SinDoc Posted April 14, 2021 Share Posted April 14, 2021 I have already spoken to some people on this forum, and have been enjoying reading around learning everything. I am new into this craft and have not yet figured out how to correctly...tune? is that the right word? my burners. I have a Majestic knife maker 2 burner deluxe. I know I have heard mixed takes on them, but they are located right down the road from where I grew up. Literally. So, why not buy local? Anyways, should I set my regulator to a certain psi, then use my burners control to adjust as needed? Or just I get the forge going, the run the burners wide open and control via the regulator? Does it matter? It seems like the end results would roughly be the same, but the second method just sounds...wrong. The couple times I have used it so far, I use the controls on the burners and adjust the psi as needed but haven't really messed with it. I adjusted it to 10 psi and have just left it there. Also, I have learned this thing is next to impossible to run with so much as a light breeze. Any recommendations as to designed a wind break for it? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 14, 2021 Share Posted April 14, 2021 What does the Manufacturer suggest? Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 14, 2021 Share Posted April 14, 2021 The burners on a Majestic are linear inducers and are very reliable. Adjust the air flow to suit the work. This is tuning the flame. Once you have a neutral flame run the lock nut onto the choke plates so they don't move. You turn the heat up and down with the regulator, a gauge is only going to confuse you. The only real world use for a gauge on a propane forge is to preset the forge for a specific temperature before you light it. Most commonly for heat treatment but you can't put your steel in the fire, walk away and expect anything good anyway. If you have to keep an eye on it presetting the forge isn't particularly useful. If you just light it and turn it down before it comes to heat your forge will get hotter quickly if it's too cool. Cooling down takes longer so start low and increase as needed. Short answer, adjust for a SLIGHTLY rich flame at a lower pressure or neutral at max pressure. Lock the choke plates and you're done with it. Naturally aspirated burners will lean out as propane pressure increases but not a lot, if you start slightly rich it won't becomes oxidizing. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
SinDoc Posted April 14, 2021 Author Share Posted April 14, 2021 I apparently need to do more research on the flame envelope. Granted it has been roughly a week since I last turn it on, I don't recall even seeing blue in the flame. I will have to read more on what a proper flame should look like and then research the proper way to set my flow. Per Thomas, I should probably call Majestic as well. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 14, 2021 Share Posted April 14, 2021 Do they have an online owner's manual? If not suggest that to them when you call. Quote Link to comment Share on other sites More sharing options...
SinDoc Posted April 15, 2021 Author Share Posted April 15, 2021 The only thing it came with was the care instructions. I picked it up so the guys at Majestic had it already all put together for me. I will have to give Brian a call and see what they suggest. Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 15, 2021 Share Posted April 15, 2021 You aren't going to get specific instructions, there are a lot of local variables that effect the flame. Mike is better at reading flames than I am but a good cue is the sound it makes. It should be LOUD almost shrieking roar and the fame should be translucent, not quite transparent. Worrying about analyzing flame envelopes without being really familiar with them in different conditions can do more harm than not. Adjust the choke plates, take a shot in the door so we can see the flame, wait till the forge heats up and take another. Post them here, we'll take a look and opine. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted April 15, 2021 Share Posted April 15, 2021 Listen to frosty about this.; he's right. The one facet about judging flames I haven't talked about is time. You will have a learning curve. Quote Link to comment Share on other sites More sharing options...
SinDoc Posted April 16, 2021 Author Share Posted April 16, 2021 Got it. Hopefully it isn't really windy again today and I can fire it back up and take some photos. Finally resolved my plumbing issue so would be nice to take out some frustration on some metal Quote Link to comment Share on other sites More sharing options...
pnut Posted April 16, 2021 Share Posted April 16, 2021 Remember to take a pic right after you light it and another after the forge chamber is up to heat. Being in a dark place helps. Pnut Quote Link to comment Share on other sites More sharing options...
SinDoc Posted April 16, 2021 Author Share Posted April 16, 2021 If the sky outside is any indication of the weather today, looks like it probably wont happen. I could set it up at the cusp of the door to my shed/shop, but I dislike doing that. Plenty of ventilation, but the idea of a very, very hot thing sitting in my mostly wooden building (granted it has metal walls), is just an unpleasant feeling. Should have built that garage instead! Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted April 16, 2021 Share Posted April 16, 2021 When it comes to safety, never exceed your comfort zone; your subconscious may be trying to point something out to you. Quote Link to comment Share on other sites More sharing options...
SinDoc Posted April 19, 2021 Author Share Posted April 19, 2021 I did not get to take any pictures, but I manage to fire it up for a few yesterday. Only shortly however as I had noticed cracks in the liner and wasn't sure what to do about that. The flame was a nice light blue, maybe with a slight tinge of green and the dragons breath was very translucent. Only noticed licks of orange flame that would pop up when there was a ever so slight breeze (my forge sits outside). Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted April 19, 2021 Share Posted April 19, 2021 : Filling cracks are one of the things that refractory cement is actually good for. If you sift any left over refractory, to remove the chunks, it can be used for the same purpose. Remember to wet the inside surfaces of the crack before applying cement or refractory into it. On 4/16/2021 at 4:27 AM, SinDoc said: Got it. Hopefully it isn't really windy again today and I can fire it back up and take some photos. Maybe it's time again to discuss how to protect burners from wind with baffles? Quote Link to comment Share on other sites More sharing options...
SinDoc Posted April 19, 2021 Author Share Posted April 19, 2021 I have some sheet metal laying around that I am going to make a wind break out of. Eventually lol. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted April 19, 2021 Share Posted April 19, 2021 Other guys have had to do the same thing. Quote Link to comment Share on other sites More sharing options...
