TCooper Posted February 8, 2009 Share Posted February 8, 2009 Hello all, I have been making knives for about 15 years using the stock removal method. Forging has always fascinated me and due to setting up a new shop I now have the room. I'm looking for any advice. Also every book I've looked in and read shows a small brake drum forge and a railroad track anvil, is this what I need to start with. I was thinking of building a gas forge, but after reading through this forum I'm not sure which direction to go. Thanks, Troy Quote Link to comment Share on other sites More sharing options...
Rob Browne Posted February 8, 2009 Share Posted February 8, 2009 For a toe in the water on small blades have a look at Charcoal Forge and while you are there a general look around is really worthwhile. As for the anvil, a length of railroad iron serves the purpose very well. We often get too into the gadgets in our hobbies. Later, if you continue forging a "real" anvil is worth it. Good luck. Quote Link to comment Share on other sites More sharing options...
Dave Hammer Posted February 8, 2009 Share Posted February 8, 2009 Before you build anything, I suggest you find the closest blacksmith guild and go to a couple of their meetings. Take one of your knives as a show-and-tell item and talk about what you would like to learn to do. I suspect you may get some hands-on experience with one or more types of forges. Then decide what your next step is.... Good Luck.... Quote Link to comment Share on other sites More sharing options...
jayco Posted February 8, 2009 Share Posted February 8, 2009 First, welcome to IFI, Troy! One way to look at the problem would be to figure out what fuel is available to you. Coal, natural charcoal(not briquets), and gas are all good fuels and can be used for bladesmithing. Gas is convienient: Light it and go.....and the neighbors don't complain about the smoke. But, it can be costly. If you can find good coal locally, it makes a good economical fuel for forging. If you have access to plenty of scrap wood and can cook it in a barrel in the back yard, you can make your own charcoal to use. You can make solid fuel forges from lots of stuff besides brake drums......my main forge for 35 years was an old 20 in. truck rim with a little fire pot under it. There are plenty of ways to make coal/charcoal forges from ' found stuff; My 2 cents worth....... Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted February 8, 2009 Share Posted February 8, 2009 (edited) Every book?... every book I've looked in and read shows a small brake drum forge and a railroad track anvil, is this what I need to start with. I was thinking of building a gas forge, but after reading through this forum I'm not sure which direction to go. Troy On one hand it is true that a brake drum and a piece of rail would work. In a similar vein, a teenager could try skateboarding by by attaching old metal rusty skate wheels to a bundle of sticks tied together. *However* if that teen's first experience with skateboarding was with a nice skateboard, he/she would more likely continue in the sport. Rusty wheels on a bundle of sticks would likely discourage all but the most determined of teens. The same is with blacksmithing. Find a local blacksmithing club and try their equipment before deciding what equipment to acquire. The better the equipment you have, and the better the instruction you have, the better experience you are likely to have, and the better informed decisions you can make on what equipment to acquire. That is my advice. KENTUCKY BLACKSMITHS' ASSOCIATION * Pres: Andy Bennet, Jr. PO Box 366 Brandenburg, KY 40108 (270) 422-3107qmnforge127@msn.com * Ed: Larry Zoeller 4312 Lahnna Dr. Louisville, KY 40216 (502) 361-0706zman59@earthlink.net *The Kentucky Blacksmith Association : ABANA (Artist Blacksmith Association of North America) affiliate. Edited February 8, 2009 by UnicornForge Quote Link to comment Share on other sites More sharing options...
TCooper Posted February 15, 2009 Author Share Posted February 15, 2009 Not trying to sound too stupid here but, I have a rather large vice that has a decent sized flat spot on the back of it. Would it be o.k. to use that for an anvil? Quote Link to comment Share on other sites More sharing options...
Dave Hammer Posted February 16, 2009 Share Posted February 16, 2009 If the surface area is large enough to accomodate your efforts, give it a try.... It's going to be as good as any other alternative to a real anvil. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted February 16, 2009 Share Posted February 16, 2009 many vises will not hold up to real smithing, short term is one thing, heavy hammering will sooner or later kill it. Welcome to I Forge Iron Quote Link to comment Share on other sites More sharing options...
TCooper Posted February 16, 2009 Author Share Posted February 16, 2009 Here are some pictures of it also. I definitely don't want to tear it up as it was my dad's. Quote Link to comment Share on other sites More sharing options...
Finnr Posted February 16, 2009 Share Posted February 16, 2009 Don't use it to forge on. Scrounge up a piece of RR track or something. That's one sweet tool there. Finnr Quote Link to comment Share on other sites More sharing options...
SK-Buckwheat Posted February 16, 2009 Share Posted February 16, 2009 (edited) Not trying to sound too stupid here but, I have a rather large vice that has a decent sized flat spot on the back of it. Would it be o.k. to use that for an anvil? I wouldn't do it if I were you. It will break. I know because I broke one just like that....then I had to weld it back together. I was fortunate that I had the knowledge and the equipment to fix it. Many lack one or both of those unfortunately,....find something else to beat on. Edited February 16, 2009 by SK-Buckwheat Because I missed a point. Quote Link to comment Share on other sites More sharing options...
