meteorman Posted July 8, 2012 Share Posted July 8, 2012 first question from a complete noob building my first small firebrick forge, with a 1/2" black pipe tee burner. The forge will have a welded angle-iron external skeleton/ frame, tightened up with all thread. It likely won't be taken apart or reconfigured once assembled. It will see occasional uise for heat-treating and forging of small parts for custom muzzleloader guns. would there be any thermal efficiency or advantage to coating the inside surfaces of the soft firebrick with plisitix 900? thanks for any insight... great site ! /mike Quote Link to comment Share on other sites More sharing options...
WayneCoeArtistBlacksmith Posted July 8, 2012 Share Posted July 8, 2012 Definately coat either hard or soft brick with Plistix. You will be amazed at the difference. I suggest that you build the forge and use it, timing the length of time to get to forging temp. Then paint it with Plixtix or Metrikote and time it again. I suspect that you will see that with the Plistix it will take about half the time. Now, what does that mean? You will work twice as fast, use half as much gas,,,,,and work twice as hard. Quote Link to comment Share on other sites More sharing options...
kevin1050 Posted July 13, 2012 Share Posted July 13, 2012 Do it! When I re coated the inside of my forge I did the fire brick too. Works like a charm. Plus you can get it from the guy above me, Wayne Coe. Quote Link to comment Share on other sites More sharing options...
meteorman Posted July 16, 2012 Author Share Posted July 16, 2012 Still working on my tiny little forge. wondering if its obvious I need to tune the 1/2" tee burner ? this is the flame with the temporary black iron flare: i then procured a 3" piece of stainless and flared it a bit and now the flame looks like this (at fairly high pressure - just under flame-out); this is with a .023 MIG jet, 4" black pipe, plus about another 1.5" of SS flare sticking past that. heat chamber will be formed by these two firebricks assembled together, which will be surrounded on all sides by more bricks in final design. Chamber will be about a 3"x5" oval, about 8" long and coated with Plistix. Am i in the ballpark ? thanks for any tips, MIke Quote Link to comment Share on other sites More sharing options...
Ramsberg Posted July 21, 2012 Share Posted July 21, 2012 The burner will operate differently when it is actually shooting its flame into the forge. In other words, if you get it to burn perfectly in the open air, it won't burn right in the forge. You won't know what adjustement to make until the forge is done and the fire is blasting into it. Caleb Ramsby Quote Link to comment Share on other sites More sharing options...
rlonstein Posted July 21, 2012 Share Posted July 21, 2012 Looks good. I found the Plistix made a big difference. It cut heating time on a piece of 1/2" stock by about 40% vs. uncoated. Ramsberg is right about the adjustment, you'll have to readjust once it's in the forge. Quote Link to comment Share on other sites More sharing options...
FruzzinForge Posted January 11, 2022 Share Posted January 11, 2022 On 7/8/2012 at 7:24 PM, WayneCoeArtistBlacksmith said: Definately coat either hard or soft brick with Plistix. You will be amazed at the difference. I suggest that you build the forge and use it, timing the length of time to get to forging temp. Then paint it with Plixtix or Metrikote and time it again. I suspect that you will see that with the Plistix it will take about half the time. Now, what does that mean? You will work twice as fast, use half as much gas,,,,,and work twice as hard. Hi Wayne, I'm new to forging. me and a buddy built one with "Insulating FireBrick 9" X 4.5" X 2.5" in (6 Pieces)" from Amazon in 2020. Never thought to coat it, because it is just brick (as far as I know). Move to now... I got a Diamondback forge for my Birthday and started researching the brick they use. I wrote them and they said that I don't need anything. Hard to believe because the Safety Data Sheet on them says differently. So now I am in pursuit of finding the best sealer and came across Plistix 900f (which is hard to find. At least on my end). So the question is... should they be coated or not? Should I believe the Sheet or the seller? Hmmm. Any info greatly appreciated. Quote Link to comment Share on other sites More sharing options...
lary Posted January 11, 2022 Share Posted January 11, 2022 Check with Glenn, I've purchased Plistex from him. Quote Link to comment Share on other sites More sharing options...
pnut Posted January 11, 2022 Share Posted January 11, 2022 I coated the brick I use as a door with Plistix on the side exposed to the forge. It's more durable than I thought it would be too. It fires to a hard finish. I also coated the entire interior of my forge with it. PM Glenn. He can help you out. Pnut Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted January 11, 2022 Share Posted January 11, 2022 11 hours ago, FruzzinForge said: should they be coated In a word, absolutely, if you want the best out of the forge. Quote Link to comment Share on other sites More sharing options...
DennisCA Posted February 12, 2022 Share Posted February 12, 2022 Where can I buy some plistix, doesn't seem to be available in europe. Quote Link to comment Share on other sites More sharing options...
silversinksam Posted March 15, 2023 Share Posted March 15, 2023 On 2/12/2022 at 2:39 AM, DennisCA said: Where can I buy some plistix, doesn't seem to be available in europe. I know this is a year old thread, but the info is still good my friend. In Europe it's called Plico®️ Stix 900 F Quote Link to comment Share on other sites More sharing options...
