Tong repair
I have a pair of tongs that have a crack in the jaw. I was considering v'ing it a bit and brazing it.  I thought it would be smother and probably stronger than a stick, or wire weld. Is this the correct procedure? Thanks
Mr Beef
I am no expert but I would think that steel tongs would be stronger if welded versus brazed but look forward to discussion.
Good Morning, Beef
Brazing will work. You will never be able to change your mind and weld it another time with a Stick or Mig welder. If you notch the piece where the crack is and Gas weld or Mig-weld the area, you still have an open door. The brazing will wick and contaminate any other welding/repairing procedure. If you have a torch to Braze it with, you have a torch to Oxy/Acetylene weld it with. The short answer is, Yes, but....
Sometimes it is easier just to get the practice and Forge another rein. Learning lasts a life-time, the school of 'Hard Knocks' is a great teacher.
Neil
I too would make another pair for the above reasons.
However; if the tongs were made from real wrought iron you may find it tricky to weld with torch of arc.  Quite possible, just some difference in the puddle.  Brazing should be the same for either steel or WI.
Thanks for the information. I hadn't thought of the contamination by brazing, good point. I will take a look at the tongs. I don't believe the crack is clear through so maybe it is just a flaw.
Seeing as the crack is in the jaws, I would think the braze would fail when they got hot. Of course that would depend on what type of brazing rod was used and how hot the tong jaws get.
