JerryCarroll Posted January 28, 2018 Share Posted January 28, 2018 I picked up a nice post vice at a garage sale in Kankakee, Il for ten dollars a while back. there is no markings on it. The only damage is the rear washer on the tightening bolt is split and open about a half inch. The washer is a half inch thick with a tapered inside. I don't have any trouble using the vice but still would like to fix or replace it. My question is if the washer is something I can weld after squeezing back in place without special welding rod. The jaws are 5 and a half inches. The vise is mounted on a mulberry log set about 30" in the clay floor of my shop that holds it good. I don't have any sendable pictures at the moment. Thanks in advance for any advice. Jerry Quote Link to comment Share on other sites More sharing options...
Lionel h Posted January 28, 2018 Share Posted January 28, 2018 Just weld it up , if you like. I have several postvises some are missing washers it just makes tightening and loosening a little harder, but it’s still useable. Quote Link to comment Share on other sites More sharing options...
beaudry Posted January 28, 2018 Share Posted January 28, 2018 If welding it doesn't work for some reason , an easy way to make a new one is to bend a piece of 1/2'' round rod into a ring the same size and weld it. Or you can drift out a heavy chain link to the same size if you happen to have one in your scrap pile. The washers on the outsides of the front and back jaws on most post vises is tapered like that on the inside to allow the thrust load on the washer to stay in line with the screw box as the tilts up and down slightly as the vise is opened and shut. The jaws of a post vise open in a slight arc as opposed to a straight line like a machinists vise, hence the need for some slight looseness in the screw and screw box in the body of the vise. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 28, 2018 Share Posted January 28, 2018 If you are worried about welding it; braze it! Quote Link to comment Share on other sites More sharing options...
Daswulf Posted January 28, 2018 Share Posted January 28, 2018 I was advised that a throw out bearing from a manual transmission would work. The hard part is finding one that will. I have a whole bucket of old ones and did find one that will work for my large postvise. I haven't mounted it yet so that sits in waiting to try out. It would probably just be easier to follow any of the above mentioned. Quote Link to comment Share on other sites More sharing options...
anvil Posted January 30, 2018 Share Posted January 30, 2018 On 1/28/2018 at 12:08 PM, Daswulf said: I was advised that a throw out bearing from a manual transmission would work. Cool idea! Thanks Quote Link to comment Share on other sites More sharing options...
Daswulf Posted January 30, 2018 Share Posted January 30, 2018 25 minutes ago, anvil said: Cool idea! Thanks No problem, wasn't my idea but glad to pass someone else's good idea on. Quote Link to comment Share on other sites More sharing options...
