David Kailey Posted May 4, 2019 Share Posted May 4, 2019 Here are some photos of the railing before it shipped. Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 4, 2019 Share Posted May 4, 2019 That's quite the railing David, I see happy customers in your future. What did you use to buck the bronze medallions when you peined the tenons? Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
David Kailey Posted May 4, 2019 Author Share Posted May 4, 2019 On 5/4/2019 at 12:23 PM, Frosty said: That's quite the railing David, I see happy customers in your future. What did you use to buck the bronze medallions when you peined the tenons? Used a rivet set I made years back then drilled a hole the same size of the set thru a 2 x 4 x 4 steel chunk I had and then poked the set thru and welded it. Then I put my 140lb soaking wet apprentice behind that. Lol Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 4, 2019 Share Posted May 4, 2019 How long does your apprentice stay wet enough to work? Making a set is probably better than a special buck and hand peining the heads. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
58er Posted May 29, 2019 Share Posted May 29, 2019 looks great, what type of finish for weather protection? Quote Link to comment Share on other sites More sharing options...
David Kailey Posted May 31, 2019 Author Share Posted May 31, 2019 On 5/29/2019 at 7:30 PM, 58er said: looks great, what type of finish for weather protection? Powder coating on the rail, and clear coating on the copper. On 5/4/2019 at 5:13 PM, Frosty said: How long does your apprentice stay wet enough to work? Making a set is probably better than a special buck and hand peining the heads. I have to water him down every 30 min in the summer. winter just once but he freezes up pretty quick. Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 31, 2019 Share Posted May 31, 2019 5 hours ago, David Kailey said: I have to water him down every 30 min in the summer. winter just once but he freezes up pretty quick. Ayup, sounds like Spokane. good to see you using traditional techniques. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Chris C Posted May 31, 2019 Share Posted May 31, 2019 That's absolutely beautiful. David. Quote Link to comment Share on other sites More sharing options...
Daswulf Posted May 31, 2019 Share Posted May 31, 2019 Yup, Beautiful railing. Quote Link to comment Share on other sites More sharing options...
bobasaurus Posted July 14, 2019 Share Posted July 14, 2019 Amazing work on that railing, wow. Quote Link to comment Share on other sites More sharing options...
