Hardening a touchmark made from drill bit
David, generally, tools used on hot metal, including touchmarks, are not hardened and tempered because the first time you use them on hot metal it will draw the temper.  Any toughness/hardness in a tool used on or in hot metal should be inherent in the type of steel, not the heat treatment.  I made my touch mark from a piece of spring and it has not noticeably eroded in use.
