Posted
So, i am making this folder, and wanted the handle to be "skeletonized" (refer to picture below) the handle is made of some old scrap mild steel, its about a quarter inch thick (i wanted a nice heavy beefy handle so i can actually use it for hammering or whatever odd job im workin on) and i would like to know what the easiest way to cut out those triangles would be, besides a hand file. (Plasma cutter is not an option haha) i have every imaginable file, sander, dremel bit, drill bit, hacksaw and a propane torch, and a bunch of other basic tools to work with.
Posted
All of those are out of my budget range for now... I have started cutting them out by drilling holes around the borders,and just fileing them. It'll take a while, but ill get it done.
Posted
Or just two sides towards a vertex that would allow you to saw 2 complete sides. (Work both directions from the tangent points.) It you want round ended vertices I'd drill small holes there to saw into.
There is a trick using a a fancy bandsaw with a blade welder where you drill a properly sized hole, break the BSB and inset an end through the hole and weld it back together and remount it and band saw internal waste space out.  I've seen it done but never owned a fancy band saw, sigh.
Posted
Yeah, ok ill try that. I do have a bandsaw, but  it is in need of repairs at the moment. I had never thought of cutting the blade and welding it back together. Bright idea!
Posted
Big industrial bandsaws often came with a built in blade welders for that very reason as well as repairing broken blades and making new blades from a coil of blade stock.
Posted
Heres my progress so far. Didnt turn out to good, but maybe the second half of the handle will be better. Criticism is expected an welcome.
Posted
You'll still have to drill holes to start and do some file work but a good narrow bimetal blade will do it for you. don't make the mistake of buying a fine blade though, the rule of thumb for TPI is 3 teeth on the stock at all times. It's hard to find saw blades coarse enough to meet the rule though. 12 tpi is right for 1/4" thick steel.
I love my saber saws.
Posted
I have used jeweler's saws for the initial cut after drilling an initial hole. You can. then,  switch to a single hacksaw. (the type that is held down with only one 'screw'.  Or an electric saw. etc. etc.
SLAG.
Posted
Well ive finally finished cutting out both halves, i drilled some 3/8 tried using a jig saw, but it didnt work as well as a saber saw probably would have. (Thanks anyways though, Frosty!) So i instead cut as much out with a hacksaw as i could, then cleaned it up with a file, and some sandpaper. My hands are cramped up, but its done! :lol:
Posted
I bought a little 1/2 inch pneumatic belt sander for jobs like that.  I don’t use it often, but it’s a real treat when I do have work for it!  Mine was only about a hundred bucks online!
Posted
I've got another question. So the long piece there is going to go between both sides of the handle and stop the blade from folding back to far (the peice will be flatter/thinner when it's finished) and im wondering what the best way to get it to stay there beside welding it. My ideas are: thread some holes all the way through and screw in some all-thread; rivet it (but the piece is pretty narrow so i dont know how well that would work); or drill some holes and force some nails through while the handle is hot...
Thomas,
Ohh nice!
Posted
Small bolts or small rivets are commonly used.  Have you gone and looked at knives like the one you are making to see how they did it? (And what you liked best?)
Posted
Well... Looks like most of them have something like this, with the heads countersunk. Why i didnt think of countersinking them, remains an enigma.
