Thoughts on 25 lb anvil?
Hello all,
I was wondering if I could get some thoughts on this little 25lb anvil (possibly ASO, I'll let you be the judges) I came across at a vintage market today. No markings/numbers on this at all, although there are those four bumps on the corners (photo 1). They almost look like rivets... I didn't have a bearing ball on me, so I'll have to head back this weekend sometime. Tried a rebound test with a 24oz ball peen which I had in the car. I wasn't thrilled with the rebound (less than 50%), but I'm wondering whether the weight ratio between the hammer and anvil would be throwing things off a bit there... Sound wise, I wouldn't say it had a super clear ring, but I'm honestly not entirely certain what I should be expecting as the few examples I have heard online seem to vary wildly. Similarly, I don't know what to expect in such a small anvil.
Here are a few photos. I appreciate any thoughts you may have. He's asking $70. Just something to play around with and give to my 3 yr. old once he reaches a 'constructive whacking' stage.
Cheers!
Well, my wife discovered weighted stuffed animal door-stops, so I'm set in that department. Thanks for the feedback!
I can buy a 80 pound chunk of steel at my local scrapyard for $16 paying $70 for a cast iron ASO seems a huge step backward.
I agree that it is just a decorative object. You couldn't attempt to use the horn even for small work without tipping the anvil over.
I do have a small 12 kg anvil but it is a swedish kohswa with very nice ring and rebound that lives a quiet life and would probably be good for some of the grandkids. That one is not worth your effort I think.
I second TP get a block or even a sledge head, 20# can be had. Take a gander at the improvised anvil threads and the TPAAT threads.
Many thanks for all of your thoughts guys! Completely new to this, so still trying to familiarise myself with what's available. I found some RR track for a decent price, so planning to just start off with that. Hoping to customise it at some point (as I've seen in some older threads), but hopefully can get a forge together and get right into it this weekend!
