DanielC Posted October 4, 2019 Share Posted October 4, 2019 So, I'm working on another run of crucible in between commissions for sanity sake. This one is a little lower C than I've grown accustomed to, but hope it survives into the end. It was melted and weighed out to 4.5 pounds. It was then roasted for ~22 hours and am poised to start the forging process. Quote Link to comment Share on other sites More sharing options...
DanielC Posted October 6, 2019 Author Share Posted October 6, 2019 Was on the verge of chucking this bar today because it was not looking good under the scope. Decarb from the soak may have left a carbon content gradient that needed to be ground through revealing the true nature. As can be seen in the picture below. The amount of spheroidized cementite looks very low in concentration to be 1.3-1.4% to me. This took roughly 6 hours to turn into a short oblong bar. This is the picture (directly below) that made me feel like there just wasnt enough cementite. So here I am today, about to give up on the bar. Assuming I either cooked all the carbon out in the roasting by not protecting the Ingot well enough or I overestimated carbon content. Either way, after another 3-4 hours of forging, I felt the bar finally give under the hammer and feel like a beautiful piece of steel and not a hunk of cast iron. The watering pattern at the edge gave me a sigh of relief. Whew. Lucky me, the bar weighs over 4 pounds. Lots of blades if all remains well. Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted October 6, 2019 Share Posted October 6, 2019 good looking pattern, very even distribution Quote Link to comment Share on other sites More sharing options...
JHCC Posted October 6, 2019 Share Posted October 6, 2019 Looking good. I can't even imagine tackling something like this. Quote Link to comment Share on other sites More sharing options...
DanielC Posted October 6, 2019 Author Share Posted October 6, 2019 Thanks. Given that it did water, the carbon content was indeed 1.3ish. Even with a power hammer, crucible steel is rough. Easy, easy, easy to mess up. Really hard to sync everything together just right. It was indeed crucible steel and Ric Furrers special that got me into smithing period. The pattern will become more bold and pronounced the further I go as long as i dont screw it up. As of right now that etched section is still over an inch thick. The pattern gets better as you gradually get closer to blade thickness. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 7, 2019 Share Posted October 7, 2019 Have you read Dr Feuerbach's thesis on "Crucible Steel in Central Asia"? (If you have an interest in historical aspects...) Quote Link to comment Share on other sites More sharing options...
DanielC Posted October 7, 2019 Author Share Posted October 7, 2019 I have it stored in my phone. Her opinion diverges from Verhoeven. It's difficult to make heads or tails out of who may be right, except for the fact that she doesnt make or forge crucible steel and Verhoeven worked closely with Pendray who did. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 7, 2019 Share Posted October 7, 2019 Pendray and Verhoeven were working on Wootz; as Feuerbach's thesis describes: not all crucible steel is wootz and both wootz and non-wootz crucible steels were in use. Are you using the term Crucible Steel in the same way or are you using it only for wootz? Quote Link to comment Share on other sites More sharing options...
DanielC Posted October 7, 2019 Author Share Posted October 7, 2019 Most of us just use the term Wootz because it is shorter, and most have realized that the only thing differentiating between modern crucible steels and historic wootz is the melting process, getting the alloying agents in the billet to form a good pattern. However I typically reserve the term for the better patterns and not the inferior ones I've seen produced by several as of late. The patterns often associated with historic wootz are obtained irrespective of melting procedure A pattern in the end is dictated by chemistry, melting temp/time, time of solidification, roasting, forging procedure and heat treatment. There are many forms of crucible steel out there that wildly change one of those key things to form a different pattern, such as bulat. Modern purveyors of crucible steel have finally gone a little further than Pendray, and the field is getting smarter by the day. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 7, 2019 Share Posted October 7, 2019 Yes Wootz is a subset of crucible steels not the superset. Huntsman wasn't interested in large dendritic grains; in fact they were considered a problem and so crucible steels were teemed into ingots and then heavily forged to refine them. I have Dr Feuerbach's thesis on disk as she kindly sent copies out to members of the Archaeological Metallurgy mailing list who requested them back when she got her Doctorate. I also discussed wootz with Al Pendray when he demo'd at Quad-State.( I was his SOFA provided assistant---as I was for Ric's demo on '3 ways to make steel' as well. Its a great way to be up close at demo's and be able to ask a lot of questions. Ric even dealt well with the floating plastic eyeball in his quench tank.) Patterned steels for bladesmithing are only a small portion of historical crucible steel usage no matter how some groups would like to define it. Quote Link to comment Share on other sites More sharing options...
