July 6, 200818 yr Let us say you are working on large project that requires a crane, hoist, jib crane, engine hoist etc to lift, turn, or reposition the project. The load is lowered to the ground to take the weight off the project, but is still being held upright into an upright position by the crane. Throw in some additional supports to keep it upright, just for the sake of safety. If you now weld on this project, would a less than perfect ground clamp connection allow the welding electric to pass up through the chains, crane hook, wire cables, etc. and into the motors, electrical connections etc of the crane and cause problems? Should some type of insulating device (such as a nylon strap) be used to isolate the crane from the project?
July 6, 200818 yr The welding circuit is made from stinger to ground on the machine. I do not think you would have a problem if the ground was not placed above the hoist. However, I would use a nylon strap anyway as they seem friendlier than chain on both hoist and work since they are plenty safe and so much easier to use. Then the welding ground has to be good or you'll get no arc.
July 6, 200818 yr Making a mountain out of a pimple on this ground thing. The last thread on it was hilarious. Just use common sense and place your ground close to where you are welding. If in doubt touch the rod at the point you are gonna weld and then touch the ground to the place you are gonna put it, if it arcs, you got it right. Edited July 6, 200818 yr by irnsrgn
July 7, 200818 yr Along these lines, it may be worth mentioning that many modern vehicles have computers on board, if welding to a vehicle with a computer, at least disconnect the battery leads.
July 7, 200818 yr One thing to remember is that nylon straps are actually quite delicate and easily damaged by welding spatter, sharp edges, and heat. If you do decide to use one around welding/forging equipment do not forget to inspect it prior to use and be mindfull of it while welding/working.
July 7, 200818 yr Author Thanks for the reminder to disconnect any vehicle's computer before welding on it (the vehicle).
July 8, 200818 yr Disconnecting the battery cables will have absolutely no effect on anything, think about it for a minute. This is a myth. I've welded on plenty of vehicles with no trouble. Lots of guys with welding rigs use thier trucks for welding tables on a regular basis. Glenn, there is nothing to worry about. I've personally welded ON electric motor cases, the only worry is from too much heat getting to the wiring. We use cranes pretty much every day installing our signs. Use the crane to postion the part, weld it in place.
July 8, 200818 yr Author what about the suggestions to disconnect batteries from one car when jump starting the other or the computer etc gets damaged?
July 8, 200818 yr I have never had to disconect the batter when jump starting. The computer in a car has a "surge" protector between the computer and the battery/ alternator. If that battery explodes it could cause an EM puls and kill the computer but not a simple jump start.
July 8, 200818 yr Since we've gotten off the original subject I would also agree with Justin. I have jumped from one vehicle to another, both with computers, many times. No ill effects. I have welded on a structure suspended by a crane and the chain got hot. Smokin' hot!! Forgot to attach the ground clamp (Boy! Was I embarrassed when I had to call maintenance to replace the fried crane motor *red faced grin*)
July 8, 200818 yr there are many welders/shopmen who would differ with you, who have blown up batteries or burned half the diodes out of alternators. In all my years of doing repair welding I had neither happen. If I was welding on the engine to remove broken studs usually I always had the mechanics disconnect the negative battery cable before I would ever attach my ground to the closest available spot to where I was gonna weld.
July 8, 200818 yr Afraid I have to agree with irnsrgn of this one. If the time it takes to undue one battery cable is too much to spend, then I guess you can readily afford to repair whatever damage may occur. Just because you have done something without ill effect, in no way garrantees that you will always get away with it. There is a concept that is a bar to all knowlegde; that concept is contempt prior to investigation.
July 8, 200818 yr Give me a good explanation of how unhooking a battery cable can help. Blowing up batteries? That's from sparking near a battery, nothing to do with the welding current. You do need to use some common sense. Hooking up a work clamp on the front bumper and welding on the rear of the vehicle is just plain silly and begging for trouble. If your work clamp is near where you are working, and well connected, you will never have any trouble. Electricity doesn't just go roaming around aimlessly. It will take the path of least resistance back to your work clamp every time, with no interest in your battery or electronics. I've spent quite a bit of time welding on vehicles with my TIG, using HF/HV start. If anything were going to cause problems that would.
July 9, 200818 yr I disconect batteries on cars with computers for the same reason I unplugged this computer from the wall outlet during the huge lightning storm we had here last week. Electrical isolation. Not connected, can't be harmed.
July 9, 200818 yr You do realize that everything electric in a vehicle is connected to a common "ground", which is all the metal in the vehicle. The only thing you are isolating by disconnecting the battery is the battery.
