Yes they are still used to make holes in a rock or stone in order to use the "plug and feathers" tool to split that stone along a desired lime
Another name for them for the drill is a "star drill" which is used with a hammer. The drill is rotated a quarter turn after each hammer blow.
They can even be bought in some big box hardware stores.
SLAG.
While the powered version is more common these days I used one by hand to drill the bolt holes in the concrete pad of the carport I was turning into my wife's spinning studio.  It was only 2000 hammer blows per bold hole as I recall.  In mining they not longer redress the cutting end in the forge but use replaceable tips---I have a bunch of those too as I use them with my screwpress to decorate flat stock.