DanielC Posted October 7, 2019 Author Share Posted October 7, 2019 Social media is a beautiful thing. Ann, Ric and pretty much the whole community talk, argue and present data, arguments for or against and examples all the time. The best wootz maker in the world resides in Finland, and it is his methods that I borrow from through a friend who took a class with him. Tbh, thanks to social media I am close friends with most of the steelmaking giants. Both professionally and personally. I am even friends with one of Al's students and friend and he helps me make heads or tails of some things. Quote Link to comment Share on other sites More sharing options...
SLAG Posted October 7, 2019 Share Posted October 7, 2019 T.P. I tried to p.m you concerning a recent 50 minute youtube "article" by Mike Loades and Al Pendray. With no luck. You have probably seen it. If not, I can post it to this thread. SLAG. Quote Link to comment Share on other sites More sharing options...
DanielC Posted October 7, 2019 Author Share Posted October 7, 2019 Apologies SLAG, I'm in and out. Very busy. I will get back to you on it soon. Quote Link to comment Share on other sites More sharing options...
SLAG Posted October 7, 2019 Share Posted October 7, 2019 DanielC, Apologies for what? Apologies are not necessary. SLAG. Quote Link to comment Share on other sites More sharing options...
DanielC Posted October 7, 2019 Author Share Posted October 7, 2019 Ah thought you were talking to me because you did send me a pm and I'm not sure if I responded. Quote Link to comment Share on other sites More sharing options...
SLAG Posted October 7, 2019 Share Posted October 7, 2019 No the p.m., in question, was "sent" to T.P. But the error message says he is not accepting p.m.'s Regards, Dan. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 7, 2019 Share Posted October 7, 2019 Funny I got your pm; just no time to watch it at work... I haven't changed any settings lately either and have had several other PMs today. Quote Link to comment Share on other sites More sharing options...
SLAG Posted October 7, 2019 Share Posted October 7, 2019 T.P., The problem seems to be at my end. Several pm.'s have posted very slowly. And one did not post at all. It seems that both of us will be viewing it tonight. I shall be tied up, now, cooking up some Szchuan Hot and sour soup for myself and Marg (the marvelous), for this evening. SLAG. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 7, 2019 Share Posted October 7, 2019 Sore throat? I always loved good H&S soup when I had throat/sinus issues; first couple of spoonfuls are like drinking hot HCl and then blissful relief. Dan; anything published out of those discussions? I just started a University job and so have access to the Library now. Quote Link to comment Share on other sites More sharing options...
DanielC Posted October 7, 2019 Author Share Posted October 7, 2019 Hmm hard to tell. Years of conversations with various people. Quote Link to comment Share on other sites More sharing options...
SLAG Posted October 7, 2019 Share Posted October 7, 2019 T.P., I stopped adding HCl to the soup about 8 years ago. (Chinese red oil is used, now, to heat up the soup, to taste.) I'd have you two over here if you lived closer by. Regards, SLAG. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 7, 2019 Share Posted October 7, 2019 We could bring a gunnysack of chili's! Dan; I'll ask a friend who is a Metallurgy Prof if he has heard of anything; I bring metallurgy questions to him and he brings blacksmithing questions to me---a sort of symbiosis. I'm currently reading the thesis+ on the monsoon wind powered smelters of Taprobane. Quote Link to comment Share on other sites More sharing options...
DanielC Posted October 11, 2019 Author Share Posted October 11, 2019 So found out there was a void in the center of the puck which led to a long cold shut. I decided to skip "killing" the melt this previous time with my go to method and instead tried to use Calcium Carbonate. Apparently not enough. Sucks, but its part of the game. 18 hours of forging under the powerhammer, 80# of propane tons figure it out though. I had just finished coarsening the cementite and started to stretch it out too. Oh well. Time for a new melt tonight. An old puck and some chunks of this recently worked bar. Should get me around 1.6-1.7% C. Quote Link to comment Share on other sites More sharing options...
DanielC Posted October 12, 2019 Author Share Posted October 12, 2019 This is what I do when I encounter failures in steel making. I always, always, always pick myself back up and keep going. New 5.5 pound puck, it is in the kiln roasting right now and the resulting metallographic structure will tell me more about carbon content, but according to estimations it can be 1.4% C at the lowest, and 1.7%C at the highest. Broke the 1st use crucible though, oh well. Quote Link to comment Share on other sites More sharing options...
DanielC Posted October 13, 2019 Author Share Posted October 13, 2019 And after a roast, I have what appears to be in the upper atmosphere. ~1.7% C Quote Link to comment Share on other sites More sharing options...
