ThomasPowers Posted November 11, 2020 Share Posted November 11, 2020 You may notice that the professional grade belt grinders are often equipped with a variable speed controller as "optional speed" changes with what you are trying to do with them. Quote Link to comment Share on other sites More sharing options...
Frazer Posted November 11, 2020 Share Posted November 11, 2020 That's one of the reasons I suggested the Grizzly, it's variable speed from 1900-3200 FPM. Quote Link to comment Share on other sites More sharing options...
JHCC Posted November 11, 2020 Share Posted November 11, 2020 Very generally speaking, the finer the grit, the slower the belt. Fast speeds are great when you're hogging off a lot of metal with a coarse grit, but slowing the grinder down when you're finishing with a fine grit reduces the risk of heat building up from the friction to the point that it ruins the temper. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted November 12, 2020 Share Posted November 12, 2020 I run speeds between 2k and 5,5k Quote Link to comment Share on other sites More sharing options...
subzeroblades Posted February 3, 2021 Share Posted February 3, 2021 I've been making knives for around ten years now. My first belt grinder was the HF 4x36 modified with a HF 1hp motor. It's a belt driven sanded so the mod was simple. That thing didn't throw a single spark until I put the one horse on it. I've had the 1x30 as well it's worthless for anything but scales. My advice is to build your own 2x72 out of an old weight bench and running machine engine. Mine is made from square tubing and a running machine. I used longboard wheels for the platen and idler and a piece of pipe for the drive wheel. The building process will help get you familiar with all your tools so by the time your making a forge burner you won't be so green and might just keep all ten fingers and your eyebrows as well. Just remember the more time you put into a project the more satisfying it is to finish. I hope you keep at it. I'll post pics of my grinder in case you want to build one. It cost me around 100 bucks including 3 ceramic belts. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 3, 2021 Share Posted February 3, 2021 Pictures are always good. Quote Link to comment Share on other sites More sharing options...
