UPDATE: First Pair of Tongs
So, I got some forge time in, and I finished my first set of tongs. I think that they turned out great, and it will be a lot easier to make more in the future. Let me know whatcha all think.
9604.attach
9605.attach
9606.attach
Use them for awhile, think about what works and what doesn't. Take that knowledge and make another pair. Welcome to the world of smithing, you can never be good enough!
John
That's a great effort. I would say that most people's first efforts never see the rivet stage let alone being used. Don't be afraid to heat them and set them up for your current jobs so they work properly. That is one of the best things about your own tongs, you are not afraid to change them.
I made these because I saw no reason to pay for something that I could make. When I bought my anvil, the guy was trying to sell me all sorts of crud. I politely told him that I could make a pair of tongs, he said, (quite correctly) that you need a pair to make a pair. I told him that that was what god invented vise grips for and that I did not want to purchase them, thank you.
Best,
Archiphile
Vice grips are possibly the worst known substitute for tongs; it is impossible to feel whether the metal is slipping until its too late, they are too short and you can't easily change the position of the grip. Making tongs is a wise safety measure and it's good practice.
Good work. What you can do now is modify the jaws to fit the stock you will make the next pair from. As you make more tongs you can customize each pair for a specific size stock or specialized task.
I was just sitting here and thinking about how to make more tong to fit and BTW these fit the stock that I plan to use for my next pair already. That is why I made them. I hate VG but that is what I had and it they have served there purpose.
I made my first pair in class and they weren't great but I learned a lot. I've been watching You Tube and picked up some tips for my next batch.
Jim
Do you have any links to the youtube vids. I've been trying to view as many as I can find. Thanks.
BTW Good job Moose!
Just for the badness of it I'll chuck a pebble in the water.......
I'm afraid your man was WRONG. There IS a way to make a pair of tongs without using any tongs, or tool that does the same job as tongs. I know more that one way in fact but for fun lets see how many ideas folks who haven't made many tongs come up with. Use some modeling clay to try out ideas.
One way would be to start with longer stock than you need and then cut off the formed piece when it's at the correct length, punch the rivet hole, rivet the 2 pieces and off you go.
That was my point. Do not try and sell me stuff that I do not need or can make myself.
No arguments here. If you search the forum for threads on injuries or burns you will find at least one poor soul who didn't know that untill it was too late. I've been using a small pair of pliers with the teeth ground off and a large set with the teeth ground off and the tip rounded for scrolling. They work great. I like how short they are. I hate long tongs. They're too heavy and I don't like how far I have to be away from the anvil. Needless to say I have a kevlar glove and an apron to keep the heat and scale off.
Yeah!!!!...... Unless you try to sell it to me for a really good price! :mad:
archiphile, One thing to keep in mind though is that if you get a chance to buy good tools for dirt cheap do it. I was able to get 22 pairs of tongs for about 3 bucks a piece. Still will make some of my own but I now have more time to work on other things.
I took a pair of vice grips and welded a nice long handle on it. They actually work very well for heating stuff up with a torch and they are rock solid! Problem is vice grips are only great for localized heat. You go and put them in a forge and the first thing to always go is the dinky little spring. Once the spring goes the never hold right. Now if you could figure out a clamping style without the spring that held as well as vice grips that would be something. I've used tong clips and though they hold really well I don't think they could ever hold as good as vice grips. Vice grips also have those sharp teeth though and that usually means marred work unless you tend on cutting that part off or hammering it. So in short vice grips have their time and place in hot localized work but not much use in forging.
Hi all
Couple of tips on tongs.
-Make the reins thicker towards the eyes not thinner, thats where they will break first, taper the reins more as you get away from the jaws.
-Right handed tongs look better than left handed tongs, right handed tongs are when they are laid flat the top rein goes to your right hand.
-The other place most tongs break is where the jaw joins to the eye, try to have smooth radii on all these joining fillets.
-Set your reins parallel to grip the stock you are working, don't have the reins set pointing in or out.
-If you are going to use tongs to forge under a powerhammer use a link to hold the reins together, many a smith has got the scar running from his mouth upwards to his eye. Thats caused by the tongs flying up and hitting the face when the job has come out of the tongs and they have flicked up. I missed and got my eye brow 40 stiches (20 internal 20 external) depressed fracture of the skull.
-Always inspect your tongs before use for cracks and other defects.
-Not a criticisim but an observation, the tongs shown have the reins leaving the eye on the same side as the jaw, they should be offset.
-Good work they are about 500% better than my 1st attempt made with my little brother swing a sledge in the back shed at home during my school years.
-As you progress hang onto them, it is good to be able to look back and say "these were my first pair that I made", unfortunately I don't still have my first pair.
Cheers
Phil
Thats' a hammer not a toy, hit it don't play with it!
