VandegriftIronworks Posted February 22, 2022 Share Posted February 22, 2022 Hi all, just filled up my blower with oil, says on the side (keep filled to oil plug) so I did that, now it is leaking oil into the hose running into the tuyere. It runs quiet and blows A LOT of air. So I don’t think there is anything wrong with it. Is this indicative of a problem? More pictures Wowza. Just found the other plug... it’s hidden on the bottom, about an inch up the housing, maybe added too much ATF Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 22, 2022 Share Posted February 22, 2022 Yep... too much ATF and probably too light of an oil. I would recommend chain saw bar oil with a little STP or equivalent added in. Quote Link to comment Share on other sites More sharing options...
George N. M. Posted February 22, 2022 Share Posted February 22, 2022 This probably means that it is leaking into the fan housing around one of the shafts rather than out through the seam between the 2 halves of the gearbox (common on C-O or other oil bath blowers). I agree that a heavier oil may reduce the problem. You may have to do some messy experimentation to discover the optimum blend. While it is possible to install a gasket on the seam to stop leaks there it will be much more difficult to stop it happening around a shaft. One of the other folk with more experience in this area may be able to offer suggestions. "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
TWISTEDWILLOW Posted February 23, 2022 Share Posted February 23, 2022 I run 30 weight in all mine but the lower it gets under 30 degrees F the harder it is to crank, Quote Link to comment Share on other sites More sharing options...
pnut Posted February 23, 2022 Share Posted February 23, 2022 As everyone said it's overfilled right now. After that is remedied I'd just put a tray full of kitty litter under the blower. I use ATF in the winter or 5W20 or 30 in the summer in my blower. I work outside though and anything but ATF or clear machine oil gets too thick when it's in the temperature drops into the teens. Pnut Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 23, 2022 Share Posted February 23, 2022 I use the light machine oil they sell for use in Swamp coolers out here and only a small squirt every now and then; but then you have a fancier geared blower with an oil bath; so fill it to the correct level and if there are any drips, well the Al foil roasting pan full of cheap clay kitty litter works. Me, I have a dirt floor and haven't noticed an oily spot yet. Supposed to hit 75 degF one day next week, tonight's snowstorm will probably not reach us down in the valley. Quote Link to comment Share on other sites More sharing options...
anvil Posted February 26, 2022 Share Posted February 26, 2022 It kinda like a Harley, if it aint leaking its out of oil. Quote Link to comment Share on other sites More sharing options...
