry
Viking sword
Beautiful work right there!
Flock of little Vikings...
Very nicely done and finished!
Grinding Practice
Practice really does make perfect!
Seax Design critique
On the handle, you might find that having the center section larger in diameter than the two ends results in a more comfortable grip. I'm looking forward to seeing the results, especially what you do with the wrought iron. I have some that I've been saving for a special project.
homemade hickory scales
+ 1 This is good advice!
Show your first knife
I made these two knives at the same time for my first. I had wanted to make a knife ever since I was a kid. I finally decided to do it. These were made mostly with a belt sander. Handles are desert ironwood. I had these professionally heat treated but have since built my own forge and handle that myself now.
Great video of a Bladesmith in action
Wouldn't you have loved to shake his hand? I bet he had a grip of iron. I can't imagine two gross of knives in a day's work. That is simply amazing.
That was a really interesting video. Amazing what a man can do if he repeats something a few million times. I liked the pride he had in the knives he makes as well.
Working with antimony question (total noob)
I'll tell her thanks for you. Be careful and be sure to show us pictures when you make something!
My chemist wife tells me that antimony is kind of toxic. Be sure to check out to be sure you can safely work it and wear it. Here is the MSDS http://www.usantimony.com/msds_metal.htm Looks like inhalation, eye contact and skin contact Re not recommended.
Neck Knife Changes
Very angular and interesting. I would cover the tang with the lanyard hole with wood. You have plenty of curve for the kydex to grab.
Neck Knife Changes
Neck Knife Changes
Multiple posts. Sorry about that! I hate it when this happens!
- Blade from a ``fresh`` smith.
My last batch of knives for the year.
All nice, but I love the sheep horn! That really is nice.
Upsized Interpretation of the Grohmann Classic Canadian Belt Knife
Thanks!
A new short sword question
If you can get them cheap, files are a good starting point when you try your first few blades. But if you really want to make a knife, use steel that is known to you. Otherwise the heat treat is a longish trial and error or a guess. Don't get me wrong, old files are lots of fun and I've made a few small knives with them. But when I really want to make a knife, I don't start with an unknown steel. On edit: what you want to make is more of a short sword. There are better steel choices for a prybar/knife than a file!
Old style polishing...
Rottenstone, which I think is powdered pumice.
how do you forge a bevel on a straight blade
I put a downward bend in the blade before I begin forging the edge. This compensates for the inevitable movement of metal as you forge the bevel.
Steel is 50100-B. Scales are desert ironwood.
Garden hoe head
That is nice work. Itnis tough to find good hoes these days. Most just use a shaft that get friction fit to a hole in the handle.
SAN-MAI KIRIDASHI
Nice work! The weld looks good and the knife flows very sweetly.
Stock removal on this one, but I did heat treat it in my forge.
W-1 and Moose
I haven't tried this, but I have heard you can seal it with something. Crazy glue or poly or something like that to get a a shine on old dried bone. Good luck!
Making Chain Saw Damascus
The top and outside edges are typically chromed. That way the chrome does come off when you file the working edge. At least that is what I was taught in a chainsaw class.
