FieryFurnace Posted March 3, 2009 Share Posted March 3, 2009 I have a broken fencing epee that I want to repair. The tip broke about 9 inches from the very end and it broke off flat. My guess is an over hard spot in the blade. (don't know what took it so long to brake as me and some friends have done some REALY hard and fast coriographed (SP?) fights with it) I want to weld the tip back on so that it can be used for light coriographed/practice fights ONLY. NO, go at your buddy and try to run him through, fights!!!!!!! I figured if I welded it, the part right at the weld would be something like annealed if I let it cool in the air after welding. (Or on top of a dying forge fire.) Then what. I can't re-harden/re-temper the whole blade. Is there anything I can do for just the tip where I weld it? Can I leave it "annealed and would it work ok for light planned sparring? Once again I am not going to use this for thrusting into the body after/if I fix it. ANY thrusting will be either parried or will be thrust inbetween the arm and body as a "planned" fight. However I don't want the tip to be constantly bending. Thoughts??? Thanks!!! Dave Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted March 3, 2009 Share Posted March 3, 2009 to re-tip at the break is fine, but do not weld, it still dangerous. Illegal in competition, and unsafe for controlled moves as well, a slip and.... Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 3, 2009 Share Posted March 3, 2009 Fencing blades are made from a very special type of steel and the heat treat is not a "top of the forge" type of thing. As peoples lives are at stake I would advise you to make a shish kabob skewer from it and use a new blade. Really they are quite cheap compared to *1* ER visit even for just a couple of stitches! Quote Link to comment Share on other sites More sharing options...
Frosty Posted March 3, 2009 Share Posted March 3, 2009 As said, retipping is fine but attempting to weld the broken part back on is an invitation to disaster. Fencing blades are of very specialized steel designed to break in a safe manner, the flat break you experienced for instance. Trying to weld it back on will produce unpredictable results, it may fail just sitting there let alone swinging it around, even slowly. This is a BIG don't do it, even if you only want to hang it on the wall, you can't predict what will happen in the future, it may get sold at a garage (your estate) sale, stolen, anything can happen and someone unaware of it's repair may attempt to use it and get run through. Frosty Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted March 3, 2009 Author Share Posted March 3, 2009 OK! Advice headed! How do I "retip" it? Is that upsetting the end or welding a ball on the end?...or none of the above? The broken blade is about the length of a standard cutlass now, so if I could retip this one I might downsize my other one and retip it too. Then forge some more traditional looking handguards for reenacting purposes. What size tip do I need? Thoughts??? Thanks!!! Dave Quote Link to comment Share on other sites More sharing options...
FieryFurnace Posted March 4, 2009 Author Share Posted March 4, 2009 (edited) Or how about just putting the orginal rubber safety tips on the broken end, (After it's filed smooth) surrounding that with, say tire tube rubber, and duck tape the hole thing on the end? I taped the original safety tips on the ends before because they kept slipping off and I was afraid that one time I wouldn't notice untill too late. It seemed to hold up well. I only suggested putting the extra rubber on the end since the shorter blade would be a little stiffer. This would exclude any welding or whatever to retip! Once again I'm not going to be slamming them into my buddies boddy. Even in the coriographed fights I'll keep it slower now. Edited March 4, 2009 by FieryFurnace Quote Link to comment Share on other sites More sharing options...
rokshasa Posted March 22, 2009 Share Posted March 22, 2009 to retip the sword would be to put the end back to a point or ball the tip , you cant really add any "material" at this point, it would be very dangerous to use. Quote Link to comment Share on other sites More sharing options...
