June 22, 20224 yr Here's some of my first repousse attempts and advice is appreciated. All are out of 12 or 16 gauge copper. If anyone has any tips for brass let me know as that's the next material I wanna try
June 22, 20224 yr Like copper, keep annealling brass by heating and quenching to avoid work hardening and cracking. Also, I suggest defining the edges of the raised areas by using a stake with a slightly rounded edge so that the edges are crisper and the transition from background to raised area is more sudden. A piece of hard wood can be used if you don't have a suitable metal stake. "By hammer and hand all arts do stand."
June 22, 20224 yr Author Thanks for the advice on the stakes. I was just using a curved crosspien hammer if that makes sense to get at the outline but as you can see it didn't work to well. I have since made stakes and will round the edges. I also have made a larger chisel then the one I used in the bird so I'm hoping it works better. My goal is to get good enough to do a last super piece even though I'm not religious really I have always like it. I'm going to make more punches and chisels to use. I'll post any more work I do.
June 22, 20224 yr Also, I believe that you need something to back up the work that is resistant but somewhat soft. A resin ball is common. There was a recent IFI discussion about makining your own resin for this purpose rather than buying the commercial stuff. I seem to recall the ingredients included pine pitch, bees wax, and brick dust. Also, as I understand the technique you do almost all your work from the back side. GNM
June 22, 20224 yr I'm no good at repousse, but I think those are pretty good for first attempts. I can't give you any practical advise but encourage you to develop your skill if you are of a mind to. I would be glad to hang those on my wall. I love to look at repousse art and hope to see more of yours someday. I tried a butterfly and it turned out looking like a cross between a pork chop and a toadstool...
June 22, 20224 yr Author Thanks for the compliments. I use a 50 50 mix of beeswax and plaster of Paris for most of it and a little red pitch for smaller details. Once work settles down I want to keep practicing.
June 23, 20224 yr Re Brass: there are MANY alloys of "brass" some work better than others! Just like you can hot forge some brass alloys and can't others. I'd suggest you contact a local University's Art Department and talk to a Professor about which ones you might try.
July 20, 20223 yr A bit late here but looks real good. I really like the texture of the quail background. I have a sand filled leather bag that I use a bit and some stakes as noted. You might dress your hammer and tools some to reduce the marks. Keep at it. I want to do more but always find that I would rather spend my time forging. I wish the wife would let me do it in front of the tv at night.
