Patternwelded modern seax
First blade of 2019!
W2 cutting edge stacked with a twist core and wrought iron spine. Blade was deeply hot blued then sanded back ever so gently to make the pattern pop. Cast bronze fittings with buffalo horn.
Theo
Another blade I can't think of anything nice enough to say about. Did me again Theo, speechless! :ph34r:
Looks amazing! I love the layers and the bluish steel look.
Gorgeous - can we get a detail shot of the pommel?  From what I can see of that Celtic knot, I want to see more!
Thanks gang!
Sorry, totally spaced on getting better photos. Jim (Sharp By Coop) will get it for sure :)
That is so amazing, One day that piece of art could be a thousand years old.  How difficult was that W2 to forge?
W2 is actually sort of malleable to forge compared to spring steel, which W2 did you use?
Hey Theo!  How's it going?  Nice blade to start the new year.  Traditional with a modern twist...like it.
  • 2 weeks later...
Fancy pictures from Jim at Sharp By Coop.
As always, thank you all for the support :)
That isn't the ONLY photo is it Theo?! <sniff sniff> :(
Gorgeous blade. Like we expect anything less.