July 9, 200818 yr Ford knows best. Here is the ford welding procedure for post '04 trucks:https://www.fleet.ford.com/TRUCKBBAS/non-html/Q114.pdf Here is the ford welding procedure for post '05 trucks:https://www.fleet.ford.com/truckBBAS/non-html/Q123R1.pdf Ford clearly states: Models Affected: All F250-550 trucks; Model Year 2005 and later. Action Requested: Please provide a copy of this bulletin to all Engineering, Manufacturing, Service, Parts, Sub- Contractors and Customers that plan to use this vehicle as a mobile welding platform. Background: F250-550 Instrument Cluster failures have been reported following plasma cutting or electric welding operations. The 2005 F250-550 Instrument Cluster circuitry has proven to be more sensitive to induced voltage. This includes service trucks intended as mobile arc welding platforms. Warranty Statement: Before electric welding or plasma cutting on the frame or body of F250-550 units, disconnect the battery, instrument cluster, ABS module and the PCM. Just disconnecting a battery cable is not enough to prevent damage to these components. Damage seen in newly-constructed trucks has been traced back to welding. Electronic module damage due to this customer or vehicle modifier action is not covered in vehicle warranty. Here is some manufacturer's instructions for welding on a DodgeTSB 13-001-03 The fact that you have been lucky does not mean that it is good advice nor advisable to keep pushing your luck. Just because nothing bad happened the couple of times it was tried does not make it any less expensive when you finally do roast a computer or Instrument cluster. Clearly, it is worth the 2 minutes that it will take to ensure that you don't void your warranty and end up accidentaly spending well over a thousand dollars (potentially)
July 9, 200818 yr Dodge had a problem with their pickup front frames and came out with some weld on reinforcing plates. I did about 35 of these for the local dodge dealer, it was nice work, they had the trucks up on a lift, the front wheels off, all the stuff disconnected according to the instructions and the frames cleaned and the plates all in place with one pair of C clamp vise grips. All I had to do was add somemore clamps and weld them in place according to dodges print. As far as I know the only precaution was unhooking the negative battery post .
July 9, 200818 yr My first car disaster involved an aprentice who cut through a gas line with a torch. Complete new interior, I picked up the tab. Second time, replacing a section of frame, some type of tarred felt glued to the inside of the sheetmetal body, about six inches away from where I was welding, ignited, causing paint and again interior damage. The car owner was a machinist who was very understanding, but I still had to pay for the repairs AGAIN. Will there be a third "accident" ? I hope not.
July 9, 200818 yr By the way, you can blow up a battery with welding current. I can't explain how this happened, but with the welder on, I connected the ground clamp. The stinger must have been in contact with the body or the bed of the truck. As I walked arround the front of the truck, with the hood open, the battery exploded in my face. But for the grace of God, I suffered no permanent damage. I dove face first into a snow bank, and by the time I was standing up, a mechanic grabbed me, and got my face under running water inside the service station. I will never weld on a vehicle with the battery connected no matter how many times you say that nothing will happen. Been there, done that.
July 13, 200818 yr I am not sure if this has anything to do with this thread, but I have found that HF really seems to get around. I have an add-on HF box, and when I turn it on, the GFI to the workbench outlet always trips. It will trip the GFI even when it is not plugged into the GFI outlet. Even if it is plugged into a circuit on another breaker, it will trip the GFI. But, if I unplug all power cords from the GFI outlet, it will not trip the GFI. I added an industrial strength line filter inside the HF box, and the results are exactly the same. That means that the HF is not getting out through the power line, and it is not radiating from the HF box line cord. I then tried keeping the welding leads closer together, and there is more power in the HF spark, but still, it trips the GFI if anything is plugged in. Also, any lights on flexible power cords (not in conduit), flash when the HF is on, regardless of circuit that they are plugged into. This indicates that the HF is behaving like a radio wave, and the AC impedance to ground of the lighting circuits is much smaller than the DC impedance. The HF will even make a halogen lamp (big) flash. The reason for this is that the HF box is not a simple transformer. It is more like a tesla coil, and the HF bursts are in the range of several amps at thousands of volts. This is what makes them so damaging to electronics. If they make a large halogen floodlight flash, which is plugged into a different socket, they are pretty potent.
July 13, 200818 yr High freg converters of the type you are using have an adjustable spark gap under a flap some where or behind a window. Yours may need an adjustment. I also sometimes remove a gfi and replace it with a regular outlet, unless it is by a sink. By the way if you have one gfi in a circuit, all the receptacles in that circuit, become gfi. As far as being broadcasters, that is exactly what they are. They are used in tig welding to broadcast a beam of electrons from the end of the tungsten to the work, that the welding current can then follow, illiminating the need to "strike an arc". High freg has the aditional benefit of helping to break through Al-oxide, which is why there is a start only setting, for welding on dc. If you want to witness the broadcasting ability, point the tungsten at your finger from a half inch away (do not ground yourself) and step on it.
July 14, 200818 yr If you want to witness the broadcasting ability, point the tungsten at your finger from a half inch away (do not ground yourself) and step on it. I've heard that HF burns never properly heal...so...YMMV
July 14, 200818 yr . By the way if you have one gfi in a circuit, all the receptacles in that circuit, become gfi.. That is not always true, It is only true IF they are wired that way with the side chain, other wise they are just normal recept's. It all depends on how they were wired. Many people assume and think that idea was true, and they wire their replacement wrong, and can later be surprised! :o
July 23, 200818 yr Electricity takes the path of least resistance, not the shortest path. It CAN go through the crane but if your welding something big enough to need a CRANE, then no. Especially if it has pieces welded together already. The ground will go through the weld straight to the ground. Like JR said, your making a mountain out of a pimple (funny saying btw ). You probably have a better chance of lightning coming into your shop and striking you while you're welding because of the ionic charge that can be emitted from the electrical current making an electromagnetic field that can create an attraction to the storm. This is a thoughtful and very good question, but it's almost like asking: if you weld in the garage next to a little puddle of water coming out of the hose on the concrete floor, can the current get sucked into the water hose and follow the water into the piping inside the house and shock someone in the house washing their hands or someone doing dishes. I'm not making fun, just saying that you probably don't need to be all THAT cautious. Just use common sense when doing something. Don't over-psychoanalyze the situation. -Hillbilly
