Whiskeysup Posted February 7, 2021 Share Posted February 7, 2021 Am planning to cut a bourbon barrel in half, the water will keep it from leaking. The other half will be for coal storage. Guess I can always add a bucket to it if frozen or use a stock tank heater. Figured water would be handy for wetting the coal as needed, cooling parts while forging etc. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 7, 2021 Share Posted February 7, 2021 Depends on the coal; I've used some that I never used water with and other coal that was kept in a water filled bucket. Getting good coal is harder out here so I mainly use propane these days and save my good coal for special projects. Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted February 7, 2021 Share Posted February 7, 2021 3 hours ago, Whiskeysup said: the water will keep it from leaking. For a while it will but in the long run the barrel bottom will rot out. I have used half whiskey barrels in the past and they only last about 5 years before needing replaced. When they start leaking I convert them to planters. I finally decided the barrels were much larger than I needed and switched to a composite sink one of our members gifted to me, just had to make a stand for it. For a couple of years, I would put a small tank heater in it to prevent freezing, then thought why not just pull the plug and empty it in the winter. The drain pipe is run outside the shop so no problem with a mess inside. Quote Link to comment Share on other sites More sharing options...
arkie Posted February 7, 2021 Share Posted February 7, 2021 I hate refilling slack tubs, that's why I use a heater.....plus, I have to carry my water about 90 feet to the shop...that would get old fast and my old back wouldn't appreciate it! Quote Link to comment Share on other sites More sharing options...
Irondragon ForgeClay Works Posted February 8, 2021 Share Posted February 8, 2021 I leave it filled spring, summer & fall, just empty in winter. I have a cover for it to keep critters and errant steel out when not using it. Mine is only about ten feet from a hydrant so I can fill it with a hose. If I'm working on a project in the winter (not often anymore) I just put the heater back in it. Quote Link to comment Share on other sites More sharing options...
