Stubbysteve Posted October 24, 2023 Share Posted October 24, 2023 I know for the most part, people usually don't want to shorten a post vise. But me I am disabled and in a wheelchair all the time. I don't have any legs. I have 4 post leg vises. I figured on taking the one in the worst shape to shorten. Anyone have any ideas on how to do this without losing the integrity of the vise? Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted October 24, 2023 Share Posted October 24, 2023 Cutting the leg to lower the vise should not affect the integrity in the least. I've seen vises that had the legs cut down by using a torch, metal cutting band saw, and one that was cut using the hot cut on the anvil usually with a helper. Most older vises the legs are wrought iron and a hand hack saw will cut them, although that is kinda time consuming and tiring. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus Quote Link to comment Share on other sites More sharing options...
Stubbysteve Posted October 24, 2023 Author Share Posted October 24, 2023 Great, I've been worried about messing something up and destroying a piece of history. I guess it would be useless to anyone else. Thanks for the reply Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 24, 2023 Share Posted October 24, 2023 Shorten your vise but keep what you cut off anyone wanting to restore the height can weld it back on. Leg vises were made to be used and are easily modified. If its wrought iron the silica inclusions that give it it's wood-like grain will dull saw blades quickly, you might want to use a carbide tipped bi-metal saw blade or use a cutting disk. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
wicon Posted October 24, 2023 Share Posted October 24, 2023 Just heat it up and bend it (90°-180°). No need to cut it off, store it where it can't be found or weld it on again. Willy Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 24, 2023 Share Posted October 24, 2023 53 minutes ago, wicon said: store it where it can't be found You're familiar with my filing system I see. Good suggestion Willy I like it better than cutting. Wish I'd thought of it, thanks. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
wicon Posted October 25, 2023 Share Posted October 25, 2023 I don't know your filing system, I only know mine. Willy Quote Link to comment Share on other sites More sharing options...
Frosty Posted October 25, 2023 Share Posted October 25, 2023 You got the description perfectly. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Jason L Posted October 26, 2023 Share Posted October 26, 2023 Rub it down with Crisco. I heard a story about that once. It didn't involve a vice and the fellow seemed pretty unhappy about the result Quote Link to comment Share on other sites More sharing options...
Nobody Special Posted October 26, 2023 Share Posted October 26, 2023 It can be found, just go casually rummaging around five minutes after you no longer need it, and preferably after you've given up and bought or made a replacement. At least that's how it works in my shop. Quote Link to comment Share on other sites More sharing options...
bwoollcombe Posted December 7, 2023 Share Posted December 7, 2023 I sometimes do work with accessibility (usually digital technology, but I can hum the tune for other aspects). I also, after much looking in an antique-poor area, found a leg vise. So here's my 2 cents: Cut it and mount it so it works. Whatever it takes. The long-dead makers, the blacksmiths before you- they would understand. That vise needs a smith as much as the smith needs a vise. I rip apart brand-new devices to make them accessible, and I'd rip apart antiques if that's what it takes. Quote Link to comment Share on other sites More sharing options...
JHCC Posted December 8, 2023 Share Posted December 8, 2023 Well said. Quote Link to comment Share on other sites More sharing options...
